Wworrell Samba Member
Posted: Mon Nov 28, 2022 6:34 pm Post subject: Help please broken crank pulley on vw 2332 |
Hello, looking for some help please. I purchased this sandrail with a broken crank pulley. Please see pic. It appears what's left of the pulley is some aluminum and what looks to be a steel ring. I was hoping to confirm that comes off as well so I can weld a puller onto it and get the rest of the broken pieces off without taking the engine apart.
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Mon Nov 28, 2022 7:36 pm Post subject: Re: Help please broken crank pulley on vw 2332 |
Yes, both should be removed…cheap Empi aluminum pulley with steel sleeve
Remove the sand seal to give you more room
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Mon Nov 28, 2022 7:40 pm Post subject: Re: Help please broken crank pulley on vw 2332 |
I would try to use a couple of new sharp std screwdrivers on both sides and pry gently to work it out, if that don't work pop out the seal to give your self a bit more room to work on it, you could try drilling a hole between the sleeve and the pulley bits and try to split the sleeve.
eQ _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Posted: Mon Nov 28, 2022 8:33 pm Post subject: Re: Help please broken crank pulley on vw 2332 |
Great info gentleman exactly what I needed thank you! |
RCP Phx Samba Member
Joined: November 20, 2021 Posts: 496 Location: Phoenix,AZ
Posted: Mon Nov 28, 2022 9:37 pm Post subject: Re: Help please broken crank pulley on vw 2332 |
I would drill a "lot" of holes in the aluminum between the crank and the sand seal liner |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Mon Nov 28, 2022 10:02 pm Post subject: Re: Help please broken crank pulley on vw 2332 |
I’d use two saddles from muffler clamps and some long bolts to grab it. From there you should be able to walk it off the crank. Love taps. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
John Connolly Samba Member
Joined: September 22, 2015 Posts: 48 Location: Sandy, UT
Posted: Mon Nov 28, 2022 10:49 pm Post subject: Re: Help please broken crank pulley on vw 2332 |
measure what's left first, so you know which size SS pulley to put back on when you are done. There are 2 standards. _________________ it's advice. If you don't like it, ignore it. Don't argue.
If you want no-BS technical advice privately, feel free to DM me. Donations appreciated (food gift certificates, etc). |
oprn Samba Member
Joined: November 13, 2016 Posts: 12714 Location: Western Canada
Posted: Tue Nov 29, 2022 5:33 am Post subject: Re: Help please broken crank pulley on vw 2332 |
Is that JB Weld I am seeing sealing the crankcase halves? _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Tue Nov 29, 2022 7:00 am Post subject: Re: Help please broken crank pulley on vw 2332 |
Probably , Yamabond same color _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Posted: Sun Jan 01, 2023 7:01 pm Post subject: Re: Help please broken crank pulley on vw 2332 |
I did end up getting it off for anyone's future reference I tac welded bolts from a pulley puller and it came right off
