oprn Samba Member
Joined: November 13, 2016 Posts: 12706 Location: Western Canada
Posted: Sat Sep 24, 2022 4:59 am Post subject: Jetta gearing question |
I have an '02 Jetta TDI with worn 1st and 2nd gear synchros. I have access to an '02 Golf 2.0L gas transaxle, how close are the gear ratios? _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Sat Sep 24, 2022 7:20 am Post subject: Re: Jetta gearing question |
I do not know what transmission you have but 020 transmission first gears are all the same, there are two different 2nd gears and I believe one is a 2.1 and the other option is a 1.9. I'm not even going to research to prove I am right so if someone points out I am wrong, believe them.
You may get better answers if you posted what transmission you was thinking about swapping. |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Sat Sep 24, 2022 10:32 am Post subject: Re: Jetta gearing question |
The 020 were in the early mkIII 2.0 cars, and not in any of the TDI mkIII's. Most likely an 02A tranny. You'd need to consult a Bently of some online source to be sure what the ratios for each are.
And being you have a mkIV, it will be an 02A, as an 020 would never fit those. |
flyinglow94 Samba Member
Joined: January 17, 2005 Posts: 1164 Location: Las Vegas, Nevada
Posted: Sat Sep 24, 2022 7:57 pm Post subject: Re: Jetta gearing question |
Check out this page on all VW water ooled transmission/ gearbox gearing https://www.zelek.com/diagram_Charts/diagramlist.htm. its a tremendous help. _________________ "What we obtain too cheap, we esteem too lightly: 'tis dearness only that gives everything its value. Heaven knows how to put a proper price upon its goods; and it would be strange indeed if so celestial an article as FREEDOM should not be highly rated."
"Socialism is a philosophy of failure,the creed of ignorance, and the gospel of envy,its inherent virtue is the equal sharing of misery.." |
volksworld Samba Member
Joined: November 26, 2011 Posts: 2529 Location: formerly NY currently NC
Posted: Sat Oct 01, 2022 1:21 pm Post subject: Re: Jetta gearing question |
the first couple pages of section 34 of the Bently manual lists all the trans and gear ratios for the 02J but you need the 3 letter code off the trans...2.0's and diesels vary some have 3.389 final drives and some have 4.235's....each gear varies too...got an 04 tdi and an 04 2.0 myself ....the gas car you're in fifth on 55mph country roads, the tdi doesnt want 5th till the interstate |
oprn Samba Member
Posted: Tue Nov 08, 2022 6:30 am Post subject: Re: Jetta gearing question |
Thanks all for the responses. I found a TDI gearbox so will go with that. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
