LED Dash lights
saddlesore1
saddlesore1 is offline
PostPosted: Tue Sep 27, 2022 3:39 pm    Post subject: LED Dash lights Reply with quote
I received an email from one of the big 2 suppliers for LED dash lights and went down the rabbit hole. I could not believe that a compete set of lights (10) could possible cost $70 plus tax and shipping. I went to my local electronic store and was able to order the exact same items for $22 out the door. I guess the box cost $50
Starbucket
Starbucket is offline
PostPosted: Wed Sep 28, 2022 4:37 pm    Post subject: Re: LED Dash lights Reply with quote
$50.00 because it has a picture of an old Porsche Laughing
qwerty
qwerty is offline
PostPosted: Sun Oct 02, 2022 7:35 pm    Post subject: Re: LED Dash lights Reply with quote
Take your pick
https://www.amazon.com/ba7s-led/s?k=ba7s+led
Slip356
Slip356 is offline
PostPosted: Thu Oct 13, 2022 5:27 am    Post subject: Re: LED Dash lights Reply with quote
Do you have any info on 6 volt led dash lights. All I see are 12 volt.
Slip
Starbucket
PostPosted: Thu Oct 13, 2022 7:22 am    Post subject: Re: LED Dash lights Reply with quote
Slip
Scroll down until you see 6volt.
Slip356
Slip356 is offline
PostPosted: Thu Oct 13, 2022 2:50 pm    Post subject: Re: LED Dash lights Reply with quote
Thanks, will do more research, then order them.
Starbucket
PostPosted: Thu Oct 13, 2022 3:02 pm    Post subject: Re: LED Dash lights Reply with quote
I don't think I would change the gen. light to LED unless the Mfg. states it won't affect the charging.
Slip356
Slip356 is offline
PostPosted: Fri Oct 14, 2022 6:05 am    Post subject: Re: LED Dash lights Reply with quote
Star bucket, I think you are talking alternator, not generator like I have. Those with more knowledge than me will hopefully chime in.
Slip
Starbucket
PostPosted: Fri Oct 14, 2022 7:16 am    Post subject: Re: LED Dash lights Reply with quote
Slip
You are right, that was for alternator.
Slip356
Slip356 is offline
PostPosted: Sat Oct 15, 2022 6:40 am    Post subject: Re: LED Dash lights Reply with quote
Don’t plan on changing alternator or oil light as they are plenty bright, day or night. Remaining lights are too dim, hopefully LED’S will brighten up the dash at dusk or dark.
Slip356
Slip356 is offline
PostPosted: Sat Oct 15, 2022 6:42 am    Post subject: Re: LED Dash lights Reply with quote
Meant to say generator light, not alternator. Need more coffee!
saddlesore1
PostPosted: Fri Oct 28, 2022 2:28 pm    Post subject: Re: LED Dash lights Reply with quote
Changed all of them out. Found out the Geni light was on or off only. It takes more amps/volts to trigger than standard so I pulled it out and replaced with standard bulb. Found same thing for oil.
Other than that the dash lights up brighter.
Slip356
Slip356 is offline
PostPosted: Fri Oct 28, 2022 3:13 pm    Post subject: Re: LED Dash lights Reply with quote
Good to know, haven’t ordered mine yet but will soon. Can they be dimmed like standard 6volt dash lights?
Where did you purchase them from?
So now I have three winter projects -good.
1. Led dash lights
2. Third brake light. Have purchased two 8 in 6 volt units from Stoddard.
3. A 6 to 12 volt inverter to change the cigarette lighter to 12volts to feed my Garmin & charge my cell phone when traveling.
Looks like a good winter.
Starbucket
PostPosted: Sat Oct 29, 2022 9:56 am    Post subject: Re: LED Dash lights Reply with quote
Amazon has them.
