zerotofifty Samba Member
Posted: Fri Dec 02, 2022 11:35 am Post subject: flywheel to crack seal types |
I have some manuals that show different types of flywheel to crank seals.
It appears there are three types
1.. A paper gasket (used with straight flywheel to crank joint).
2...A metal shim (used with tapered flywheel to crank joint).
3. An Oring seal around the crank to flywheel joint.(used on flywheels with Oring groove).
Is this correct?
What type will be on a 1966 1300 cc * stock original motor?
thanks
* ed. engine displacement corrected
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 852 Location: South Florida
Posted: Fri Dec 02, 2022 2:37 pm Post subject: Re: flywheel to crack seal types |
zerotofifty wrote: |
... What type will be on a 1966 1200cc stock original motor? |
The 1966 Beetles imported to USA had 1300cc engines. There are lots of threads re your gasket question(s). For example, this one may be helpful; especially the post by mukluk, just a few posts below/after this one:
https://www.thesamba.com/vw/forum/viewtopic.php?p=9865334&highlight=#9865334 |
Posted: Fri Dec 02, 2022 5:57 pm Post subject: Re: flywheel to crack seal types |
yeah, your right, 1300 cc, my typo error, does not compute, duh......
that link you showed me is good, thank you. |
