hushcar Samba Member
Posted: Tue Sep 27, 2022 2:42 pm Post subject: Bus 3 rib tranny to 2.0 engine |
Hello, I believe I can put a later bus engine, like a 2.0 liter from a 78 Bus into an early bay, 1971 if I change the bell housing? Is that true and if so what Bell housing year do I need to use? Thanks ahead! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51123 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Sep 27, 2022 4:01 pm Post subject: Re: Bus 3 rib tranny to 2.0 engine |
You'd be better off changing the flywheel, a 210mm type 4 will fit your existing trans, you'll have to put a pilot bearing in the flywheel to reach that shorter type 1 input shaft though.
But unless you plan on running giant tires you'll be super disappointed with the performance, the gear ratios will top out long after that long stroke 2l stops making torque and the shift points will place the next gear in a range between best power speeds. Good for drag racing, not so much for climbing long mountain passes. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent Samba Member
Posted: Tue Sep 27, 2022 5:19 pm Post subject: Re: Bus 3 rib tranny to 2.0 engine |
if your intent is to have a bus that will be enjoyable, stay with the type 1 engine and put a little larger cylinders in it like for a 1776. If your intent is to make a lot of power and have a handful of modifications and expenses, put in a type 4 2L with an 091 six rib transmission. If your intent is to flip some bus you found without an engine, just clean it up and flip it as is. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16959 Location: San Diego, California
Posted: Tue Sep 27, 2022 6:16 pm Post subject: Re: Bus 3 rib tranny to 2.0 engine |
Good luck. You’ll need it _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
timvw7476 Samba Member
Posted: Tue Sep 27, 2022 8:29 pm Post subject: Re: Bus 3 rib tranny to 2.0 engine |
the early 002 ratios really make 1st a 'granny gear' once you bolt even a 1800 Type IV to it. Along with 16mpg. A 2.0L would pull down 15mpg at best. If that's your thing, & you think you need a VW bus with a granny low for wood hauling or tow work . Wait, that's crazy. 091 usually provides up to 23+ with a 2.0L.
VW matched the ratios/final drive really well for all around use. |
Posted: Tue Sep 27, 2022 8:41 pm Post subject: Re: Bus 3 rib tranny to 2.0 engine |
In addition, the later 091 transmission has much stronger workings that are built for the 2.0 size engine. So if you go with the 002 you’ll suffer reliability as well as drivability and economy _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
busman78 Samba Member
Joined: August 17, 2004 Posts: 4520 Location: Oklahoma City, OK
Posted: Wed Sep 28, 2022 3:43 am Post subject: Re: Bus 3 rib tranny to 2.0 engine |
If your making that 2.0L into and upright engine via a DTM or other option you will have a screamer, the 2.0L or any of the T4 will out torque your stock T1. But if you are going to try and stuff the T4 with all the tin and cooling in stock form go buy a 72 or later bay.
And to answer your question, get a 210mm flywheel and clutch set, since you have a 71 now your TO bearing will work. |
Posted: Wed Sep 28, 2022 5:21 am Post subject: Re: Bus 3 rib tranny to 2.0 engine |
I have an 002 coupled with an 1800 in my '77. The 002 has a lower first gear so that I didn't have to use the clutch as much on really rough roads, and I had 4th gear upped a bit so that combined with 27x8.5R14 tires I get about the same highway rpm as a stock 091 would give. I have been running this combo for 6 or 7 years now and it is doing me well. |
nemobuscaptain Samba Member
Posted: Wed Sep 28, 2022 7:34 am Post subject: Re: Bus 3 rib tranny to 2.0 engine |
hushcar wrote: |
as others have said, the general rule is match the flywheel and clutch from the transmission and everything works, in this case those from a 1700 or 1800 work well.
However, cutting up the bus to fit T4 engine tins is a lot of work and destroys value, if that is what you are planning.
Much easier to sell the 2.0 and get the right engine. If you do cut the back to fit the T4 engine, keep the parts you remove. _________________ Ohio Valley Tribe, Full Moon Bus Club https://www.facebook.com/groups/294422277314227/
https://www.facebook.com/groups/FullMoonBusClub
RIP Bob Hoover https://www.thesamba.com/vw/forum/viewtopic.php?t=427791
Hoover Sermons: https://www.vwsage.com/images/vwsage/Bob%20Hoovers%20Sermons.pdf
Last edited by nemobuscaptain on Thu Sep 29, 2022 3:49 pm; edited 1 time in total |
RalphWiggam Samba Member
Joined: February 02, 2018 Posts: 906 Location: SouthEast
Posted: Thu Sep 29, 2022 5:03 am Post subject: Re: Bus 3 rib tranny to 2.0 engine |
Wildthings wrote: |
I have a spare 2L that I havent built yet for my bus. Would be about the same setup as yours. My 1.7L has all the 'fixins' and to me it seems like the 210mm clutch setup is already at about its limit.
Do you notice any indications that a 210mm setup cant hold the power of the 2L? |
Posted: Thu Sep 29, 2022 5:13 am Post subject: Re: Bus 3 rib tranny to 2.0 engine |
From experience I can say yes it will. Just consider the T1 crowd with over 2L engines cranking out lots of HP and they use a 200mm. The 210 pressure plate will be more than enough. |
Posted: Thu Sep 29, 2022 5:43 am Post subject: Re: Bus 3 rib tranny to 2.0 engine |
RalphWiggam wrote: |
I have a 228 clutch. The lining was still fine after 180k+/- miles but all the springs in the disc were shot. |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Thu Sep 29, 2022 7:50 am Post subject: Re: Bus 3 rib tranny to 2.0 engine |
One of my friends daily drives his 2L with an early 002 and stock tires. He loves the acceleration that keeps up with modern traffic on shitty stroads. We had the engine out last year for gas tank work, and found the 210mm clutch to be thicker than 8mm after 40k moles. No slippage at all, and the engine is tuned well.
I really like driving his bus around town, but if I were doing significant freeway miles, I would want the proper gearing.
www.airschooled.com |
Xevin Samba Member
Posted: Thu Sep 29, 2022 8:50 am Post subject: Re: Bus 3 rib tranny to 2.0 engine |
airschooled wrote: |
We had the engine out last year for gas tank work, and found the 210mm clutch to be thicker than 8mm after 40k moles. |
That’s a lot of moles
F’ing autocorrect wins again _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
