VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9960 Location: Huntington Beach, CA
Posted: Thu Nov 10, 2022 9:10 am Post subject: Re: Engine dies at stops with clutch pedal depressed |
Curious.
Go to the back of the car. Open the decklid. Grab the crank pulley with 2 hands, tightly. Then try to push it into the case, followed by pulling it out of the case. Try a few times and use some forcefulness in moderation to check it with. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
doug bugg Samba Member
Joined: March 08, 2003 Posts: 349 Location: Minneapolis
Posted: Thu Nov 10, 2022 9:36 am Post subject: Re: Engine dies at stops with clutch pedal depressed |
VW_Jimbo wrote: |
Curious.
Go to the back of the car. Open the decklid. Grab the crank pulley with 2 hands, tightly. Then try to push it into the case, followed by pulling it out of the case. Try a few times and use some forcefulness in moderation to check it with. |
I actually had done that again yesterday and she's tight, no give either way. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Thu Nov 10, 2022 9:48 am Post subject: Re: Engine dies at stops with clutch pedal depressed |
You may have a couple of issues at the same time.
Your clutch noise sounds like a bad TO bearing or clutch pivot (cross shaft). Either requires engine removal to fix.
Any chance your motor/tranny mounts are weak, and the engine is moving as you declutch, causing the throttle cable to take up or let slack out? Longshot, but easy to check with a buddy observing.
Your ground strap looks correct; some connect it to one of the two nuts holding the nosecone to the mount, which does not complete the ground path!
Posted: Thu Nov 10, 2022 10:33 am Post subject: Re: Engine dies at stops with clutch pedal depressed |
I'll check motor mounts and timing again. I did the valves a few weeks ago. |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15982 Location: North Florida, USA
Posted: Thu Nov 10, 2022 11:48 am Post subject: Re: Engine dies at stops with clutch pedal depressed |
doug bugg wrote: |
After the engine warmed up a bit, it wouldn't always die with the pedal on the floor but would drop from 600 rpms to about 100. |
Is your engine set up to idle @600rpm once warmed up? Normal warm idle for manual transmission engine is 800-950rpm. _________________ AshMan40
Posted: Thu Nov 10, 2022 12:20 pm Post subject: Re: Engine dies at stops with clutch pedal depressed |
ashman40 wrote: |
doug bugg wrote: |
Is your engine set up to idle @600rpm once warmed up? Normal warm idle for manual transmission engine is 800-950rpm. |
Oops! Fat-fingered THAT one! Supposed to read 900 rpm. |
Cubey Samba Member
Posted: Sun Jan 29, 2023 12:18 am Post subject: Re: Engine dies at stops with clutch pedal depressed |
Did you figure it out? I'm having the same issue on my 64. |
