Cam bearings ???
QRP
QRP is offline
PostPosted: Tue Nov 30, 2021 12:35 pm    Post subject: Cam bearings ??? Reply with quote
Do any shops still bore older 40hp cases for cam bearings??
RCP Phx
RCP Phx is offline
PostPosted: Tue Nov 30, 2021 1:00 pm    Post subject: Re: Cam bearings ??? Reply with quote
I would think Rimco does.
Pruneman99
Pruneman99 is offline
PostPosted: Tue Nov 30, 2021 2:13 pm    Post subject: Re: Cam bearings ??? Reply with quote
Carcraft touched up my cam bearing saddles in a case that originally had cam bearings. I'm definitely no machinist, but I'd think they would use the same tool to cut the cases that didn't have cam bearings for them. They are in Riverside. You can give them a call.
splitlp
splitlp is offline
PostPosted: Thu Oct 06, 2022 6:02 am    Post subject: Re: Cam bearings ??? Reply with quote
Bumping this thread.
Has anyone found a shop still cutting 40HP cases for cam bearings?
Ojai63dbl
Ojai63dbl is offline
PostPosted: Fri Oct 07, 2022 1:56 pm    Post subject: Re: Cam bearings ??? Reply with quote
RIMCO / Fat Performance did it for me probably 5 years ago. Did you try Brothers Machine shop - I think they still do it
