busmike Samba Member
Joined: January 16, 2010 Posts: 205 Location: New Hampshire
Posted: Sat Oct 08, 2022 10:23 am Post subject: Re: Fastback returns home |
Family photo
Clatter Samba Member
Joined: September 24, 2003 Posts: 7544 Location: Santa Cruz
Posted: Sat Oct 08, 2022 12:09 pm Post subject: Re: Fastback returns home |
Are you going to switch the carbs over from your old motor?
Gonna be a chore getting another fuel line thru the tunnel,
As well as working out how to get the later FI tank into the early car.
Not that FI doesn’t work well,
But that’s a carbureted car, right? _________________ Bus Motor Build
What’s That Noise?!? |
Posted: Sat Oct 08, 2022 12:50 pm Post subject: Re: Fastback returns home |
Yes, I’m going to put carbs on the new motor. |
Posted: Thu Nov 17, 2022 6:33 am Post subject: Re: Fastback returns home |
So I gathered up what could possibly be needed to put carbs on new motor, is there something that I don’t need or something else I need.
Posted: Thu Nov 17, 2022 6:37 am Post subject: Re: Fastback returns home |
Can anyone tell what part number this is,I can only make out the 311
Posted: Thu Nov 17, 2022 6:38 am Post subject: Re: Fastback returns home |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22425 Location: Kimball, Mi
Posted: Thu Nov 17, 2022 1:20 pm Post subject: Re: Fastback returns home |
Just a heads up, you don't want to run those metal type 1 intake manifold gaskets, as they'll cause a vacuum leak. You're better off getting thick paper or something like that instead. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Thu Nov 17, 2022 1:44 pm Post subject: Re: Fastback returns home |
Thanks Bob,removed metal, now have thick paper gaskets. Back to the original question, do I need all of these items.
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
Posted: Fri Nov 18, 2022 10:54 am Post subject: Re: Fastback returns home |
busmike wrote: |
you only need the phenolic piece once, it's to keep the heat from soaking in the carb.
I've never ran either one with stock or aftermarket carbs. _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
Posted: Sun Jan 08, 2023 7:50 am Post subject: Re: Fastback returns home |
I started buffing out the hood
ibldrc Samba Member
Joined: September 23, 2015 Posts: 156 Location: Savannah, GA
Posted: Thu Feb 02, 2023 10:38 am Post subject: Re: Fastback returns home |
I bought a synchronizer and did not get the adapter to use with my stock carbs,this is what I found in my leftover plumbing parts. They are under $7 at Lowe’s. The size is perfect when you have the rubber seal for the air cleaner on.
Posted: Tue Feb 21, 2023 6:56 am Post subject: Re: Fastback returns home |
I’ve been working out some electrical gremlins, when I put the turn signal on the green light flashes only one time and goes off but the the lights continue to work as the should. Any suggestions. |
Cschenkel Samba Member
Joined: February 20, 2013 Posts: 114 Location: San Bruno, CA
Posted: Sun Feb 26, 2023 10:17 am Post subject: Re: Fastback returns home |
IF all the bulbs work then its likely the turn signal relay or something going on with the turn signal it self. In my Square the relay sometimes sticks and I can also get the arm to go "too far" and it just wont turn the signal on. I've learned to deal with it for the time being, its like playing an old piano. |
Posted: Mon Mar 20, 2023 10:05 am Post subject: Re: Fastback returns home |
I got the drivers seat reupholstered this weekend.
Posted: Tue Mar 28, 2023 5:03 pm Post subject: Re: Fastback returns home |
. I finished the seats , put in a parcel tray and cup holder today. |
Posted: Wed Mar 29, 2023 5:05 am Post subject: Re: Fastback returns home |
. 2023 upgrade. It’s as modern as this car is going to get. |
Posted: Sun Apr 09, 2023 8:57 am Post subject: Re: Fastback returns home |
Took the fastback out yesterday for its spring maiden voyage, it performed great with its new engine,fresh upholstered seats and shined nice in the sun. |
Posted: Mon Apr 22, 2024 4:19 pm Post subject: Re: Fastback returns home |
Fixed dent that has been in car since I got it back in 2007
catbox Samba Member
Joined: May 16, 2007 Posts: 866 Location: Portland, Oregon
Posted: Yesterday 10:55 am Post subject: Re: Fastback returns home |
Excellent work on the dent fix!
Car looks like fun for sure. _________________ "...these cars were preferred by the racers because the strut front suspension results in far superior handling than the regular torsion bar front end..." - Keith Seume. |
