Sweetbabyjane1 Samba Member
Joined: September 06, 2021 Posts: 45 Location: Windsor, Ontario
Posted: Tue Nov 01, 2022 7:10 am Post subject: To vacuum or not to vacuum |
We are now at the point in the restoration of the engine, of rebuilding my vacuum advance distributor. It was pretty dirty inside. And the question came up, because some of the parts inside didn't look right, should I rebuild or get a new or rebuilt distributor? And what one would work best with my stock 36hp engine? I have seen different posts in regards to dead spots with acceleration and ones talking about fuel economy. I do not have electronic ignition, and have no desire to install one, as my car did not have one when she was made. So the question is.... should I use a 010 style distributor, or a vacuum advance distributor? |
D. Haviland Samba Member
Joined: October 30, 2009 Posts: 536 Location: Burlington, Vermont
Posted: Tue Nov 01, 2022 7:20 am Post subject: Re: To vacuum or not to vacuum |
My totally stock 57 runs a stock vacuum advance distributor. I never have flat spot issues. It's 6-volt and runs points. Ed Fall in Utah does an excellent job rebuilding distributors, carbs, and fuel pumps. Vintage Werks. |
Posted: Tue Nov 01, 2022 7:26 am Post subject: Re: To vacuum or not to vacuum |
I guess I haven't spoken to Ed in a while. He now lives in Washington state. |
pig-pen Samba Member
Joined: December 04, 2012 Posts: 570 Location: United Kingdom
Posted: Tue Nov 01, 2022 8:55 am Post subject: Re: To vacuum or not to vacuum |
having recently been through fitting an 019, and an 010 to my 36hp with a supercharger... I can absolutely confirm that going back to the vacuum (which I thought would never work with the charger) has made the car totally drive-able.
With the 010 and the 019 it was a total pig. Now it is a joy. Vacuum. 100% _________________ 1954 L227 Type 113
1964 L31 Type 265 |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6609 Location: Houston, Texas
Posted: Tue Nov 01, 2022 1:08 pm Post subject: Re: To vacuum or not to vacuum |
For the stock engine go with the stock distributor. _________________ www.vwnos.com [email protected]
Posted: Tue Nov 01, 2022 1:40 pm Post subject: Re: To vacuum or not to vacuum |
Vacuum it is!
My husband cleaned the old one all up, and it looks and mechanically functions great. He love to tinker with things. Though we are not sure the canister is working properly. Blowing into the canister you can hear a click. But not when a suction is applied. Is this right? Or am I looking at a new canister/distributor. It isn't the original distributor that I can tell. It looks just like the least expensive vacuum advance one on CIP1. |
heimlich VWNOS.com
Posted: Tue Nov 01, 2022 1:45 pm Post subject: Re: To vacuum or not to vacuum |
[quote="heimlich"]This is what your vacuum canister should look like:
https://www.thesamba.com/vw/classifieds/detail.php?id=2269287
Yes, if I had a Bosch distributor, but mine is not a Bosch. I think it is a no name distributor. To replace the canister would cost more than the distributor itself I think. |
Posted: Tue Nov 01, 2022 1:48 pm Post subject: Re: To vacuum or not to vacuum |
this is what I have right now |
ecallaway Samba Member
Joined: April 14, 2020 Posts: 164 Location: Encinitas, California
Posted: Tue Nov 01, 2022 11:11 pm Post subject: Re: To vacuum or not to vacuum |
If you were to decide you want to spring for a close to original distributor I would recommend getting in touch with tasb.
https://www.thesamba.com/vw/forum/profile.php?mode=viewprofile&u=3066
He does not have an ad posted currently but when he rebuilt one for me a couple years ago he wrote that he still had about 100 cores. I am very happy with the VJU 4 BR 8 that he built for me. He says that these distributors are hybrid mechanical and vacuum advance. "SVDA distributor with advance weights inside." "The mechanical advance is delivering a full 16 degrees of advance while the vacuum canister is delivering 12 degrees. You will find that the static timing will be closer to 5 degrees BTDC not to exceed 32 degrees at full throttle." |
Posted: Tue Nov 01, 2022 11:21 pm Post subject: Re: To vacuum or not to vacuum |
Just noticed that heilmlich's pics were from active listings that they have posted. These look really nice. |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Wed Nov 02, 2022 4:45 am Post subject: Re: To vacuum or not to vacuum |
The VJU4BR8 uses the same mechanical advance curve as the 010, with the addition of the vacuum advance. The advance spring tension is adjustable (little screw under the cap). _________________ modok wrote:
heimlich VWNOS.com
Posted: Wed Nov 02, 2022 10:52 am Post subject: Re: To vacuum or not to vacuum |
Sweetbabyjane1 wrote: |
Do you have the one in your hand or in the picture off the website? Neither one would be correct for your 36HP engine with the stock carburetor. The vacuum signal pulling would be incorrect for the vacuum canister. It might work but not as intended which could be good or bad.
The distributor that is in your hand is a very good distributor for a 1600CC and up engine. It is desirable.
You can pick up a used VJU4BR8 and rebuild it or you can buy one already rebuilt. _________________ www.vwnos.com [email protected]
Posted: Wed Nov 02, 2022 1:34 pm Post subject: Re: To vacuum or not to vacuum |
I do have a VGUR4 BR8 distributor in hand. It came with the car, but not mounted. We suspect it is missing a few pieces. ie. bearing and dust cap, and that is why it wasn't on the car when we got it. Husband is tinkering with that now. We have the red capped one mounted for now, but will switch to the BR8 when that one is rebuilt. Finding parts is, at the least, frustrating. |
heimlich VWNOS.com
Posted: Wed Nov 02, 2022 7:28 pm Post subject: Re: To vacuum or not to vacuum |
I do have a VGUR4 BR8 distributor in hand. Finding parts is, at the least, frustrating. |
I have all the parts. New vacuum canister, new shafts, shim kits, fiber washers, etc. _________________ www.vwnos.com [email protected]
j-dub Samba Member
Joined: November 09, 2003 Posts: 865 Location: Phoenix, AZ
Posted: Wed Nov 02, 2022 8:09 pm Post subject: Re: To vacuum or not to vacuum |
+1 in support of using he VJUR4 BR8, it is one of my favorite. _________________ 1957 Oval rag
"POLICE STATION TOILET STOLEN ... Cops have nothing to go on." |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4572 Location: St Charles, MO
Posted: Thu Nov 03, 2022 8:56 am Post subject: Re: To vacuum or not to vacuum |
+2! I totally agree with the above posters. Get a good "correct" 36hp vacuum advance distributor and have any one of several guys out there (Ed Fall, "tasb" Heimlich, etc) properly go through it to get it rebuilt and you will be very happy in the end. A properly rebuilt and running VJUR4 BR8 vacuum advance distributor will make your 36hp engine VERY happy!
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Thu Nov 03, 2022 9:31 am Post subject: Re: To vacuum or not to vacuum |
Been following along and have to finally chime in.
+3 on the above line of thinking. The vacuum signal is for load. A street car requires this for smooth, reliable, and predictable running! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Kjell Roar Samba Member
Joined: December 08, 2008 Posts: 1326 Location: Norway
Posted: Tue Nov 08, 2022 2:22 am Post subject: Re: To vacuum or not to vacuum |
esde wrote: |
The VJU4BR8 uses the same mechanical advance curve as the 010, with the addition of the vacuum advance. The advance spring tension is adjustable (little screw under the cap). |
Not the 010, but the 019 / VJ4BR8 curve.
The vacuum canister help save some fuel fuel & let the engine run a little cooler.
And smoothen the ignition curve when driving. _________________ I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438 |
Posted: Mon Nov 21, 2022 5:14 pm Post subject: Re: To vacuum or not to vacuum |
The Hubby got the BR8 rebuilt! I am excited to have her on the car!
Your knowledge has been awesome! Thanks so much! |
