thelongboardguy Samba Member
Posted: Sat Nov 12, 2022 4:45 pm Post subject: oil breather washer hole size? |
1973 SB
dual carbs
1600
stock vented heads but the vents are capped off
single cap oil breather
all of the emissions parts have been removed
Greetings,
I have recently removed the stock 2 cap oil breather and replaced it with a single cap breather as per recommendations by fellow Samba members. I have 2 different size washers for the inside. 1 has a 7mm hole in the center and the other is a 12mm hole. They both got mixed up in the cleaning bucket toss.
I do not know which would be the correct one to use for the single cap breather, nor do I understand how breathers work or why it would make a difference in hole size.
Both washers have the same outside diameters.
Any guidance on this is appreciated.
longboardguy _________________ 1973 Squareback
Dual Empi Carbs
I have put a hex on the previous owner of this car.
May he never be allowed to own or touch another motor vehicle as long as he lives. |
pedro sainz Samba Member
Posted: Sat Nov 12, 2022 7:37 pm Post subject: Re: oil breather washer hole size? |
thelongboardguy wrote: |
1973 SB
dual carbs
1600
Greetings,
longboardguy |
Regardless
Correct or Not
I would used the Bigger Center Hole
Will help Breathe Better _________________ 68 T34 1600 Automatic
62 T34 Cabriolet Prototype
N.O.N.A member #3
The Truth is Out There |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22358 Location: Kimball, Mi
Posted: Sun Nov 13, 2022 2:48 pm Post subject: Re: oil breather washer hole size? |
Agreed. Keep in mind that you want to pull vacuum thru it, and the larger hole will make that easier. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Nov 14, 2022 3:55 pm Post subject: Re: oil breather washer hole size? |
That makes sense.
I now have the 12mm washer installed.
Thanks _________________ 1973 Squareback
Dual Empi Carbs
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33883 Location: Conejo Valley, CA
Posted: Mon Nov 14, 2022 4:49 pm Post subject: Re: oil breather washer hole size? |
There is an open cell foam filter that fits into the spring, too.
https://vwispwest.com/filter-311115529a/
It tends to make an old soft/worn cap pop off, so it's often left out.
FWIW, the ISPwest washer drawing shows the larger center hole. |
Posted: Mon Nov 14, 2022 5:16 pm Post subject: Re: oil breather washer hole size? |
KTPhil wrote: |
Yup
I don’t even have washers on my engines
Just the Cell Filter
I like my Cases to Breathe as Much Possible 😁 _________________ 68 T34 1600 Automatic
N.O.N.A member #3
