heyskull Samba Member
Joined: August 07, 2022 Posts: 170 Location: Cumbria, England
Posted: Fri Oct 21, 2022 10:54 am Post subject: Type 4 timing. |
My 1972 Westfalia has a 411/914 engine installed so although it has the degree guage their are no marks on the face of the fan wheel.
The bung where you time it on these vehicles had to be chisseled out as some very clever person had bonded it in.
On taking this out and with the aid of a video camera and a torch I rotated the engine to find the marks on the fan wheel.
After rotating it several times there is definitely no marks on it, or if there was they are no longer there.
How do I find TDC and 7.5 BTDC without any marks?
I have put a stick down number 1 cylinder but it does not touch anything.
Help as I am just having to guess the timing at the moment?
Thanks
SC |
busdaddy Samba Member
Posted: Fri Oct 21, 2022 11:46 am Post subject: Re: Type 4 timing. |
I am not sure about the mark is hard to see.
Can I remove all the bits to check this with the engine in situ?
SC |
Posted: Fri Oct 21, 2022 12:00 pm Post subject: Re: Type 4 timing. |
Yes, as long as you have access to the pulley on the fan you can find it. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
timvw7476 Samba Member
Posted: Fri Oct 21, 2022 12:37 pm Post subject: Re: Type 4 timing. |
heyskull wrote: |
SC |
The notch is actually like a shadow or cleft on the inside facing the timing scale on buses, & Ratwell's image of the 411 mark seems as though it's a faint stamping on the fan as well. I'd clean the fan to see better, then count five blades to the left of each mounting boss lug till I located 'the mark' .
My timing cleft has White-Out on it so no eye strain at tune up time. But even then it does get covered with road grit/grime & I have to hunt for it. |
Posted: Fri Oct 21, 2022 9:54 pm Post subject: Re: Type 4 timing. |
Use your fingernail or something like a butter knife to feel all along the forward rim of the pulley for the notch. it is tiny and can be quite hard to see. Once you find the notch or make one according to Ratwell you will need a timing scale to use in conjunction with it. |
Posted: Sat Oct 22, 2022 9:39 am Post subject: Re: Type 4 timing. |
I have spent all day on this.
I measured TDC with the 42mm from the screw only to find a mark there already.
I have moved the plug leads around on the distributor cap. But it still is not timing up properly.
Does anyone have a picture of the rough positioning and where each plug leads go to?
Thanks
SC |
Posted: Sat Oct 22, 2022 9:54 am Post subject: Re: Type 4 timing. |
heyskull wrote: |
Thanks
SC |
The mark works with a timing scale, if your scale is missing you can not time your engine using the "v" mark. Timing scales are available through various vendors in either plastic or metal. The stock plastic scale has proven very durable and accurate, don't know about the aftermarket plastic ones, while some of the metal ones are not known for being accurate. |
Posted: Sat Oct 22, 2022 10:05 am Post subject: Re: Type 4 timing. |
[quote=
The mark works with a timing scale, if your scale is missing you can not time your engine using the "v" mark. Timing scales are available through various vendors in either plastic or metal. The stock plastic scale has proven very durable and accurate, don't know about the aftermarket plastic ones, while some of the metal ones are not known for being accurate.[/quote]
I have a timing scale fitted just no marks on the wheel.
SC |
Posted: Sat Oct 22, 2022 10:20 am Post subject: Re: Type 4 timing. |
heyskull wrote: |
.........I measured TDC with the 42mm from the screw only to find a mark there already...... |
OK, so what's the problem then?, sounds like you found the mark. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Oct 22, 2022 10:40 am Post subject: Re: Type 4 timing. |
[quote="busdaddy"]
heyskull wrote: |
OK, so what's the problem then?, sounds like you found the mark.[/quote
I need a picture of the rough positioning and where each plug leads go to?
Something is not in the correct position.
Thanks
SC |
Posted: Sat Oct 22, 2022 10:49 am Post subject: Re: Type 4 timing. |
If the engine runs even moderately strong and doesn't back fire your plug wires are likely correct.
What wheel do you not have a mark on? |
Posted: Sat Oct 22, 2022 11:22 am Post subject: Re: Type 4 timing. |
Wildthings wrote: |
I have ameasured the mark onto the alternator belt wheel and a scale held on the fan mesh cover.
SCREEN |
Posted: Sat Oct 22, 2022 11:35 am Post subject: Re: Type 4 timing. |
The lead to #1 cylinder goes on whatever terminal in the cap the rotor points at when at firing TDC, the rest follow in a clockwise direction, 1-4-3-2.
Finding firing TDC is not just lining up the mark, you also have to confirm cylinder #1 is making compression on the stroke leading up to TDC. You can feel for compression, or watch the valves on #3 cylinder when at TDC, when they are both moving as you rock the engine back and forth it's at #1 TDC.
Or just stab the wires in at the first TDC you find, it'll either un, or backfire and kick, if it doesn't run move all the wires 180 degrees in the cap. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Oct 22, 2022 11:45 am Post subject: Re: Type 4 timing. |
heyskull wrote: |
Wildthings wrote: |
SCREEN |
Will your engine run or not? Put some paint or fingernail polish on your "v" so you can see it easily. The cylinder numbers are stamped on the tin, though not so easy to see due to all the wires and hoses.
busdaddy wrote: |
Or just stab the wires in at the first TDC you find, it'll either un, or backfire and kick, if it doesn't run move all the wires 180 degrees in the cap. |
I need a picture of where the rotor arm should roughly be at TDC.
When trying to time it, the marks are way off
SC |
Posted: Sat Oct 22, 2022 11:50 am Post subject: Re: Type 4 timing. |
heyskull wrote: |
busdaddy wrote: |
SC |
At TDC the rotor needs to be pointing to one of the towers. Put the #1 wire on that tower and then install the other 1-4-3-2 in a clockwise direction. If it will not try to run swap all the wires 180° around the cap. |
dodger tom Samba Member
Joined: March 25, 2013 Posts: 1272 Location: Central Coast, CA, but we're all still Ukrainian
Posted: Sat Oct 22, 2022 12:14 pm Post subject: Re: Type 4 timing. |
heyskull wrote: |
When trying to time it, the marks are way off SC |
search is your friend. pick one.
https://www.thesamba.com/vw/forum/album_search.php...t_dir=DESC _________________ 1978 Champaign Edition 2 Westfalia
Would never find the time to keep up another classic air-cooled. |
Posted: Sat Oct 22, 2022 12:19 pm Post subject: Re: Type 4 timing. |
So what you are saying number 1 TDC can be anywhere.
I am only asking for roughly where most type 4 distributor is set for TDC?
SC |
Posted: Sat Oct 22, 2022 12:30 pm Post subject: Re: Type 4 timing. |
heyskull wrote: |
SC |
no, you asked for a picture and i found some.
looking at them myself, i can see they are not clear.
on my type iv the rotor points at #1 plug wire at tdc.
i’m no expert, but isn’t that universal? _________________ 1978 Champaign Edition 2 Westfalia
