modok Samba Member
Joined: October 30, 2009 Posts: 26779 Location: Colorado Springs
Posted: Wed Sep 28, 2022 7:10 pm Post subject: Re: Rear transmission mount |
Ah, ok. Nice! |
DerrickfromNC1 Samba Member
Joined: October 24, 2008 Posts: 1300 Location: North Carolina
Posted: Mon Jan 23, 2023 9:51 am Post subject: Re: Rear transmission mount |
extremebuggy wrote: |
NJ John wrote: |
Empi sells this one. It’s HD like the solid mount, but allows for stock or poly mounts. I like it so far. |
That looks just like the EMPI that I was looking at from JBugs. |
Where can I find that rear cradle above. I found this one below which looks more like a reproduction rather than a HD like the one above.
Also this urethane mount has less than 1000 miles and fell apart on my car that has been on jackstands and not seen any road time in over 20yrs.
Posted: Mon Jan 23, 2023 11:31 am Post subject: Re: Rear transmission mount |
Looks like I’m out of luck on obtaining this HD rear cradle as it is part of the EMPI rear trans strap kit:
NJ John Samba Member
Joined: September 21, 2007 Posts: 2222 Location: HdG, MD & NJ
Posted: Mon Jan 23, 2023 12:13 pm Post subject: Re: Rear transmission mount |
They do sell it without the straps. Empi # 18-1106 _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
Posted: Thu Jan 26, 2023 12:36 pm Post subject: Re: Rear transmission mount |
NJ John wrote: |
They do sell it without the straps. Empi # 18-1106 |
Thanks NJ, I picked one up from “Carolina Dune Buggies” the other day. Waiting on a bolt on mid mount, and a set of HD(grey rubber) front and rear motor mounts that I ordered. Plan to next order a bolt on Truss bar just can’t decide which one….empi or the Coolrydes version that ties in a 3 points.
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3817 Location: Georgia
Posted: Thu Jan 26, 2023 3:00 pm Post subject: Re: Rear transmission mount |
I got the Coorydes version.
Went on fairly easily.
My only suggestion is to chase out the threads with a tap first or at least make sure the heim joints turn in smoothly.
_________________ Volkswagen!
(Compression 8.7:1) |
Posted: Thu Jan 26, 2023 6:15 pm Post subject: Re: Rear transmission mount |
Truss bar is next for me, too. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9755 Location: Oregon
Posted: Thu Jan 26, 2023 6:51 pm Post subject: Re: Rear transmission mount |
jeffrey8164 wrote: |
The only bummer with the truss bar kit is. You can't use your heat transfer tubes.
How are you supposed to chasse the reverse threads?
When I bought my kit. I had a hard time with the threaded ends.
I hit up Kevin on a Saturday (email). I was surprised he actually responded that day.
Kevin said he'd cover the cost of a replacement, if I galled the reverse threaded ends, while turning in the heim joints.
If you're gonna hard launch the car. Tighten the right side as best as you can. It will help with the wheel hop! _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Thu Jan 26, 2023 7:10 pm Post subject: Re: Rear transmission mount |
With reverse Taps of course.
I didn't pay attention to any side specifically. I gave all the rods about the same preload and tightened it all down.
I'm not a track star, I just rip it up on deserted streets and parking lots.
This bar and a mid mount and haven't experienced any hop whether in a straight line or slow donuts. _________________ Volkswagen!
Posted: Fri Jan 27, 2023 2:17 pm Post subject: Re: Rear transmission mount |
Is anyone using the Truss bar with an automatic beetle starter. I was wondering if there was a clearance issue between the two? The EMPI catalog states that it will not fit with the larger Bosch SR-17 autostick starter or other oversized starter.
Thanks
Last edited by DerrickfromNC1 on Fri Jan 27, 2023 3:53 pm; edited 1 time in total |
Posted: Fri Jan 27, 2023 2:28 pm Post subject: Re: Rear transmission mount |
DerrickfromNC1 wrote: |
Is anyone using the Truss bar with an beetle starter. I was wondering if there was a clearance issue between the two? The EMPI catalog states that it will not fit with the larger Bosch SR-17 autostick starter or other oversized starter.
Thanks |
Derrick, I have a stock starter in my 67. The truss bar clears the starter with no issues.
I can't speak for the AutoStick starter clearance. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Fri Jan 27, 2023 3:52 pm Post subject: Re: Rear transmission mount |
Thanks |
Posted: Fri Jan 27, 2023 5:39 pm Post subject: Re: Rear transmission mount |
Upon further review, it appears that my automatic starter is about 1.5” longer than a standard starter. This positions the solenoid right in the path of the horizontal truss bar connecting the shock towers. Fortunately I only pd. $15 for this used starter so it won’t hurt too bad to switch it out. |
Posted: Tue Feb 20, 2024 11:40 am Post subject: Re: Rear transmission mount |
Duralast front transmission mount from Autozone that was in my spare parts bin. It was purchased at least a couple yrs ago.
Studs are molded in crooked, went back to get a 2nd one Saturday and it was identical. I guess at $5.00 this is what you get. This may not be a issue for a trans with a factory nose cone but I have a older Transform 5speed with a different nose cone and these crooked studs are a no go. |
nextgen Samba Member
Joined: August 19, 2004 Posts: 6024 Location: CONGERS, N.Y.
RickS Samba Member
Posted: Tue Feb 20, 2024 4:25 pm Post subject: Re: Rear transmission mount |
nextgen wrote: |
One type of Mount I totally believe should be thought about to use and they are cheap in the $30 to $50 range is the mid engine mount. Yes it does toughen the ride a but it does prevent the original engine/tranny mount from breaking. The pulling the engine out is not fun. |
How does a mid mount affect pulling the engine? |
Posted: Tue Feb 20, 2024 4:43 pm Post subject: Re: Rear transmission mount |
RickS wrote: |
nextgen wrote: |
Doesn’t affect pulling the engine……pulling transmission yes. |
RickS Samba Member
Posted: Wed Feb 21, 2024 6:14 am Post subject: Re: Rear transmission mount |
RickS wrote: |
nextgen wrote: |
Do you think I didn’t know this? |
