Mike Sal Samba Member
Joined: May 28, 2014 Posts: 195 Location: Southern Illinois
Posted: Sat Oct 22, 2022 6:45 pm Post subject: Re: Kubelwagen Project |
You might find the kar is a little skittish at speed. Mine is. It was built by skunkwerks back in 2007 on a 1970 chassis. I added 50lbs of lead in the front end which helped. I'm a reenactor & made a lot of changes to mine to make it look more authentic (especially the fenders). I also re-did the suspension to gain the proper ground clearance as an original. These may not be as important to you. |
55rover Samba Member
Joined: December 25, 2015 Posts: 107 Location: Oklahoma
Posted: Sun Oct 23, 2022 7:30 am Post subject: Re: Kubelwagen Project |
Mike Sal wrote: |
Thanks Mike for the observations. I will have an extra fuel can on the front. I can experiment with either 30 lbs of fuel or 40 lbs of water to test out handling. I left off the German markings on this build. A little sensitive to the unknown destinations we will be visiting. You never know. |
mr white Samba Member
Joined: October 02, 2005 Posts: 1193 Location: beautiful Oregon & Mohave County, AZ
Posted: Tue Nov 22, 2022 5:55 pm Post subject: Re: Kubelwagen Project |
I just read this thread. I was skeptical at first. The end result in
My opinion looks great! Are you selling a kit or blue print with a parts list of materials and needed quantities to complete? Looks like fun. |
Posted: Tue Nov 22, 2022 8:51 pm Post subject: Re: Kubelwagen Project |
mr white wrote: |
Kubelkraft of Albuquerque is the manufacturerer. I was very surprised at the base level fabrication done on these replicas. Basically scratch built with square tubing and precut metal panels. Below is a photo of the pre assembly metal panels.
Posted: Sat Jan 07, 2023 7:26 am Post subject: Re: Kubelwagen Project |
The engine has shipped from MOFOCO.
- 1,600 dual port (biggest stock VW displacement)
- counter weighted crank (for smoothness and vibration)
- MOFOCO 041 heads (better cooling and slight performance increase)
- hydraulic lifters (never adjust them)
- Alternator upgrade (90 amp)
- Dual pulley serpentine belt (modern belt system)
- Remote filter (easy decision)
- Electronic ignition (no mechanical points or condenser)
- Weber progressive single carb (Extra 10-15 HP and higher RPM)
Link to video of first run: https://www.youtube.com/shorts/x_3dCnBwtSU |
Posted: Mon Jan 16, 2023 1:30 pm Post subject: Re: Kubelwagen Project |
Engine tin painted "special yellow" to match the Kubel.
germansupplyscott Samba Member
Posted: Mon Jan 16, 2023 3:26 pm Post subject: Re: Kubelwagen Project |
The mufflers are cool looking. Lots of work went into those I bet. _________________ SL |
Posted: Mon Jan 23, 2023 2:41 pm Post subject: Re: Kubelwagen Project |
Weber progressive problem
I guess in WWII they did not anticipate a dual throat carburetor with a large air box on top. Carb and airbox setup just a little to big to clear the engine bay door. Definitely not as spacious as a bus (or a type 1) engine bay. It is amazing what a cutoff grinder and metal patch can do. I think it turned out pretty good.
toxicavenger70 Samba Member
Posted: Mon Jan 23, 2023 2:53 pm Post subject: Re: Kubelwagen Project |
Amazing build!!!
Did I really read that it took almost 1.5 years to get that motor? If so I hope it is perfect. |
Posted: Mon Jan 23, 2023 2:58 pm Post subject: Re: Kubelwagen Project |
toxicavenger70 wrote: |
Amazing build!!!
Almost that amount of time for delivery. Kubel drive test report coming soon. |
Posted: Tue Jan 24, 2023 3:22 pm Post subject: Re: Kubelwagen Project |
55rover wrote: |
Amazing build!!!
Man that would be upsetting to deal with.
Well good luck with the test drive. |
Posted: Tue Feb 14, 2023 2:08 pm Post subject: Re: Kubelwagen Project |
Sunday, February 12 a very long auto transport delivered the Kubel. After much discussion and checking the paperwork it was determined that mine was the bottom vehicle. Some minor assembly will be required and road test next. Thinking there might have been some performance difference between the two vehicles.
Posted: Fri Mar 10, 2023 8:38 pm Post subject: Re: Kubelwagen Project |
Received vehicle mid February and it took a while to sort through the "some assembly required" parts of the Kubel.
- Top is not installed. Required sandwiching front edge into top frame, screwing down and using the leather slots and tabs for securing.
- Side windows - required dropping them into the two rod receptacles in each door and connecting in the center.
Minor issues
- turn signal switch on dashboard was reversed, quick fix.
- trailer connection had a mis wired right turn signal.
- stalled after driving for a bit. Fuel tank vent not working, pulling a vacuum and starving fuel to the engine. Quick fix, cut a slot in the gas tank cork gasket. Will investigate further.
Photos for interest. Tested the limited slip differential by climbing hills at an angle. Diff worked perfectly with a little throttle when slipping. Normal VW transaxle will just spin one tire. Full articulation did not result in any rubbing of the fenders.
Joe 20 Samba Member
Posted: Fri Mar 10, 2023 8:52 pm Post subject: Re: Kubelwagen Project |
I hope it's everything you were hoping for and serves you well. _________________ "Someday the world is gonna be populated by nothing but Volkswagens'" Corporal Klairvoy |
Posted: Tue May 30, 2023 4:43 pm Post subject: Re: Kubelwagen Project |
Unfortunately, the chassis wiring failed about 10 hours on the vehicle. I came in the next day the the fusible link on the battery had melted. The fused wire had a dead short to ground that could not be isolated and ran the full length of the chassis within the square tubing. Basically the wiring harness going from the back to the front was completely shorted. I could not remove the harness either from the front or back and had to rewire the car. Fortunately, It was only nine wires. Photos and comments below
Blown fusible link
Wiring harness completely grounded
New 16 and 10 gauge wire (Highly recommend https://4rcustomswire.com/ for high quality wire)
Marine 100a (generator) and 30a (main power feed) breakers. Note scorch marks on the left from the fusible link.
Routing inside passenger footwell (no other choice), back to battery then across the transaxle hump to the engine. Separated the high amperage (90a alternator) with the ignition, engine sensors and tail lights.
Added two 16 gauge and one 10 gauge spares bundled under the seat. I don't want to get back into the harness again if I don't have to.
