Rickf1985 Samba Member
Posted: Tue Dec 13, 2022 11:20 am Post subject: Re: Pushrods/valves SEEM to have stopped moving |
I realize this is all past history but look very closely at the case where that cam gear runs very close to it and see if you see any witness marks where the gear may have jammed something into the bottom of the case. There may have been a loose nut or small piece of metal floating around in there for years that finally found it way over to that gear where there is no clearance between gear and case. |
NachoCar Samba Member
Posted: Tue Dec 13, 2022 12:46 pm Post subject: Re: Pushrods/valves SEEM to have stopped moving |
yeah I would LOVE to know what the root cause was. I'll inspect for marks for sure!
Had one smarty pants engine builder who said it had to be the distributer drive shims/washers (he was twice the price of others like chico, mofoco, and strickly foreign). There were 2 still on and no remnants from any others
A mechanic I trust thinks the cam gear itself was defective.
It would be nice not to have a repeat, if you know what I mean. |
Posted: Tue Dec 13, 2022 2:30 pm Post subject: Re: Pushrods/valves SEEM to have stopped moving |
Well, The reason I mention this is I have seen that happen once before. BUT, I was after the #2 rod decided to become a multi piece rod at about 7,000 rpm. As the engine was still winding down in gear then bits and pieces got caught under that gear and did exactly what you see there. So, A little different set of circumstances but same end result. |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4423 Location: Stuck in Ohio
Posted: Tue Dec 13, 2022 7:12 pm Post subject: Re: Pushrods/valves SEEM to have stopped moving |
must be searching using wrong terms. Need quick advice.
Need to install a main bolt, one of six bigguns used to bolt case halfs together.
Finger tight with Permatex aviation? Guessing it will snug up when torqued properly?
Thanks I LOVE this shit.....and not too much to lose at this point. |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Wed Dec 14, 2022 3:10 am Post subject: Re: Pushrods/valves SEEM to have stopped moving |
Don't use any kind of sealant on the case stud where it threads into the case.. You'd do just fine to use red or blue loctite. I have always set most studs very snug past hand tight, but that may just be personal preference.
I think you will get it back together and be happy with it.. Tearing down and repairing an engine, and putting some miles on it after, is very rewarding. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
Posted: Wed Dec 14, 2022 5:54 am Post subject: Re: Pushrods/valves SEEM to have stopped moving |
Thanks guys.....I had already used blue loctite and made it flush with the other 2 bolts on that side. Fingers crossed! |
Posted: Wed Dec 14, 2022 7:21 am Post subject: Re: Pushrods/valves SEEM to have stopped moving |
Rickf1985 wrote: |
sure enough, found this sucker. Unclear if this points to a culprit
goober Samba Member
Posted: Wed Dec 14, 2022 7:32 am Post subject: Re: Pushrods/valves SEEM to have stopped moving |
scrivyscriv wrote: |
Tearing down and repairing an engine, and putting some miles on it after, is very rewarding. |
And liberating.
Once you realize there is nothing on your Bug you can't handle, you'll be freed from the never-ending cycle of external replace or repair. |
Posted: Wed Dec 14, 2022 7:36 am Post subject: Re: Pushrods/valves SEEM to have stopped moving |
And there you go. You will probably never know what it was but from looking it was not very big nor does it look like it was sharp sided steel. It may be just what the machinist said and it could have been a defective gear and that was a piece of it that came off and jammed. I have never seen one of those gears fail just on their own but there is always a first. And probably many more that were never reported, like before the internet. Back then they saw that and tossed the whole engine in the bin and pulled another out of another of the hundreds of cars in the yards. |
vamram Samba Member
Posted: Wed Dec 14, 2022 6:46 pm Post subject: Re: Pushrods/valves SEEM dead / engine build |
Nacho Car, what is it you found? Blame my ignorance but I don't see the smoking gun...?
_________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Posted: Thu Dec 15, 2022 6:54 am Post subject: Re: Pushrods/valves SEEM dead / engine build |
vamram wrote: |
See above where Rick mentioned looking for "Witness marks" on the interior of the case ....That's what I was referring to a couple posts earlier.
Still don't know the cause....I'm leaning towards a defective cam gear, which was suggested by a guy much more knowledgeable than I. |
Posted: Thu Dec 15, 2022 7:43 am Post subject: Re: Pushrods/valves SEEM dead / engine build |
He is talking about the gouge in the oil galley between the cam bearing and he oil pump where the gear jammed something between the gear and the housing. |
vamram Samba Member
Posted: Thu Dec 15, 2022 7:50 am Post subject: Re: Pushrods/valves SEEM dead / engine build |
Ah ok - now I see it. Thanks. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
Posted: Mon Dec 19, 2022 7:34 am Post subject: Re: Pushrods/valves SEEM dead / engine build |
couldn't get the main bearings orientated and seated correctly.
Ruined a set of German bearings and smooshed a dowel into the case. Hope there is enough left to hold bearing in place.
Off to research tips on marking and placing bearings correctly. dang it.
Posted: Mon Dec 19, 2022 9:45 am Post subject: Re: Pushrods/valves SEEM dead / engine build |
Patience my friend, Patience is key to building an engine. as you are putting the bearings in you can move them around just a bit and you will feel the dowel key into the hole. I am guessing you had the bearing in backwards and the hole was on the other side of the bearing? Especially since you are just beginning you need to take your time, have the manual open and check everything several times as you put it together. If you are watching a instructional video of engine assembly then do not be afraid to pause it, back up and look again. whatever it takes but patience. Do NOT try to keep up with the video. If you get frustrated then walk away, shut the lights off and come back later. Even shut down for the night and take the video inside and watch it over a couple of times.
Even those of us that have done hundreds of engines and make it look so easy and quick, we are still doing all the things I am telling you like feeling for the dowels, felling for tightness. Making sure all surfaces are spotlessly clean. It looks like we are not doing it since we move faster but we do all of those things. It becomes routine. Do not try to emulate the guys on the videos, they have done this so many times it is all habit to them and you do not see half of what they are doing because it is mostly in their heads.
And, above all, if you get stuck, DO NOT GUESS! Come here and ask before moving on! |
Posted: Mon Dec 19, 2022 9:48 am Post subject: Re: Pushrods/valves SEEM dead / engine build |
Thanks for the wise words guys!
I do tend to rush a bit. |
vamram Samba Member
Posted: Mon Dec 19, 2022 11:09 am Post subject: Re: Pushrods/valves SEEM dead / engine build |
I've assembled two engines and did this exact thing with the 2nd one. I knew immediately something was off because I couldn't turn the crank once I reached the final torque on the case bolts. Fortunately didn't damage the case and discovered it before final assembly and break -in. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
