Sofia74 Samba Member
Posted: Wed Sep 14, 2022 2:14 pm Post subject: Diameter of the heater hose in the front footwell |
Does anyone know the diameter of the hoses that run up vertically from the heater channel there in the front footwells? The car is a 1974 KG Coupe. I see a couple options from the usual places and not seeing it in the Parts Book or the catalogues I have...
I am away from the car but trying to stock up on parts in advance of my next trip to work on the car.
While I’m here, do they just attach with hose clamps?
Thanks,
Matt |
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Thu Sep 15, 2022 9:08 am Post subject: Re: Diameter of the heater hose in the front footwell |
Hi Matt, when I bought mine they were listed by the vendors as fresh air hoses. If you search that they should be correct, yours should be the same size as what I got for my 71.
They should fit fairly snug over the little lip at the dogleg inside the car, but can be secured with those basic clamps, where they attach under the hood, you shouldn't need a clamp unless they are real loose.
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
gorbur Samba Member
Joined: October 10, 2010 Posts: 187 Location: West of Calgary
Posted: Fri Sep 16, 2022 8:35 am Post subject: Re: Diameter of the heater hose in the front footwell |
The stub coming out of the dogleg has an OD of 50mm. Thats on my 73' so assuming 74 the same. I do believe the earlier models had a smaller diameter. _________________ 73 - Ghia Cabriolet, currently under resto
76 - Type1, 1776, full restomod |
Posted: Fri Sep 16, 2022 12:47 pm Post subject: Re: Diameter of the heater hose in the front footwell |
Perfect. Thank you both.
Matt |
