chrisfreemanca Samba Member
Posted: Wed Nov 30, 2022 3:03 pm Post subject: Would this panel scare you away? |
Pretty sure this rear panel is rusted from just below the rear window down into the wheel well. I'm in a non salt on the road and very low rust area so not sure it would get much worse. How much would that deter you from pursuing it?
[/img] _________________ 87 2wd manual. |
calsurf Samba Member
Posted: Wed Nov 30, 2022 3:28 pm Post subject: Re: Would this panel scare you away? |
Depends on the price of the Westy and your willingness/experience to tackle bodywork. Probably more to the eye here. But, if there's a deal to be had, I'd use that rust & that lower mid-panel as a negotiation item, cheers. |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Wed Nov 30, 2022 3:31 pm Post subject: Re: Would this panel scare you away? |
I'd go on price from there. In my case, I am ALWAYS considering any bus... But then again, I am quite disturbed in the head. Once you have 2, you can't ever think in terms of just one again... Cars and Guitars, it never ends.
If it were the right price, I could see that being an easy Ospho treatment twice a year, and drive it til the wheels fell off thing. The window rust would be problematic, since I would not want to weld in clean metal with the cabinets in place... Not fun to start a fire where you can't put it out. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4789 Location: Bemidji, MN
Posted: Wed Nov 30, 2022 4:09 pm Post subject: Re: Would this panel scare you away? |
will that panel affect your fun? your ability to camp? where you go and what you see? of course not.
it all depends on what you're buying a westy for.. an investment? a puff piece to garner compliments and stroke your ego? something for the next 20 years?
so the real question is how much money do you have to find one with zero rust? sure, everyone wants a creampuff. if you can afford it, by all means buy one. if you can't afford it, you'll still have a ball with a bit of rust. _________________ -dan
www.thefixitworkshop.com |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12006 Location: Santa Cruz, CA
Posted: Wed Nov 30, 2022 4:22 pm Post subject: Re: Would this panel scare you away? |
The lifting window seals means there is rust festering in there and likely holes. That kitchen wall rot that you can see on westies is a known rust issue that typically is even worse inside.
If want a van to keep for a long time I would pay more for a dry body, if you just want a beater I would use the rust as a price negotiation point.
Would it scare me away? Probably since I know rust only gets worse with time and I keep cars for decades. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
Silverghost500 Samba Member
Joined: August 01, 2018 Posts: 1087 Location: Atlanta, GA
Posted: Wed Nov 30, 2022 4:35 pm Post subject: Re: Would this panel scare you away? |
Rust is like an iceberg. There's usually a whole lot more beneath the surface. _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
Honda K24A converversion-Road Testing Phase
3-Speed Automatic
Von Westy YouTube Channel
https://www.youtube.com/channel/UCbhyZYxJEQrUuLnMbLleeIA |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4024 Location: Redwood City, California
Posted: Wed Nov 30, 2022 6:18 pm Post subject: Re: Would this panel scare you away? |
I think the fact that the service doors are in the wrong location would worry me as much.
That van with that amount of rust should be about $7500.00, I'd bet there is not a single panel without some rust in it.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4094 Location: East Kootenay, British Columbia
Posted: Wed Nov 30, 2022 6:22 pm Post subject: Re: Would this panel scare you away? |
16CVs wrote: |
That van with that amount of rust should be about $7500.00, I'd bet there is not a single panel without some rust in it. Stacy |
(edit: changed my mind on what I said about it maybe being a conversion)
It all depends on price, but rust work can be very expensive unless you do the work yourself and remember - Rust NEVER sleeps. _________________ Currently:
Defend democracy, support Ukraine.
outcaststudios Samba Member
Joined: February 09, 2015 Posts: 1732 Location: Maine
Posted: Wed Nov 30, 2022 7:22 pm Post subject: Re: Would this panel scare you away? |
nothing scares me, i drive a vw. _________________ '88Doka JX td
'69 westy
(rip)couple bugs
(rip)three type III"s
(rip) '81 vanagon
a bunch of french stuff,and 9 motorcycles.
https://www.thesamba.com/vw/classifieds/detail.php?id=2573791 |
steve244 Samba Member
chrissev2 Samba Member
Posted: Thu Dec 01, 2022 8:58 am Post subject: Re: Would this panel scare you away? |
That is not really that difficult to fix, and the entire panel is available as a patch.
I have removed and replaced that panel on my vanagon. It is not hard to get it out, and it requires removing the interior pieces behind it and drilling out some welds.
You can find dry, rot free Vanagons, so repairing rust is really a choice. What I would do is dig into it and see what condition everything else is in. If it has new front and rear end work, brakes are recent, engine is functional and recently rebuilt and otherwise in good shape, it would probably make sense to fix it. If everything is junk, then find a dry body and rebuild from there.
You also have the real opportunity and alternative to simply ignore that rust and enjoy the vehicle. It will be many years before that rust becomes something that renders the vehicle unsafe or un-driveable. So you can just ignore it. _________________ 1986 westfalia auto 1.9TD
2023 VW Atlas 3.6 VR6 Highline
2019 Golf Wagon 4 motion
1978 Volkswagen super beetle convertible
1992 Eurovan 2.5 5spd westfalia |
jimf909 Samba Member
Posted: Thu Dec 01, 2022 10:36 am Post subject: Re: Would this panel scare you away? |
This is all about what you want. I've always said that not one camping trip was ruined by seam rust.
Much more important to me are other things like under-body rust and general upkeep of the van. Has the van been meticulously maintained? Are the suspension components rusted together? The underbody? Will your foot go through the rusted out hole below the pads at the front doors? Those things scare me away, not seam rust. But again, this is all about you.
I bought this van nine years ago and this seam rust hasn't advanced much (although it's accelerated the last few years). The engine bay and underbody are entirely rust free and the we don't hesitate to drive it 1,000 miles.
Pictures of the engine and the rest of the van and its asking prices will get more helpful information from this gang in terms of the whether or not it's worth it.
Unless if you don't like rust, then walk away. _________________ - Jim
Abscate wrote: |
Posted: Thu Dec 01, 2022 11:16 am Post subject: Re: Would this panel scare you away? |
16CVs wrote: |
Service doors? _________________ 87 2wd manual. |
Posted: Thu Dec 01, 2022 11:19 am Post subject: Re: Would this panel scare you away? |
DanHoug wrote: |
so the real question is how much money do you have to find one with zero rust? sure, everyone wants a creampuff. if you can afford it, by all means buy one. if you can't afford it, you'll still have a ball with a bit of rust. |
Fair enough. Definitely would be a user as was my '87 that I had, not a show piece. Trying to get more engine pics before making a 4 hour drive to check it out. _________________ 87 2wd manual. |
Posted: Thu Dec 01, 2022 11:21 am Post subject: Re: Would this panel scare you away? |
calsurf wrote: |
Asking $15k OBO currently. Working on getting some engine pics. _________________ 87 2wd manual. |
jlrftype7 Samba Member
Posted: Thu Dec 01, 2022 11:38 am Post subject: Re: Would this panel scare you away? |
chrisfreemanca wrote: |
16CVs wrote: |
Service doors? |
The access doors on the side for Water and other Utilities. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
kamzcab86 Samba Moderator
Posted: Thu Dec 01, 2022 11:52 am Post subject: Re: Would this panel scare you away? |
jlrftype7 wrote: |
16CVs wrote: |
Service doors? |
The access doors on the side for Water and other Utilities. |
What we Westy people call hook-up boxes. _________________ ~Kamz
2016 Golf GTI S
valvecovergasket Samba Member
Posted: Thu Dec 01, 2022 11:57 am Post subject: Re: Would this panel scare you away? |
calsurf wrote: |
Asking $15k OBO currently. Working on getting some engine pics. |
seems like the rest of it should be really nice or desirable to justify that... _________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
