Theichelberger Samba Member
Posted: Wed Sep 21, 2022 11:08 pm Post subject: 1385cc, What mechanical advanced distributor should I use? |
Hello, I've got a 1200cc that I'm building to be a 1385cc, and I was wondering what mechanical advanced distributor would work best with my set up.
My current set up is 1200 with the 1385cc big bore kit with a set of 1300cc cylinder heads on the jugs, I will be running dual single barrel Weber 34 ICT's, I will be keeping the stock cam (.285 on the intake .295 on the exhaust) but I will be putting a set of 1.25 rockers on it. I was wondering if a 010 distributor would work or is there a better option? Any information is greatly appreciated! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Thu Sep 22, 2022 5:26 am Post subject: Re: 1385cc, What mechanical advanced distributor should I use? |
An 010 is what's been used in the past.
Anything else would not be period correct _________________ Glenn
Member #1009
#BlueSquare |
Kblack1101 Samba Member
Joined: August 05, 2020 Posts: 162 Location: Wisconsin
Posted: Thu Sep 22, 2022 10:46 am Post subject: Re: 1385cc, What mechanical advanced distributor should I use? |
I've had good results using an 019 Glenn rebuilt for me. Running 1.1/1 rather than 1.25 - Valves are not big on these heads. _________________ 1964 Beetle
1977 Westy - SOLD
1985 Westy weekender |
Posted: Thu Sep 22, 2022 11:51 pm Post subject: Re: 1385cc, What mechanical advanced distributor should I use? |
What about an 050 distributor? I haven't heard much about them |
Glenn Mr. 010
Posted: Fri Sep 23, 2022 4:23 am Post subject: Re: 1385cc, What mechanical advanced distributor should I use? |
Theichelberger wrote: |
They're designed for Type 4 engines. _________________ Glenn
Member #1009
#BlueSquare |
Bub Samba Member
Joined: June 10, 2004 Posts: 1155 Location: Central Washington
Posted: Fri Sep 23, 2022 10:42 am Post subject: Re: 1385cc, What mechanical advanced distributor should I use? |
I ran an 019 screamer, an 022, then an BR25 /010 .
. Of those choices the 010 WITH a pertronix was the best without question on my 1386. I've always been of the opinion that points are fine, and pertronix was a solution to a problem that didn't exist in these engines.
But, I will say it runs very noticeably smoother compared to points. _________________
hitest wrote: |
Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was... |
Glenn Mr. 010
Posted: Fri Sep 23, 2022 12:16 pm Post subject: Re: 1385cc, What mechanical advanced distributor should I use? |
Bub wrote: |
I ran an 019 screamer, an 022, then an BR25 /010 |
022 has way too much advance. _________________ Glenn
Member #1009
#BlueSquare |
