KillerGriller Samba Member
Joined: June 15, 2022 Posts: 52 Location: Ontario, Canada
Posted: Fri Nov 04, 2022 11:09 am Post subject: 1995 Eurovan CV - Axle Shaft w/ CV Joint and Boot Replacement |
Hi all,
During an oil change I noticed that the passenger CV boot was torn, and most of the auto-knowledgable folks I talked to recommended replacing the axle shaft/CV joint/boot while I was in there instead of replacing only the boot.
From what I've read on here (and other sites) it "should" be a pretty straight-forward part swap, and take about an hour? I'm trying to budget what little good weather we have left this year, barring any unforeseen catastrophe, does that sounds reasonable?
Any steps or items to be aware/take note of?
Cheers |
Saturn Samba Member
Joined: April 06, 2019 Posts: 192 Location: San Francisco
Posted: Fri Nov 04, 2022 12:03 pm Post subject: Re: 1995 Eurovan CV - Axle Shaft w/ CV Joint and Boot Replacement |
KillerGriller wrote: |
Hi all,
Here is a posting covering my experience in replacing passenger side transaxle on my 1995 EVC. The one unexpected issue I ran into was having to remove the ABS tone ring. (Thought I had ordered one for a non-ABS set up.)
https://www.thesamba.com/vw/forum/viewtopic.php?t=757480
1994Karuso Samba Member
Posted: Fri Nov 04, 2022 1:26 pm Post subject: Re: 1995 Eurovan CV - Axle Shaft w/ CV Joint and Boot Replacement |
https://www.youtube.com/watch?v=hoo2VdSIFVI
Outer CV joint and boot -- avoids dealing with the inner joint. |
TheOneTrueQuux Samba Member
Posted: Mon Nov 07, 2022 9:33 am Post subject: Re: 1995 Eurovan CV - Axle Shaft w/ CV Joint and Boot Replacement |
Hi all,
Cheers |
I have a conditional disagreement here. Some of the aftermarket axles, particularly the "rebuilt" ones are of questionable quality. If the boot is only recently torn, and the joint still has grease, and isn't full of road debris, replacing the boot makes a lot of sense. If it's full of road grime, or is making weird noises, then absolutely replace it. |
Posted: Mon Nov 07, 2022 12:24 pm Post subject: Re: 1995 Eurovan CV - Axle Shaft w/ CV Joint and Boot Replacement |
@Saturn - I saw your post earlier, but you never know who's still lurking about or not Thanks for posting that.
The initial tear I found on the inner CV boot, but I've since found one on the outer boot as well. I think I'm going to go the same route you did and replace the entire transaxle/joints/boots at once. How was easy/difficult to mount it to the transmission?
Also, is the "passenger side" considered the right or left side
Saturn wrote: |
Hi all,
Thanks, I subscribed to his channel. |
Posted: Mon Nov 07, 2022 12:28 pm Post subject: Re: 1995 Eurovan CV - Axle Shaft w/ CV Joint and Boot Replacement |
TheOneTrueQuux wrote: |
I don't think the tear in the inner boot is recent, but the one in the outer boot is newer. The inner boot looked to have debris in it, no weird noises yet though |
Saturn Samba Member
Posted: Wed Nov 09, 2022 10:14 am Post subject: Re: 1995 Eurovan CV - Axle Shaft w/ CV Joint and Boot Replacement |
Make sure you have the correct triple square socket (M10) for removing the six bolts. This is what I ordered from Amazon for this operation: https://www.amazon.com/gp/product/B08D3D4ZGN/
Access to the bolts not a problem, thought you might need to clean out the bolt heads if they are extremely dirty/greasy. I initially loosened two at a time then rotated the assembly to get to the next pair. This was from the front side allowing for the most perpendicular purchase into the bolt head, and not at an angle. A 3/8" extension was used and removed each of them by a ratchet not with something like an impact gun. Reassembly is pretty straight-forward, the mounting bolts were first installed by hand until finger tight and then torqued down. Again this was working on a couple at a time then rotating the axle to get to the next ones.
Passenger side = right side Well, unless I was working on a RHD vehicle.
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2797 Location: North Carolina
Posted: Wed Nov 09, 2022 10:19 am Post subject: Re: 1995 Eurovan CV - Axle Shaft w/ CV Joint and Boot Replacement |
Mike Rule #1 about CV replacement is there is no such thing as too much grease in the joint. Mike Rule #2 is pre-assembled axles don't ship with enough grease. If you buy pre-assembled axles, get extra grease and pack them more. It should be a plain moly-type CV axle grease in the assembly and you can add same. At least, that's my limited experience. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
Posted: Thu Nov 10, 2022 7:54 am Post subject: Re: 1995 Eurovan CV - Axle Shaft w/ CV Joint and Boot Replacement |
mikemtnbike wrote: |
Mike Rule #1 about CV replacement is there is no such thing as too much grease in the joint. Mike Rule #2 is pre-assembled axles don't ship with enough grease. If you buy pre-assembled axles, get extra grease and pack them more. It should be a plain moly-type CV axle grease in the assembly and you can add same. At least, that's my limited experience. |
Yeah, there is such a thing as too much grease. If you put too much, it puts outward pressure on the boot, and if you're lucky, it'll spew out at the clamped end, which is a mess. If you're not, it'll lead to the rupture of the boot. You want the inner volume of the joint packed solid, and a bit more in the boot. The service manual will tell you how much to use if you're starting from empty. |
Posted: Thu Nov 10, 2022 8:42 am Post subject: Re: 1995 Eurovan CV - Axle Shaft w/ CV Joint and Boot Replacement |
I think what's most important is that the part you buy hasn't been mislabeled and/or put in the wrong box...
Good thing I checked this in depth before pulling the van apart. For those of you who aren't familiar with these, the transmission end should have a flange with bolt holes that you bolt directly to the transmission instead of the cylinder bit on the right (with the sticker on it).
Supposed to be getting a proper replacement this afternoon, but we'll see what happpens |
Posted: Thu Nov 10, 2022 8:54 am Post subject: Re: 1995 Eurovan CV - Axle Shaft w/ CV Joint and Boot Replacement |
Yes thanks for clarification that I was talking about "in the joint." That's what I was referring to, the inner volume, the specificity is appreciated. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
