busdaddy Samba Member
Joined: February 12, 2004 Posts: 51129 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Dec 19, 2022 11:56 am Post subject: Re: Type 4 timing. |
Oil cooler, cooler seals or even the gasket between the oil filter mount and the case. There's also a number of gallery plugs in that area that like to get loose.
But first start at the very top, the oil pressure sender is often to blame. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Dec 19, 2022 12:33 pm Post subject: Re: Type 4 timing. |
The Type 4 oil pressure switches are pretty well hidden down in a well, and are notorious for failing. The type 4 switch has tapered pipe threads while the Type 1 switch has straight threads and uses a sealing ring, so make sure you get the correct one. If you are unfamiliar with pipe threads in general, look the tightening spec up in the Bentley. IIRC it takes a 24mm deep socket (15/16" also works fine) to change it. |
75 Westy FI noob Samba Member
Joined: November 04, 2022 Posts: 330 Location: MidWest
Posted: Wed Dec 21, 2022 1:22 pm Post subject: Re: Type 4 timing. |
This raises the question of … the Tins.
Can they be (easily)removed from a FI Type 4 with the engine in?
Or do the plenum and intakes need to come off first?
I think the oil pressure sender is under the tin.
I really don’t wanna pull the engine / trans out. |
dodger tom Samba Member
Joined: March 25, 2013 Posts: 1267 Location: Central Coast, CA, but we're all still Ukrainian
Posted: Wed Dec 21, 2022 1:32 pm Post subject: Re: Type 4 timing. |
[quote="75 Westy FI noob]I think the oil pressure sender is under the tin.
I really don’t wanna pull the engine / trans out. [/quote]
you don’t need to remove tins. the switch is behind the distributor. just pull the wire, and use a socket to loosen the switch.
_________________ 1978 Champaign Edition 2 Westfalia
Would never find the time to keep up another classic air-cooled. |
Posted: Wed Dec 21, 2022 4:00 pm Post subject: Re: Type 4 timing. |
As Tom states the sender doesn't require tin removal to look at or replace, if it's oily down in there shoot some degreaser in there and blast it with the hose (don't drown the distributor on the way in), if it's oily again in a few days you might have found the issue.
If it's dry your next bst option may be to pull the fan shroud, you can clean it up and run it without the shroud a few minutes in the driveway and see where the oil originates. It may be worthwhile anyways if it's been sitting, rodents like to move in and you may find a few of their homes. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Dec 21, 2022 4:10 pm Post subject: Re: Type 4 timing. |
Thanks! |
Posted: Wed Dec 21, 2022 6:52 pm Post subject: Re: Type 4 timing. |
ps: I Hate the tins. Imagine dropping that nut in that hole. They made intalling the head temp sensor ridiculously difficult. Caused me to cross thread a spark plug while Removing it…. Nightmares.
I guess removing the fan shroud would grant some access to retrieve lost bits.
I need to check btw the jugs for nests…. |
Posted: Wed Dec 21, 2022 7:19 pm Post subject: Re: Type 4 timing. |
i’m with you, man. i dropped #2 spark plug on top of the cylinders once. took me an hour to fish it out.
mindfulness is your friend when working on a type iv engine. firm grasp. eyes on the prize. then, you’ll only drop some stuff down into the tins. _________________ 1978 Champaign Edition 2 Westfalia
timvw7476 Samba Member
Posted: Wed Dec 21, 2022 9:27 pm Post subject: Re: Type 4 timing. |
dodger tom wrote: |
mindfulness is your friend when working on a type iv engine. firm grasp. eyes on the prize. then, you’ll only drop some stuff down into the tins. |
Autozone sells a great sparkplug socket, magnetized. Holds the plug with just enough power. Bought that decades ago, no more drops, no more silly foam left around the insulator when the cheap foam lets go from the socket. Think they are called 'power something' - Blue stripe around the edge. Great socket.
And a magnetic wand to fish out all the other previous owner's plug 'drops' too.
EDIT: POWERBUILT, think that's the name. AZ brand? who knows. |
my59 Samba Member
Joined: August 13, 2003 Posts: 3791 Location: connecting the dots
Posted: Wed Dec 21, 2022 11:41 pm Post subject: Re: Type 4 timing. |
I have a rubber sleeve gizmo gifted by a friend. You fit the plug in one end, and it is long enough so you can reach in and get the spark plug hand started before you put a socket on it.
When I pulled the bus engine the first time there were 2 spark plugs and a socket lying under the tins. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
Posted: Thu Dec 22, 2022 12:07 am Post subject: Re: Type 4 timing. |
Changing the oil pressure switch with the tin installed is easy enough, but the need to use a 24mm socket to remove and install it means you are likely going to be using a 1/2" drive ratchet which can easily apply way too much torque to the small diameter (10mm) pipe fitting where the switch screws into the block. Snap it off or worse crack the block and you have big problems.
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3566 Location: viroqua wi.
Posted: Thu Dec 22, 2022 12:10 am Post subject: Re: Type 4 timing. |
my59 wrote: |
When I pulled the bus engine the first time there were 2 spark plugs and a socket lying under the tins. |
My gizmo is 6 inch's of fuel hose. |
Posted: Thu Dec 22, 2022 12:35 pm Post subject: Re: Type 4 timing. |
Good tip Wild Things… will try and remember not to crank it too hard.
I have a spark plug socket w a rubber grommet in it, causes the socket to stick firm, then the grommet stays on. So, when i was taking it out, I didn’t put it all the way on, just shy about 20%. Well, that was enough for the socket to be too tall to clear the tin. But it was the last 3 threads or so and i didnt even feel it.
Other than that goof, I’ve only dropped the heater fan fuse down in the tins. Been careful as i can. |
cellobus1 Samba Member
Joined: June 10, 2014 Posts: 284 Location: East Tennessee
Posted: Sat Dec 24, 2022 11:16 am Post subject: Re: Type 4 timing. |
I’m reading through this thread and remembering a time when I was changing spark plugs on a type IV and one of them slipped out of of the socket. I made the mistake of trying to fish out the plug with my fingers. I think it was cylinder 3 which looks like it’s an easy reach. DO NOT ever stick 2 fingers in a spark plug tin hole, you will be sitting there a long time trying to get them out, or you will flense them to a bloody mess if you’re in a hurry. _________________ 1976 unrestored daily driver Standard bus, "Stella"
formerly, 1959 Standard bus
formerly, 1973 transporter which was 4 years old when it taught me to drive |
Posted: Thu Dec 29, 2022 12:57 pm Post subject: Re: Type 4 timing. |
Got my timing scale from Busted Bus …
Big red dot at 5 atdc.
But, I should actually set timing at 7.5 btdc …is that correct ?
Found idle screw info in my Bentley manual.
Gonna start it again today.
70 degrees in late December? I’ll take it. The Good Lord know I wanna work on the bus.
Posted: Thu Dec 29, 2022 2:09 pm Post subject: Re: Type 4 timing. |
Disregard the dot, that's for a different distributor, yours should idle ~7.5* BTDC. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Dec 29, 2022 2:58 pm Post subject: Re: Type 4 timing. |
75 Westy FI noob wrote: |
But, I should actually set timing at 7.5 btdc …is that correct ? |
The best timing for these old worn rigs is going to be 28° BTDC at 3800+ rpms, hose(s) off. This should give you a timing at base idle of around 7.5° BTDC, hose(s) off. You can see that someone has marked 28° on your fan shroud.
The white mark on your pulley pretty much aligned with the 0° mark on your timing scale is the correct mark, don't know what the mark in the pulley far to the left is, so just ignore it. |
Posted: Thu Dec 29, 2022 3:22 pm Post subject: Re: Type 4 timing. |
Thanks guys… I’ll put the notch at 7.5 btdc and see how she does.
I have an aftermarket dist.. no vacc lines on it.
That big shiny mark to the left was mde by yours truly, trying to do it by valve position. I was off a bit.
Glad I found the notch. haha |
Posted: Mon Jan 16, 2023 8:23 am Post subject: Re: Type 4 timing. |
busdaddy wrote: |
If it's dry your next bst option may be to pull the fan shroud, you can clean it up and run it without the shroud a few minutes in the driveway and see where the oil originates. It may be worthwhile anyways if it's been sitting, rodents like to move in and you may find a few of their homes. |
Ok, so i've got the tins off, the fan off, and the 4 nuts off the shroud... now comes the fun part of pulling it off. But the dipstick tube looks like an accident waiting to happen.. as it passes through the shroud. Does that need to be removed first? Also, I'm assuming this can be lifted out without removing the heat exchange/exhaust.. right?
i searched a bit, and some say the engine should be out for this bc it cant raise high enough to clear the cooler.. Bently doesnt mention the dipstick or removing the engine. It also doesnt mention disconnecting the alternator wires (access?) but that obv needs to happen.
Ready to pull shroud off.. but dont want to #$%^ it up.
edit: found tis regarding dipstick.. so it's part of the shroud. wonder how it fits at the back.. hmmm.
https://www.thesamba.com/vw/forum/viewtopic.php?t=776002&highlight=fan+shroud+remove |
Posted: Mon Jan 16, 2023 9:39 am Post subject: Re: Type 4 timing. |
Pulling the shroud is a PITA. You kind of have a choice as to which way you go at it. You can pull the heat exchangers, which means pulling the entire exhaust, or you can remove the 4 studs that hold the fan shroud to the block and lift the fan shroud up out of the heat exchangers. There are a few other tricks that were done when these things were new and it was expected they would be junked within a half dozen years, but most don't want to damage rare expensive parts today. |
