tristanblue Samba Member
Posted: Tue Nov 29, 2022 6:53 pm Post subject: Which is best to use with spacers lug bolts or studs and nuts? |
Installing some aftermarket 911 style wide fives on a beetle. The rear wheels need 1/4 spacers to keep from rubbing. Will using spacers require I use lug bolts or studs with nuts or will both work.
Thanks
T
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 74690 Location: Sneaking up behind you
Posted: Tue Nov 29, 2022 7:04 pm Post subject: Re: Which is best to use with spacers lug bolts or studs and nuts? |
Studs make.it easier to mount the tire but either will do the job _________________ Glenn
Member #1009
"Politics is the art of looking for trouble, finding it everywhere, diagnosing it incorrectly and applying the wrong remedies."
Groucho Marx |
hitest Samba Member
Joined: September 30, 2008 Posts: 10274 Location: Prime Meridian, ID
Posted: Wed Dec 07, 2022 2:27 pm Post subject: Re: Which is best to use with spacers lug bolts or studs and nuts? |
Does your car have a disc conversion up front? It looks the part on my monitor. The reason I ask is if so, maybe spacers to bring the rears out a little to match. _________________
EverettB wrote: |
FU#5 |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17712 Location: Eugene, OR
Posted: Sun Dec 11, 2022 12:53 pm Post subject: Re: Which is best to use with spacers lug bolts or studs and nuts? |
I bought longer Mercedes style lug bolts for my Fuchs wheels from www.ezaccessory.com _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
esde Samba Member
Joined: October 20, 2007 Posts: 5358 Location: central rust belt
Posted: Sun Dec 11, 2022 1:21 pm Post subject: Re: Which is best to use with spacers lug bolts or studs and nuts? |
When using spacers, I like to drill and tap two holes, so I can use a flat head machine screw to mount them to the drum. Just makes life easier down the road. _________________ modok wrote:
