2type2 Samba Member
Joined: June 02, 2002 Posts: 969 Location: SW Colorado
Posted: Mon Oct 31, 2022 3:18 pm Post subject: Alternative wiring my garage ceiling heater question |
Looking to install a 240V/7500W ceiling mounted garage heater,( Comfort Zone $150)but avoid the cost/job of hard wiring. Is there any reason I should not just use an 8awg 3wire w/ NEMA6 - 50P plug, 20 ft. welder extension cord--- wired into the heater and plugged into my 50 Amp welder -designated plug in my garage? I figure I will only be running this heater for 2-4 hours at a time, just to make the garage tolerably warmer whilst I fiddle around.
I found a 20 ft cord for $67, and from what I am told it is about $300 to wire heater directly to panel.So I would prefer to just plug in as needed.Any caveats? _________________ "A life of peace and happiness depends on your own gratefulness" |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22568 Location: NYC/Upstate/ROW
Posted: Mon Oct 31, 2022 3:26 pm Post subject: Re: Alternative wiring my garage ceiling heater question |
8 gauge , 30 Amp , 25 foot run.
Plenty of margin. Is that connector ok for use or is it designed for semi-permanent use? _________________ .ssS! |
2type2 Samba Member
Posted: Mon Oct 31, 2022 3:39 pm Post subject: Re: Alternative wiring my garage ceiling heater question |
Which connector? The outlet on wall is installed just below the panel. The cord will have one end cut off. Not sure of total amps drawn by heater. So, good to go? _________________ "A life of peace and happiness depends on your own gratefulness" |
Posted: Mon Oct 31, 2022 3:56 pm Post subject: Re: Alternative wiring my garage ceiling heater question |
The wire is fine for the amperage but many high amperage connectors are not rated for “ household “ use, like daily connects or disconnects.
Also , local codes often don’t allow heavy gauge wire to be loose like a cord. I know nothing about your local codes. _________________ .ssS! |
2type2 Samba Member
Posted: Mon Oct 31, 2022 4:10 pm Post subject: Re: Alternative wiring my garage ceiling heater question |
Thanks for the advice Abscate. I will only be using it occasionally. _________________ "A life of peace and happiness depends on your own gratefulness" |
