kdnguyen61 Samba Member
Joined: June 14, 2019 Posts: 109 Location: Houston, Texas
Posted: Fri Sep 23, 2022 2:39 pm Post subject: Breathing System |
Dear Members,
I saw the Iron Resurrection show where they rebuilt a Ghia (filmed back in 2017 I think). I noticed this Austin VW club members installed the engine with this special breathing system that I have never seen before. Appreciate if anyone can share info on this. Thank you.
Braukuche Samba Member
Posted: Fri Sep 23, 2022 3:06 pm Post subject: Re: Breathing System |
It’s just a sort of Porsche 356/912 oil filler with breather connected to the air cleaners sort of kinda like a 912. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Posted: Fri Sep 23, 2022 3:36 pm Post subject: Re: Breathing System |
Thank you for that. I found some on eBay. |
74 Thing Samba Member
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76760 Location: Sneaking up behind you
Posted: Fri Sep 23, 2022 4:14 pm Post subject: Re: Breathing System |
Personally I don't like dumping oily air into the carb.
I have a Berg with both valve covers vented and the 3rd hose it vented to the atmosphere with a button foam filter on the end.
_________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Sep 24, 2022 7:13 am Post subject: Re: Breathing System |
Hi Glenn,
Thank you for your comments. Currently I have setup breather box with foam where two hoses coming from valve covers and third coming from oil filler stand.
I finally able to stop the leaking from the connectors at valve covers with stronger rubber hose and really tight down all connections. |
