sallittjob Samba Member
Joined: September 16, 2010 Posts: 340 Location: North NJ
Posted: Sun Sep 25, 2022 1:02 pm Post subject: Cleaning Type 4 AMC Head Flashing with Engine Installed |
I recently rebuilt my 1800cc type 4 bus motor and have been monitoring CHTs & AFR. No matter what I do, it is running a little too hot for my liking (400-415 highway and uphills).
I ran a bore scope over the new AMC heads and noticed the air ports in the center are almost completely blocked on the driver's side head (didn't check the passenger side yet). I pulled the dirty, old stock head out of storage to compare, and sure enough, the ports are wide open on the stocker.
I did some research and saw this is a common issue with AMC heads. I want to try and drill out the flashing in the center section of the head but I have no clear way to do it. I was thinking my best bet is to drain the oil, pull the pushrod tubes and remove the bottom air deflector to gain access from below. I'm not looking forward to it but that seems like the best option at this point. Alternatively I could remove the top tins, but that seems like a huge pain. I should also mention, I have the fan housing pulled, so I can get my hand in there but I'm not sure an angle drill could get it from inside the tin as there is minimal vertical clearance. That'd be easiest though if anyone knows of a angle drill I could buy that would fit.
Any suggestions?
Thanks all! _________________ 57' Beetle Deluxe
1192cc SP
71' Super Beetle
1968cc DP
73' 412 Sedan
1679cc FI
75' Westy
1800cc FI |
SGKent Samba Member
Posted: Sun Sep 25, 2022 6:50 pm Post subject: Re: Cleaning Type 4 AMC Head Flashing with Engine Installed |
some places leave it up to you to clean the flashing. The ones I got from Len Hoffman were already cleaned up. Colin just did one in I think St Louis where it took him 401 plunges with a long drill bit to clean the flashing out. Once that was done head temps came down to a normal range. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Sun Sep 25, 2022 7:32 pm Post subject: Re: Cleaning Type 4 AMC Head Flashing with Engine Installed |
I would first make sure that your fuel air mixture is correct. After that, I’d think an air powered pencil grinder or an electric Dremel would work best
Neiko 10649A 1/8-Inch Pencil Type Micro Air Die Grinder, 54000 RPM https://a.co/d/a8LJDS9
CBTOEN 20 PCS Carbide Burr Set 1/8 Inch Shank Double Cut Tungsten Carbide Rotary Burrs Die Grinder Bits for Carving, Polishing, Engraving and Drilling https://a.co/d/9D6Ey5I
Dremel 8220-1/28 12-Volt Max Cordless Rotary Tool Kit- Engraver, Sander, and Polisher- Perfect for Cutting, Wood Carving, Engraving, Polishing, and Detail Sanding- 1 Attachment & 28 Accessories https://a.co/d/eFziCNp _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Nitramrebrab72 Samba Member
Joined: November 10, 2018 Posts: 485 Location: France
Posted: Mon Sep 26, 2022 12:19 am Post subject: Re: Cleaning Type 4 AMC Head Flashing with Engine Installed |
Check your air fuel mixture. Flashing alone won't do that.
I have AMC heads and I run no more than 275f on very steep hills. |
crownline Samba Member
Joined: September 10, 2010 Posts: 593 Location: Northwoods of WI
Posted: Mon Sep 26, 2022 4:08 am Post subject: Re: Cleaning Type 4 AMC Head Flashing with Engine Installed |
Is your thermostat working correctly? Are the flaps opening all the way when up to temp? _________________ 1972 Bus 1700 cc Single Carb. But not a progressive.
Barelymuvin
Wish I still had the ones I got rid of.
"It"s got some dings and dents and neither of us is going to SEMA."(Update, I went to SEMA in 2019 but the Bus stayed home)
[url=http://www.vw-mplate.com/mplate-8446.png]Click to view image[/URL] |
Posted: Mon Sep 26, 2022 5:08 am Post subject: Re: Cleaning Type 4 AMC Head Flashing with Engine Installed |
Thanks all for the responses. I have a DD CHT gauge, Dash-Mounted Wideband and a 5k potentiometer all in the cockpit. So needless to say, I've experimented quite a bit with AFR and timing settings. I can keep it below 380°F around town. Once I hit the highway or load it up a long hill, the CHTs climb and I have a hard time cooling it back down.
When I rebuilt the engine, the driver's side flap was completely missing. I sourced a "new" one from Awesome Powedercoat. Unfortunately he used 3D printed plastic hinges riveted to the flap. These were getting soft at operating temp and the entire flap was falling off the hinges, binding my flaps rod. So I used a scope camera, removed the fan, and fished a long screwdriver up there and popped it back on. Confirmed it was opening all the way and then took it out for a test drive. Still hot.
Next move was to pull the entire fan housing. I did that and drilled out the 3D printed hinges. I fabricated new ones from some sheet steel I had. Shouldn't be an issue any more. I used the scope camera and a flashlight to check the flashing while I have it apart. The center-section of the new AMC heads are almost completely blocked. I think that is the biggest issue, so here we are.
I'm going to pull the pushrod tubes, stuff shop rags in the heads and case bores. Then I'll remove the air deflectors that are bolted to the bottom of the heads. I think an extended 1/8" drill bit is the way to go. Not looking forward to it but it seems like my best option.
P.S. static C/R is 7.3 : 1. This is an entirely stock 1.8L bus motor with stock cam. All cooling tin is in place and I painstakingly sealed up any cracks between tin. The foam engine seal is new and installed. I don't think there is anything else I'm missing that could explain the high CHTs. It's driving me nuts LOL.
Thanks _________________ 57' Beetle Deluxe
1192cc SP
71' Super Beetle
1968cc DP
73' 412 Sedan
1679cc FI
75' Westy
1800cc FI |
airschooled Air-Schooled
Posted: Mon Sep 26, 2022 6:41 am Post subject: Re: Cleaning Type 4 AMC Head Flashing with Engine Installed |
The center section of the head flashing won't contribute directly to hot CHT temps, as the intake ports are constantly bathed in a cool air and fuel mixture. The flashing towards the outer edges near the exhaust ports are much more important. Yes they should all be drilled out, but I believe your problem lies elsewhere.
How long has this problem been going on? Have you inspected the CHT ring sender to make sure it's fully seated and not pulled sideways creating a gap? In my experience it's nearly impossible to install one in an AMC T4 head without cutting a notch for the crimp and wiring.
Do the temps come down quickly if you coast down a hill in gear?
How are you setting your timing? Do the temps drop 10-15° when you retard the timing 5° temporarily?
www.airschooled.com |
Posted: Mon Sep 26, 2022 9:58 am Post subject: Re: Cleaning Type 4 AMC Head Flashing with Engine Installed |
airschooled wrote: |
Robbie |
CHT probe is epoxied into a hole I drilled in the head right by the #3 plug. I should mention that I double-checked the temp with a separate thermocouple/thermometer setup and it was exactly the same temp, so I believe the gauge reading.
It's been running hot since I rebuilt the engine.
Yes, temps come down quick when I coast down hill in gear.
Stock distributor, hoses removed @ 2,500 RPM or so. I'm at 28° max now, tried anywhere between 26-30°.
The intake port area is the most obvious but the area near the exhaust ports isn't clear either. I should have clarified. Only a few tiny holes of light get through in both sections. I compared to my old stock head and it was a noticeable difference. _________________ 57' Beetle Deluxe
1192cc SP
71' Super Beetle
1968cc DP
73' 412 Sedan
1679cc FI
75' Westy
1800cc FI |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7551 Location: Santa Cruz
Posted: Thu Sep 29, 2022 10:16 am Post subject: Re: Cleaning Type 4 AMC Head Flashing with Engine Installed |
Robbie |
^^^X2^^^
You can lower cruise CHT by richening mixture.
The question becomes if it’s too rich. _________________ Bus Motor Build
What’s That Noise?!? |
SGKent Samba Member
Posted: Thu Sep 29, 2022 12:31 pm Post subject: Re: Cleaning Type 4 AMC Head Flashing with Engine Installed |
colin said the one he cleaned up was almost completely blocked across the head. It came from some porsche guru in St Louis I think he said. Len cleans his out. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Sun Oct 02, 2022 3:23 am Post subject: Re: Cleaning Type 4 AMC Head Flashing with Engine Installed |
sallittjob wrote: |
Robbie |
The intake port area is the most obvious but the area near the exhaust ports isn't clear either. I should have clarified. Only a few tiny holes of light get through in both sections. I compared to my old stock head and it was a noticeable difference. |
Time @ 3400+ 28BTDC
How certain is the thermo-coupler installed for the DD?
What are your temps when not pulling a grade/hill?
How many miles on engine? _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
SGKent Samba Member
Posted: Sun Oct 02, 2022 7:44 am Post subject: Re: Cleaning Type 4 AMC Head Flashing with Engine Installed |
often the cracks in the T4 head are in the roof of an intake port. Colin theorized that the temperature differential between the ports and surrounding area contributed to that. I would clean all flashing out if it is clearly flashing or too diversionary. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Bonesberg55 Samba Member
Posted: Sun Oct 02, 2022 8:53 am Post subject: Re: Cleaning Type 4 AMC Head Flashing with Engine Installed |
I'm a lifelong Rambler guy and I don't recall them ever making VW heads! |
SGKent Samba Member
Posted: Sun Oct 02, 2022 11:08 am Post subject: Re: Cleaning Type 4 AMC Head Flashing with Engine Installed |
Bonesberg55 wrote: |
AMC and AMC are different companies but you knew that
American Motors Corporation of (USA)
Amadeo Marti Carbonell S.A. (Spain)
They make the head castings but it is up to the importer to add valves, springs etc.. That is why the quality varies between companies that sell the heads. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
