BayStYat Samba Member
Joined: July 30, 2020 Posts: 136 Location: Gulf Coast MS
Posted: Wed Nov 23, 2022 7:04 pm Post subject: 2003 Trans temp supper high with aftermarket cooler |
I just did a LPD 49211 cooler with no bypass valve. (In live in the Deep South). I am seeing crazy high temps, 244F. I just did a trans fluid change and the cooler. At 60mph im running 3200 RPMS in 4th gear. I do have 225/65/16 tires. Shifts good but from 3 to 4 it holds for 2 seconds before 4 engages. I checked that the transmission is pumping fluid. I have check/set the fluid 2 times with the scan gauge.
I am completely stumped on that the problem could be.
Any guidance is appreciated |
hmbrgrs Samba Member
Joined: September 03, 2021 Posts: 21 Location: Seattle
Posted: Thu Nov 24, 2022 7:50 pm Post subject: Re: 2003 Trans temp supper high with aftermarket cooler |
shouldn’t it be closer to 70mph at 3200rpm? my 2002 does 60 mph at 2750rpm. |
Posted: Thu Nov 24, 2022 8:08 pm Post subject: Re: 2003 Trans temp supper high with aftermarket cooler |
hmbrgrs wrote: |
I was thinking my RPMs were high for 60 mph. |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2797 Location: North Carolina
Posted: Fri Nov 25, 2022 6:57 am Post subject: Re: 2003 Trans temp supper high with aftermarket cooler |
I'd be questioning my installation, honestly. Lord knows I've made enough mistakes to do so- are you sure everything is hooked up right? Please, again, note not saying you've done something wrong, not being critical or negative, just saying what I would do because I am super good at thinking I did things right and later discovering I did not. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
Posted: Fri Nov 25, 2022 11:22 am Post subject: Re: 2003 Trans temp supper high with aftermarket cooler |
mikemtnbike wrote: |
I'd be questioning my installation, honestly. Lord knows I've made enough mistakes to do so- are you sure everything is hooked up right? Please, again, note not saying you've done something wrong, not being critical or negative, just saying what I would do because I am super good at thinking I did things right and later discovering I did not. |
Definitely understand what you’re saying but I did verify it’s correct. Some one said my Torque Converter may not be locking up. Causing high rpm and creating heat. |
