bsairhead Samba Member
Joined: October 08, 2008 Posts: 3564 Location: viroqua wi.
Posted: Wed Nov 09, 2022 9:38 pm Post subject: Re: ACVW Front Engine Rear Drive Ideas |
vwinnovator wrote: |
bsairhead wrote: |
Just spitballing. Use the whole kit and caboodle in the front. Flip the transaxle upside down sprockets instead of drive shafts chains to the rear. Old Mack Truck style. |
what about the shift patten?
It would be upside down / opposite |
You would figure it out. My old Moto Guzzi had a learning curve. |
sub-hatchtim Samba Member
Joined: September 19, 2006 Posts: 2610 Location: Phoenix AZ
Posted: Thu Nov 10, 2022 12:38 am Post subject: Re: ACVW Front Engine Rear Drive Ideas |
I'm pretty baffled why you'd want to
But why not just use a subaru trans _________________ 58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S |
Slow 1200 Samba Member
Posted: Thu Nov 10, 2022 6:33 am Post subject: Re: ACVW Front Engine Rear Drive Ideas |
how about a 924/944 transaxle? |
rayjay Samba Member
Joined: March 26, 2008 Posts: 1506 Location: Buford GA
Posted: Thu Nov 10, 2022 7:14 am Post subject: Re: ACVW Front Engine Rear Drive Ideas |
Anybody that has seriously contemplated this idea is trying to divorce themselves from the limitations of transaxles. |
vwinnovator Samba Member
Joined: July 11, 2005 Posts: 1555 Location: Still doing it in the back of your VW
Posted: Thu Nov 10, 2022 7:31 am Post subject: Re: ACVW Front Engine Rear Drive Ideas |
rayjay wrote: |
I did it because I got tired of breaking ring and pinions, axles, etc...
cost a lot of time and money...
It's nice to have drivetrain thats been rated 1000hp plus |
rayjay Samba Member
Posted: Thu Nov 10, 2022 8:47 am Post subject: Re: ACVW Front Engine Rear Drive Ideas |
rayjay wrote: |
Not to mention the loss of entry fees, tow gas, lodging if applicable, and the emotional letdown of losing because of parts breakage. Inevitable parts breakage.
The NHRA was televising fwd drag racing in the early 2000s and bye runs were common due to driveline failure even with the high dollar stuff those guys were running.
What got my mind going on streetable manual trans set ups was a Summit catalog. Super T10s and T5 trannies are around $2200. These would be almost bulletproof behind the vast majority of streetable ACVWs. An 8” Ford rearend would be a good compromise between strength and weight. |
Dusty1 Samba Member
Posted: Thu Nov 10, 2022 11:17 am Post subject: Re: ACVW Front Engine Rear Drive Ideas |
sub-hatchtim wrote: |
But why not just use a subaru trans |
When you fall down that rabbit hole you'll find a full- on Subi transaxle costs around $8k. The DIY version costs around $2k.
The next logical move it to use the Japanese flat four. Don't tell Spock you're tryin' to adapt an ACVW, it ain't logical.
The Subaru transaxles are reliable up to 300hp. They'll handle almost 600hp as long as your baby your 600hp bomb.
You can get Type 2 and 930 axles, stubs and flanges to fit Subaru. Kinda tells you what the Subarugears people had in mind.
Slow 1200 wrote: |
Best idea here! Now I'm lookin' for a thrashed 924...
Old Alphas had engine in the front, transaxle in the back.
Wait! Wait! I got it!
Corvair transaxle?
Eldorado / Toronado / Riviera transaxle. Just push the whole powertrain straight back. It's kinda wide. A bandsaw and / or a lathe plus a little welding might help that.
Posted: Thu Nov 10, 2022 11:29 am Post subject: Re: ACVW Front Engine Rear Drive Ideas |
I've actually seen it done
Years ago at the chirco show in Tucson guy had a type 4 powered front engine awd "subie" super beetle
Now that I think of it someone brought down a blue beetle with a similar treatment, I think it was a rally car from Colorado _________________ 58' pg/sg silo fridge westy
76 911S |
Dusty1 Samba Member
Posted: Thu Nov 10, 2022 3:26 pm Post subject: Re: ACVW Front Engine Rear Drive Ideas |
Now that I think of it someone brought down a blue beetle with a similar treatment, I think it was a rally car from Colorado |
If you're goin' 4WD you might as well buy an STi and be done with it. What I'm talkin' about is a 2WD converted WRX transmission. There's a flipped ring gear available and a trick part that locks out the 4WD. Looks like an oversized split case VW transmission when it's done. With 930 flanges and little stubby Sway-a-Way axles.
I've done two VW / Subaru conversions this year in my spare time. If the suck of all suck "supply chain issues" continue I'm going to omit the VW entirely next time. Parts availability is makin' this enthusiast considerably less enthusiastic.
Posted: Thu Nov 10, 2022 6:45 pm Post subject: Re: ACVW Front Engine Rear Drive Ideas |
Yup I'm aware
Those boys down under do them for the vanagon crowd _________________ 58' pg/sg silo fridge westy
76 911S |
RickS Samba Member
Posted: Thu Nov 10, 2022 8:37 pm Post subject: Re: ACVW Front Engine Rear Drive Ideas |
Kawell Black Moon Rising. One of the first front engine cars. Saw it at Atco in the mid 90’s. I seem to remember they used a Liberty transmission.
Posted: Fri Nov 11, 2022 12:03 am Post subject: Re: ACVW Front Engine Rear Drive Ideas |
There's this monster
Engines by fish of Doug's bugs and bunnies in mesa az
https://youtu.be/_lz6Q30Mxtg _________________ 58' pg/sg silo fridge westy
76 911S |
Dusty1 Samba Member
PBR Allstar Samba Member
Joined: November 24, 2005 Posts: 3 Location: Sonoma, Ca.
Posted: Thu Nov 24, 2022 6:12 pm Post subject: Re: ACVW Front Engine Rear Drive Ideas |
Why not use a bus Bellhousing and then make an adapter plate to use something like a t5 behind it? That way you may have to do a little work as far as pilot bearing and clutch disc, but pressure plate, release bearing, clutch linkage, and starter should all be very simple. |
rayjay Samba Member
Posted: Fri Nov 25, 2022 1:31 pm Post subject: Re: ACVW Front Engine Rear Drive Ideas |
PBR Allstar wrote: |
2nd paragraph post #1 |
rayjay Samba Member
Posted: Sat Nov 26, 2022 7:29 am Post subject: Re: ACVW Front Engine Rear Drive Ideas |
In researching manual transmissions I have found that for T5s some of the 4 cylinder versions have a .86 od ratio that would work the best for our purposes. In this chart the D and E first through fourth ratio sets that have the .86 od might be the best bets.
The 4 cyl T5 input shafts have smaller pilot brg shanks and smaller dia clutch disc splines than the v8 trans.
http://www.britishv8.org/Articles/Borg-Warner-T5-ID-Tags.htm |
