How to remove vdo 64 clock needle
karmann17
karmann17 is offline
PostPosted: Mon Sep 26, 2022 12:44 pm    Post subject: How to remove vdo 64 clock needle Reply with quote
Hello,
Everything is in the title, impossible for me to remove this needle, could you tell me how it's possible ? 🤔 Thank you
karmann17
PostPosted: Tue Sep 27, 2022 9:45 am    Post subject: Re: How to remove vdo 64 clock needle Reply with quote
Nobody knows??? 🥺
sputnick60
sputnick60 is offline
PostPosted: Tue Sep 27, 2022 12:13 pm    Post subject: Re: How to remove vdo 64 clock needle Reply with quote
karmann17 wrote:
Nobody knows??? 🥺
A small cloth to protect the face. Two spoons with the tips under the needles and backs resting on the cloth. Push down on the spoon handles to apply a controlled force on the needles
The needles push on. Has someone done something like glue your's on?
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
Era Vulgaris
Era Vulgaris is offline
PostPosted: Tue Sep 27, 2022 3:23 pm    Post subject: Re: How to remove vdo 64 clock needle Reply with quote
The needles are press fit onto the spindle. When I removed them from my clock to convert it into a tach, I used a fork. Slide the fork under the needles so that the spindle is between the fork teeth, then pull upward. If you plan on re-using the clock internals, make sure you pull straight upward and not sideways or you'll bend the spindle. This also works with speedo needles.
Currently own:
66 Karmann Ghia, L390 Gulf Blue, under construction, here: www.thesamba.com/vw/forum/viewtopic.php?t=760505&highlight=
99 Mazda MX-5 10AE, Sapphire Blue Mica, 6 speed, LSD
Previously owned:
98 Porsche Boxster, silver, 2.5L -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue
karmann17
PostPosted: Tue Sep 27, 2022 10:55 pm    Post subject: Re: How to remove vdo 64 clock needle Reply with quote
sputnick60 wrote:
karmann17 wrote:
Nobody knows??? 🥺
Nicholas
I'm affraid about the Idea of the glue... Nothing works.... It will finish vith a dremel... 😥
