JiI Samba Member
Joined: February 18, 2006 Posts: 1845 Location: Michigan
Posted: Fri Nov 25, 2022 2:04 pm Post subject: 1963-1965 front upper shock bolt |
Anyone know where to get one? A used one is fine. I'm just not finding them anywhere. Thanks!
Jeff |
vwoldbug Samba Member
Posted: Fri Nov 25, 2022 3:26 pm Post subject: Re: 1963-1965 front upper shock bolt |
Wolfsburg West shows they have them. |
JiI Samba Member
Posted: Fri Nov 25, 2022 4:23 pm Post subject: Re: 1963-1965 front upper shock bolt |
Thanks. I'll check. Couldn't get on their site earlier.
Jeff |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5600 Location: 37.5N 77.1W
Posted: Sun Nov 27, 2022 7:04 am Post subject: Re: 1963-1965 front upper shock bolt |
it's not really a special bolt. Measure it then just get a 'hardened' one 10.9 _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
RWK Samba Member
Posted: Sun Nov 27, 2022 7:19 am Post subject: Re: 1963-1965 front upper shock bolt |
The thread is smaller then the shank, it can be drilled out for a 12mm std bolt, that is std. practice in the off road community. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
Posted: Sun Nov 27, 2022 8:30 am Post subject: Re: 1963-1965 front upper shock bolt |
Quote: |
thread is smaller then the shank |
it's a regular old everyday 12mm-1.5 bolt. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
JiI Samba Member
Posted: Sun Nov 27, 2022 8:37 am Post subject: Re: 1963-1965 front upper shock bolt |
What about the 16mm sleeve over it? |
anthracitedub Samba Member
Posted: Sun Nov 27, 2022 8:44 am Post subject: Re: 1963-1965 front upper shock bolt |
The bolt is not just a regular bolt… it is shouldered and specific for the job. Use a little antisieze on the threads and shoulder area to keep it from getting stuck. |
Posted: Sun Nov 27, 2022 9:20 am Post subject: Re: 1963-1965 front upper shock bolt |
y'all need to send a letter to CIP, to name a few, and tell them they are wrong
"PAIR OF TOP SHOCK BOLTS FOR KING-LINK FRONT END - 12MMX1.5MM - 65MM LONG - BEETLE/GHIA 62-65"
https://www2.cip1.com/vwc-111-413-403-apr/ _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
JiI Samba Member
Posted: Sun Nov 27, 2022 9:54 am Post subject: Re: 1963-1965 front upper shock bolt |
Serious blond moment. Didn't realize the sleeves were frozen on the shafts from the shocks.
Just ignore the rest of this thread...
Jeff |
Posted: Sun Nov 27, 2022 10:12 am Post subject: Re: 1963-1965 front upper shock bolt |
Quote: |
frozen on the shafts |
This will get them off easy clamp the bolt in a vise, put the chisel end against the tube about mid-way. Hold the airtool at about 45° and pull the trigger
JiI Samba Member
Posted: Sun Nov 27, 2022 10:15 am Post subject: Re: 1963-1965 front upper shock bolt |
If I owned any air tools, that might work.
I'll just dremel them off. No big deal.
Jeff |
RWK Samba Member
Posted: Mon Nov 28, 2022 4:14 pm Post subject: Re: 1963-1965 front upper shock bolt |
My bad, early king/link pin beams used stepped bolt for upper shock. Missed the date from OP _________________ 73 Type 181
63 Type 113
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Mon Nov 28, 2022 4:17 pm Post subject: Re: 1963-1965 front upper shock bolt |
anthracitedub wrote: |
I second the anti-seize! I had one shear off at the first thread. Check the thread lead-in for any burrs or sharp edges. That is a stress point. |
JiI Samba Member
Posted: Tue Nov 29, 2022 8:45 am Post subject: Re: 1963-1965 front upper shock bolt |
Ace only has 12-1.75 bolts.
Check the big boxes next...
McMaster has them. |
Posted: Tue Nov 29, 2022 9:34 am Post subject: Re: 1963-1965 front upper shock bolt |
Quote: |
Ace only has 12-1.75 bolts. |
just get the nut that's for that size. save some gas _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Posted: Tue Nov 29, 2022 10:07 am Post subject: Re: 1963-1965 front upper shock bolt |
https://www.thesamba.com/vw/gallery/pix/1458949.jpg
From the forums. I think the hack job of drilling out the shock tower and just sizing up to a 12mm bolt is what a few of you are trying to convey. The bolt in the pic is what is normally found on a link pin front end that hasn’t been modified. |
JiI Samba Member
Posted: Tue Nov 29, 2022 10:18 am Post subject: Re: 1963-1965 front upper shock bolt |
That's the earlier stepped 12mm shaft/ 10mm thread. The 63-65 was a straight 12mm.
I could retap the hole but it's easier to just get the bolt. Can order them now that I got the website leads.
Jeff |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
Posted: Tue Nov 29, 2022 12:36 pm Post subject: Re: 1963-1965 front upper shock bolt |
JiI wrote: |
Other thread pitches are typically in the small drawers at Ace. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
JiI Samba Member
Posted: Tue Nov 29, 2022 1:27 pm Post subject: Re: 1963-1965 front upper shock bolt |
Yeah, but we live in Traverse city, mi. They just heard of electricity and those new fangled aeroplanes up here.... |
