calvinater Samba Member
Posted: Fri Sep 23, 2022 9:05 am Post subject: cummins 4bt |
anyone familiar with this engine?
would it pair well with a th400 transmission in a 0ne ton 77 chevrolet value van?
the boy and i are spitballing a camper setup. _________________ "Albatross"! |
modok Samba Member
Joined: October 30, 2009 Posts: 26743 Location: Colorado Springs
Posted: Fri Sep 23, 2022 11:11 am Post subject: Re: cummins 4bt |
I'm very familiar with the engine but less clear on what people like to do with them.
Personally I think the van is too small to handle the weight and vibration of that engine. |
Posted: Sat Sep 24, 2022 1:49 am Post subject: Re: cummins 4bt |
Ok thank you
Any recommendation for a replacement for a 454 cu in chevrolet engine?
Also has a 456 duel rear with positraction.
Hoping for some kind of diesel swap. _________________ "Albatross"! |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2175 Location: HdG, MD & NJ
Posted: Sat Sep 24, 2022 3:40 am Post subject: Re: cummins 4bt |
Most any LS engine and a 4L80 trans _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
cbeck Samba Member
Joined: January 14, 2014 Posts: 2494 Location: high ridge, mo
Posted: Sat Sep 24, 2022 5:08 am Post subject: Re: cummins 4bt |
Luv my 7.3 powerstroke. Pre emissions, 300 ish hp, 500 ish ft lb, 40 hp tow tune. Keep it under 2000 rpm and knock out almost 20 mpg. _________________ My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779 |
modok Samba Member
Posted: Sat Sep 24, 2022 11:09 pm Post subject: Re: cummins 4bt |
I have no clue to be honest.
See a lot of the cummins because they are very practical to rebuild.
Duramax and newer ford 6.4 and 6.7 diesels are not very good to rebuild.
Best look at a diesels that I'm not familiar with.
If it doesn't break then I'll never see one. |
cbeck Samba Member
Posted: Sun Sep 25, 2022 5:06 am Post subject: Re: cummins 4bt |
Is that the 4 cylinder? The mags have shown several of the 4 cylinders swapped into jeep size vehicles. Cummins used to offer a fairly complete engine kit. Several years ago the kit was around 10k.
The older 12 valves are popular swaps because of the simple wiring requirements. _________________ My cut in half and rebuild thread
mark tucker Samba Member
Posted: Sun Sep 25, 2022 1:24 pm Post subject: Re: cummins 4bt |
that may be a bit too much gear for a diesel. I wood go for a twin turbo small 6 cylinder gas or diesel...of coarse we did just buy a 2021 twin turbo crew cab ford truck ( gas)
I would not go with the 4le trans,I wood go with 6,8 or 10 speed.but there is a good amout of electronics to those. of coarse you could buy a newer crashed drive train& harness/putter combo for a "drop in" modern tech at a pretty good deal most of the time. choose your poison.
( for the engine you're thinking on, I would not worry about vibration, just install it right and there should be no issues.) one thing to remember. You don't need piles of horsepower just to go down the road, thus the6, 8&10 speed trans now days. hp& tq are needed for starting off and uphill. Witch the 6,8&10 speed trans help immensely. think it out, so there is no doubt. good luck. |
