Joined: December 14, 2008 Posts: 19 Location: South Florida
Posted: Thu Nov 24, 2022 9:55 am Post subject: rear decklid hinge modification |
does anybody have a modification to the rear decklid (engine) hinges so it opens more for easier access to the engine
thanks |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13957 Location: Southampton U.K.
Posted: Fri Nov 25, 2022 11:00 am Post subject: Re: rear decklid hinge modification |
i just want the lid to open more so it is easier to get to the motor |
Era Vulgaris Samba Member
Joined: August 22, 2012 Posts: 1678 Location: Raleigh, NC
Posted: Fri Nov 25, 2022 11:09 am Post subject: Re: rear decklid hinge modification |
If you look at the lower bracket that the spring attaches to on the firewall, you'll see several holes. Your springs are probably on one of the lower settings, like this one taken from the gallery. If you put the springs on a higher up hole, your decklid will stay open at a higher position.
You'll have to squeeze the spring arm with vice grips, and be careful because there is spring tension involved. I had to do this on the 67 I owned about 5 years ago. I don't recall whether it was difficult to move the springs, but I did do it so it couldn't have been too difficult
_________________ Currently own:
66 Karmann Ghia, L390 Gulf Blue, under construction, here: www.thesamba.com/vw/forum/viewtopic.php?t=760505&highlight=
99 Mazda MX-5 10AE, Sapphire Blue Mica, 6 speed, LSD
Previously owned:
98 Porsche Boxster, silver, 2.5L -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue |
Posted: Fri Nov 25, 2022 11:35 am Post subject: Re: rear decklid hinge modification |
i am not an expert but i think the spring adjustment is to adjust the tension on the spring to make sure it stays open (depending on the weight of the deck lid)
what i want to do is make the lid open more
the crotch of the hinge bracket that attaches to the lid hits the bracket to stop it from opening further
i need to modify that part to allow the lid to open more |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1049 Location: Jacksonville, FL
Posted: Fri Nov 25, 2022 3:36 pm Post subject: Re: rear decklid hinge modification |
[email protected] wrote: |
This is not a modification of the existing hinge assembly, rather a complete replacement of it.
You can use the hinges from a 2012 Nissan Maxima, fabricate some mounts, fabricate mounting brackets/plates for the lid, and have a crazy custom setup. I am looking into the viability of this approach which is why I mention it. These hinges have the potential to open the lid almost completely vertically and move it forward and out of the way when fully open.
Emil _________________
It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted |
Posted: Sat Nov 26, 2022 8:23 am Post subject: Re: rear decklid hinge modification |
that looks like a great option
you got me intrigued now - i am going to create a like original solution
i will let you know what i come up with
are there any dimensioned drawings of the original hinges available? |
Posted: Sat Nov 26, 2022 12:30 pm Post subject: Re: rear decklid hinge modification |
...are there any dimensioned drawings of the original hinges available? |
I haven't seen any but it shouldn't be too difficult to throw one together using your hinges as a reference. If you want to try your hand at designing a hinge that could fit into the existing location you can use a free program called "Linkage". There's a link to several YT videos on how to use Linkage at the top of the download page.
Link to "Linkage" download:
https://blog.rectorsquid.com/download-linkage/
kiwighia68
Posted: Sat Nov 26, 2022 1:49 pm Post subject: Re: rear decklid hinge modification |
Correct. I misunderstood what you were asking. I thought you had a sagging engine lid and wanted it to stay fully open. I didn't realize you're trying to get it to open beyond the original limits. Disregard my comment! _________________ Currently own:
Previously owned:
chink13 Samba Member
Joined: May 07, 2009 Posts: 143 Location: Ocean Springs, MS
Posted: Mon Nov 28, 2022 8:28 am Post subject: Re: rear decklid hinge modification |
i wonder if a flip flop truck kit would work on a ghia. it certainly would be very cool |
toddb_67 Samba Member
Joined: November 28, 2003 Posts: 1313 Location: Hansville, WA
