GrigioTR Samba Member
Joined: September 18, 2020 Posts: 18 Location: woodinville, WA
Posted: Mon Sep 19, 2022 1:40 pm Post subject: 356B Rear Drum Question |
My VW has 356B rear brakes on a 60's transmission. Both sides were leaking transmission oil. I have disassembled the left side and found too many spacers and shims. No idea why since it appears the drum was not making full contact with the brake linings. Outboard about 1/8".
My plan is to rebuild the axle oil seal assembly and forgo the spacer that was slid on the axle after the bearing/seal cap was installed. Seems to stick out about 1/8' beyond the cap surface.
So here is the question. Does the axle spline or drum spline have enough taper to keep the inner drum axle area from making contact with the bolted-on oil seal cap? The drums came off surprisingly easy and makes me wonder if they were properly seated even with the 200+ foot pounds of torque.
Thanks in advance for any help. _________________ 1956 VW w/ blow through turbo
1984 Porsche Carrera |
Starbucket Samba Member
Posted: Sat Sep 24, 2022 2:18 pm Post subject: Re: 356B Rear Drum Question |
The splines are not tapered that's why the 200# torque. |
Big_E_Deluxe Samba Member
Joined: September 23, 2013 Posts: 264 Location: Charlotte, NC
Posted: Wed Oct 19, 2022 2:33 pm Post subject: Re: 356B Rear Drum Question |
Make sure you have the correct bearing cover matched to your axle. Checkout out the following post: https://www.thesamba.com/vw/forum/viewtopic.php?t=584479&highlight=rear+bearing+cover
It will identify the correct bearing cap paired with correct axle. I had a leaky axle due to mismatched cover and axle.
Also, make sure you are using the correct axle castle nut. A standard VW axle castle nut will not work properly with 356B drums. You need a Porsche 356 castle nut to clear the spline on axle. If you use a VW castle nut it will bottom out on the splines before it torques down on the drum, not good. Someone may have placed spacers to push drums out further on axle to allow castle nut to torque down without hitting spline (just guessing)
Correct castle nut/356 (notice bevel at threads to clear splines):
Hopefully one of these helps solve your problem, my guess it's the wrong bearing cap. Easy to get it wrong, very slight difference in design. _________________ Erik
1958 VW Beetle - "Max": https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
1959 VW Bus - "Hans" - Double Door Panel (sold): https://www.thesamba.com/vw/forum/viewtopic.php?t=746927
2014 Porsche 991.1 Carrera S |
wdfifteen Samba Member
Posted: Thu Oct 20, 2022 10:28 am Post subject: Re: 356B Rear Drum Question |
Erik got it right. VW nut will not work properly with Porsche brake drum.
The axle nut torque should be at least 350 ftlb and up to 400 ftlb. Make sure the nut threads and the axle threads are in good condition. |
