DesertG Samba Member
Posted: Sun Nov 27, 2022 5:09 pm Post subject: Quick Towing Question - 1965 |
Hi Guys, I am going to most likely buy a stock height 1965 Beetle. Will this drive onto a Uhaul car hauler (not the dolly) without issues. I assume pull the car on nose first. Anything else I should know. Thank you
https://www.uhaul.com/Trailers/Auto-Transport-Rental/AT/ |
AirHead1966 Samba Member
Joined: October 17, 2019 Posts: 568 Location: Triad Area NC
Posted: Sun Nov 27, 2022 5:48 pm Post subject: Re: Quick Towing Question - 1965 |
Without a problem.
Posted: Sun Nov 27, 2022 6:24 pm Post subject: Re: Quick Towing Question - 1965 |
AirHead1966 wrote: |
Without a problem.
Thank you. Can you tell me where you attached the front and rear chains that come with that trailer. |
Posted: Sun Nov 27, 2022 6:41 pm Post subject: Re: Quick Towing Question - 1965 |
I made sure that the ratchet straps were tight around the tires. Those are the main holding points. The chains are backup safety. I put the chains around the front beam and and rear torsion bars.
The car is narrow but it fits the ramps and the platform. Just have someone guide you on and off carefully. I transported it on the pictured uhaul trailer for over 150 miles without any issues. |
Posted: Sun Nov 27, 2022 6:43 pm Post subject: Re: Quick Towing Question - 1965 |
Thank you Sir. I think I want to check the lug nuts. Are they really 12mm? Do you know the torque spec. |
Posted: Sun Nov 27, 2022 6:46 pm Post subject: Re: Quick Towing Question - 1965 |
12x1.5 bolts, not nuts. I torque mine to 73 ft-lbs. |
Posted: Sun Nov 27, 2022 6:48 pm Post subject: Re: Quick Towing Question - 1965 |
Thank you. Hopefully this car is exactly like the owner says... |
bigdog1962 Samba Member
Joined: August 11, 2010 Posts: 1586 Location: Augusta, Georgia
Posted: Mon Nov 28, 2022 5:33 am Post subject: Re: Quick Towing Question - 1965 |
The car is narrow but it fits the ramps and the platform. Just have someone guide you on and off carefully. |
^^^This.
And mine shifted during transport on the rails. Had to get a couple of people to shove it back closer to center at the end of the trip.
I bought a tow bar - I'm not using the Uhaul trailer any more. _________________ Oprn wrote: I'm getting to the age that any self propelled woman (no wheel chair or walker) looks HOT!! Oooo! look at that Babe! She made it from the dining room all the way to the TV room without help!! Hubba, hubba!! |
Posted: Mon Nov 28, 2022 7:56 am Post subject: Re: Quick Towing Question - 1965 |
bigdog1962 wrote: |
How did it shift? The front of the trailer has wheel chocks, and the tires butt up against them and get pressed against them using the ratcheting straps. They should remain locked rock solid if strapped properly. The chains are just secondary safety, the straps lock the car in place.
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Mon Nov 28, 2022 9:16 am Post subject: Re: Quick Towing Question - 1965 |
I've used the Uhaul trailer once. The track is a bit narrow for a bug, but it still fits. Just use a spotter as someone else suggested.
I didn't have any issues with the car moving at all. I'm pretty meticulous about using the straps, and using extra chains or straps. |
aa390392 Samba Member
Posted: Mon Nov 28, 2022 10:21 am Post subject: Re: Quick Towing Question - 1965 |
Buy a VW tow bar,,,in n out in 5 mins.
Have hauled many a cars many a miles, not 1 issue.
No drama. _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
finster Samba Member
Joined: May 26, 2012 Posts: 7951 Location: north o' the border
Posted: Mon Nov 28, 2022 10:25 am Post subject: Re: Quick Towing Question - 1965 |
aa390392 wrote: |
No drama. |
that's assuming the tyres/bearings are up to the job.... _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Mon Nov 28, 2022 11:16 am Post subject: Re: Quick Towing Question - 1965 |
I bought a used tow dolly for everything I tow. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Mon Nov 28, 2022 11:36 am Post subject: Re: Quick Towing Question - 1965 |
With the U-haul trailer, go ahead and add a couple of your own ratchet straps (maybe cross them) from the torsion tubes to somewhere on the trailer- just to reduced the chance of it crab walking a little over rough roads. Small stock tires have very little practical gripping contact with the trailer rails.
Bigdog1962 and I have had similar experience I think. _________________
EverettB wrote: |
FU#5 |
Posted: Mon Nov 28, 2022 12:19 pm Post subject: Re: Quick Towing Question - 1965 |
How did it shift? |
I had it ratcheted down and chocked but after 3 hours on the road and time to get it off, it was not a straight back down the ramp job. And there is no room to turn the wheel.
I like Hitest's description - crab walk.
With the rails being so narrow, any sift can make it much more difficult to get off the trailer. It can be done but I decided to not use a Uhaul trailer any more as I can't always depend on there being help to unload it. _________________ Oprn wrote: I'm getting to the age that any self propelled woman (no wheel chair or walker) looks HOT!! Oooo! look at that Babe! She made it from the dining room all the way to the TV room without help!! Hubba, hubba!! |
