heyskull Samba Member
Joined: August 07, 2022 Posts: 170 Location: Cumbria, England
Posted: Sun Sep 18, 2022 1:07 pm Post subject: Gear linkage problems |
I have now replaced all the bushes and couplings on my 72 Westfalia gear shift.
But I am still having issues engaging 3rd gear and the rest seem very vague.
I found that it has a quick shift spacer fitted but when this is removed and the correct length bolts fitted it will not shift at all.
Also if the shifter is put into 4th too briskly you can disengage the entire the gear stick.
I have checked that reverse shift is correctly fitted.
Thanks
SC |
busdaddy Samba Member
Posted: Sun Sep 18, 2022 2:49 pm Post subject: Re: Gear linkage problems |
Have a look at the pin the forward end of the shift rod slides on, it's often bent down from shifter abuse, it should be parallel with the bottom of the floor. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Sep 18, 2022 2:50 pm Post subject: Re: Gear linkage problems |
heyskull wrote: |
Not sure what you are meaning here.
Is the bushing on the front of the shift rod there and in good shape? |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Sun Sep 18, 2022 6:57 pm Post subject: Re: Gear linkage problems |
It’s possible that even if your shift linkage has been made like new, you can still have shifting issues. This can be in the tranny nose cone. The bushing (brass) for the hockey stick can be sloppy or the plastic ball in the nose cone can be worn out. It’s replacement is steel and costs $10. Either of these repairs can be done at home and cheaply but you’ll need to remove the engine and tranny to do them
_________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
sodbuster Samba Member
Joined: August 08, 2004 Posts: 1086 Location: wherever my baywindow takes me.
Posted: Mon Sep 19, 2022 12:55 pm Post subject: Re: Gear linkage problems |
Did you remove both pieces of the quick shift kit? The floor spacer and the piviot spacer? |
Posted: Mon Sep 19, 2022 1:05 pm Post subject: Re: Gear linkage problems |
I have managed to remove the quick shift completely and I am now getting all the gears. Third is very far over and if you put into fourth to briskly the gear stick disengages from the slot where the pin goes. I have checked everything and there is no slack or movement. I am beginning to think the lower gear stick is worn.
SC |
Posted: Mon Sep 19, 2022 3:50 pm Post subject: Re: Gear linkage problems |
Have a close look at that guide pin, and replace the plastic bushing in the front end of the rod/bowl if you haven't already. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Sep 25, 2022 12:02 pm Post subject: Re: Gear linkage problems |
Well I thought I would get the one thing on the gear shift side I hadn't replaced, the gear stick.
I purchased a new original gear stick from a reputable seller in the UK.
The picture shows the original on the left and the brand new replacement.
To say that no part of the base working part of the lever matches the original
The ball socket is smaller, the flat is not correct and will not allow the gear shift to go far enough down when trying to select reverse and lastly the pin is longer and mishaped on the end.
After further investigation either the wrong clutch cable has been fitted or it has stretched considerably as their is additional nuts on the cable and it is at its maximum adjustment.
Also the engine mounting nut and bolt at the upper left where the clutch lever is, is missing and to my mind this would cause a flex at the clutch pivot point.
SC |
Posted: Sat Oct 15, 2022 9:15 am Post subject: Re: Gear linkage problems |
Woo Hoo I have repaired it👍😜
This turned out to be the rear gearbox coupling.
Once I had drilled out the lock screw, as it had snapped and wrestled the pin screw out.
I pulled it out and found that the part that was locked on the shaft had about 1/2" of play.
This was causing the issue with the 3rd and 4th gate was not being twisted over enough.
All back together and refitted the old gearstick and quickshift and it changes all gears now very smoothly.
SC |
SGKent Samba Member
Posted: Sat Oct 15, 2022 9:20 am Post subject: Re: Gear linkage problems |
cool. Glad to hear it is fixed _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat Oct 15, 2022 9:24 am Post subject: Re: Gear linkage problems |
I was beginning to think all sorts of expensive issues.
The only issue is you couldn't feel the movement until it was removed.
The old cage was mangled due to all the stress it has had trying to hammer it into gear.
SC |
