Braukuche Samba Member
Posted: Tue Dec 27, 2022 9:48 am Post subject: Re: Fantasy Porsche option project |
Trylon wrote: |
So you don’t need a fancy-schmacy painting booth and such to paint these? |
No, but it would be nice as it cuts down on dust nibs. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Posted: Wed Dec 28, 2022 4:46 pm Post subject: Re: Fantasy Porsche option project |
We cleaned up the original German pans, fixed some holes sealed and undercoated using 3M schutz like the dealer did.
Top side I shot it with epoxy sealer then three coats of black acrylic urethane.
The pans by the way were replaced on the car and the PO chose to use original German ones carefully removed from other Ghias. Given the poor fit and thinness of the available reproductions we decided to stick with these.,the pressings are deeper, the steel is thicker and we feel it will give the car more rigidity than aftermarket,
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Mnmunky Samba Member
Joined: December 18, 2012 Posts: 80 Location: Minnesota
Posted: Wed Dec 28, 2022 6:40 pm Post subject: Re: Fantasy Porsche option project |
I’m fortunate enough to have both a swb 912 and recently purchased my dream car, a Karmann Ghia coupe.
The 912 has an overbored engine with a few go faster tweaks and I can honestly say, it’s the biggest ‘insert your own swearword here’ I’ve ever fought with.
Don’t drive it for a couple of weeks and try and get the thing started… grrr.
It looks like you know what you are doing, so I’m sure it won’t phase you, but the 19xxcc in the ghia is a (much lower powered) peach by comparison!
Good luck and thanks for posting. I really need to find time to get back into the garage and get wrenching on my two again. |
Posted: Wed Dec 28, 2022 6:47 pm Post subject: Re: Fantasy Porsche option project |
Mnmunky wrote: |
Nice 912 and Ghia.
I’ve had a couple 912s, both ‘67s. Wonderful cars. Never had too many issues with starting after sitting for a while, but my 356 with Zeniths will do that and I’ve noticed the same with my 62 Ghia with a Porsche engine and Zeniths. I think the fuel evaporates out of them and so the pump has to refill the reservoir. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Posted: Wed Dec 28, 2022 6:51 pm Post subject: Re: Fantasy Porsche option project |
Ha ha ha! You are spot on.
Sounds like you are more than well versed in the issues and ready to fight them.
I’m looking forward to being inspired by your progress! |
NoDents Samba Member
Posted: Thu Dec 29, 2022 10:12 am Post subject: Re: Fantasy Porsche option project |
I went with a 914 2.8 liter and a 911(915 model) 5 speed transmission.
_________________ No Dents
1963 Bug - Sold in 1980
1966 Karmann Ghia Convertible - Stolen in 1988
1971 Karmann Ghia Convertible, resto/mod COMPLETED 10/2020 |
Posted: Thu Dec 29, 2022 6:56 pm Post subject: Re: Fantasy Porsche option project |
NoDents wrote: |
Nice. Bet it hauls ass. What’s the horsepower on it? We are estimating 100 to 110 based on factory specs plus adding in the big bore pistons, meaning the engine will displace 1.7 vs 1.6. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Posted: Thu Dec 29, 2022 7:04 pm Post subject: Re: Fantasy Porsche option project |
Braukuche wrote: |
NoDents wrote: |
Nice. Bet it hauls ass. What’s the horsepower on it? We are estimating 100 to 110 based on factory specs plus adding in the big bore pistons, meaning the engine will displace 1.7 vs 1.6. |
See dyno run here: https://youtu.be/0lbrDeu-LaQ
185whp, 182 torque. EST: 220hp at flywheel. _________________ No Dents
Went in this morning and spent the day doing some last minute paint prep and then shot the sealer and then three fat coats of Restoration Shop Acrylic Urethane Porsche Slate Gray.
Ignore the hideous yellow stuff. I wasn’t sure if paint would adhere to the sound insulation so we will brush black truck bed liner on it before covering most of it with carpet and interior parts.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
Posted: Thu Dec 29, 2022 8:59 pm Post subject: Re: Fantasy Porsche option project |
Braukuche wrote: |
..... I think the fuel evaporates out of them and so the pump has to refill the reservoir. |
That's exactly what my Ghia does.. The solution is to pour a cap full of fuel down the throat of the carb so there's something to get the motor turning soon after the first crank. The float in the carb fills up pretty quickly after that and saves the wear on the starter motor and the battery.
Nicholas _________________ '66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
Posted: Fri Dec 30, 2022 7:56 am Post subject: Re: Fantasy Porsche option project |
sputnick60 wrote: |
Braukuche wrote: |
Nicholas |
Some Porsche guys install a hand pump, like a squeeze ball, in line to pump fuel into the carbs.
Of course an electric fuel pump would be the best solution if you have 12 volts. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Posted: Fri Dec 30, 2022 5:32 pm Post subject: Re: Fantasy Porsche option project |
Put the hood and decklid on today. Waiting on a set of new hinges for the doors.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
obus Samba Member
Joined: March 08, 2001 Posts: 11069 Location: just off Garden State Parkway Exit 81
Rome Samba Member
Joined: June 02, 2004 Posts: 9651 Location: Pearl River, NY
Posted: Sun Jan 01, 2023 2:51 pm Post subject: Re: Fantasy Porsche option project |
Is the body color a very dark grey, or black? Can look like either in your photos, probably lighting dependant. But that gloss is so nice.
Did you not want to paint the trunk area, spare tire well and inside of the nose the same color? |
Posted: Sun Jan 01, 2023 3:32 pm Post subject: Re: Fantasy Porsche option project |
Rome wrote: |
It’s Slate Gray, so in some light it’s a deep anthracite gray, in sunlight it lightens up a lot and you can see a touch of green.
The yellow you see is the plastic coating the PO had sprayed on the interior to sound proof it. From what I’ve read it’s used for cars with high end sound systems. We kept it because it will cut down on engine and exterior noise.
I’m concerned that the paint would not stick well or provide an effective surface for glue for the carpet and vinyl so we will use a black brush on product to cover it. Something like truck bed liner. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Rome Samba Member
Posted: Sun Jan 01, 2023 11:20 pm Post subject: Re: Fantasy Porsche option project |
Ahhh, Slate Grey! Excellent choice.
Here's a shot from July 2020 of my friend Moogie32's Slate Grey '65 356SC Cabrio, Bill S' Speedster replica and my Pearl White '64 Ghia during a drive outing in central CT- |
Posted: Mon Jan 02, 2023 8:50 am Post subject: Re: Fantasy Porsche option project |
Rome wrote: |
Nice line up!
The look we are going for color wise is like that 356 cab. Except we are doing a burgundy top instead of black. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Posted: Mon Jan 02, 2023 8:33 pm Post subject: Re: Fantasy Porsche option project |
We covered all the yellow plastic sound proofing material with black truck liner today and began reassembling the pan starting with a CB Performance narrowed and adjustable beam with new narrowed torsion bars.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
TRS63 Samba Member
Joined: December 17, 2017 Posts: 999 Location: Stuttgart - Germany
Posted: Tue Jan 10, 2023 10:01 pm Post subject: Re: Fantasy Porsche option project |
Cut and buffed and finally with doors and lower trim on.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
