Rickf1985 Samba Member
Posted: Sat Apr 15, 2023 6:59 pm Post subject: Re: 71 Beetle engine pull adventure |
Sounds real good. |
Marcdeb Samba Member
vamram Samba Member
Posted: Sun Apr 16, 2023 9:45 am Post subject: Re: 71 Beetle engine pull adventure |
Sounds awesome, congrats and now to enjoy the open roads and shows! _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Sun Apr 16, 2023 10:52 am Post subject: Re: 71 Beetle engine pull adventure |
What a great clip. Seems like you got everything sorted. I'm so glad you stuck with it and are now enjoying your bug! |
sb001 Samba Member
Posted: Sun Apr 16, 2023 11:01 am Post subject: Re: 71 Beetle engine pull adventure |
mg50 wrote: |
I hope this thread stays available somewhere because I'll probably forget all I learned if I decide to build another engine. |
I do too as I would reference it the first time I ever decide to try to rebuild my own VW engine! _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4407 Location: Stuck in Ohio
mg50 Samba Member
Joined: August 30, 2022 Posts: 647 Location: Southeast
Posted: Sun Apr 16, 2023 12:48 pm Post subject: Re: 71 Beetle engine pull adventure |
Buggeee wrote: |
Great Video! |
Thanks,
A happy accident, those girls in prom dresses crossing the street. |
mg50 Samba Member
Posted: Sun Apr 16, 2023 12:50 pm Post subject: Re: 71 Beetle engine pull adventure |
sb001 wrote: |
mg50 wrote: |
I do too as I would reference it the first time I ever decide to try to rebuild my own VW engine! |
Reference Cusser's video first, fewer dumb mistakes |
sb001 Samba Member
Posted: Sun Apr 16, 2023 5:03 pm Post subject: Re: 71 Beetle engine pull adventure |
mg50 wrote: |
Buggeee wrote: |
Great Video! |
Thanks,
Come on, that was set up _________________ I'm the humblest guy on this board.
1600 SP engine
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9755 Location: Oregon
Posted: Sun Apr 16, 2023 6:10 pm Post subject: Re: 71 Beetle engine pull adventure |
mg50 wrote: |
sb001 wrote: |
mg50 wrote: |
You shoulda offered those girls a ride to the entrance to the Prom Venue.
They'd have been a hit with all the other girls and guy's there!
Thank you for the props in the credits in your video! _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
mg50 Samba Member
Posted: Sun Apr 16, 2023 6:26 pm Post subject: Re: 71 Beetle engine pull adventure |
. [/quote][/quote]
They'd have been a hit with all the other girls and :[/quote]
Would have had to clear that with my wife standing there on the corner shooting the video. |
mg50 Samba Member
Posted: Tue Apr 18, 2023 10:20 am Post subject: Re: 71 Beetle engine pull adventure |
Happy to say no leaks, except for a small leak that seems to come from part of the breather. I wipe it up after each run. I can't see why it would leak from there unless breather pan oil is sloshing around. I thought I filled oil to the right level but maybe I need to take the level down.
Posted: Tue Apr 18, 2023 5:46 pm Post subject: Re: 71 Beetle engine pull adventure |
Is your road draft tube plugged at the bottom of the down pipe? I think you need to cut the slit in the new rubber "valve" that goes on the bottom of the tube if you put a new one on there.
It's not uncommon to get more than usual blow by before the rings seat. Run the car up to speed, then let it engine brake to slow down. This can help set the rings and reduce the blow by. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31361 Location: Hot Arizona
Posted: Tue Apr 18, 2023 6:41 pm Post subject: Re: 71 Beetle engine pull adventure |
Pruneman99 wrote: |
Is your road draft tube plugged at the bottom of the down pipe? I think you need to cut the slit in the new rubber "valve" that goes on the bottom of the tube if you put a new one on there. |
Yes, new ones need to be slit by the installer.
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
mg50 Samba Member
Posted: Wed Apr 19, 2023 4:20 am Post subject: Re: 71 Beetle engine pull adventure |
Cusser wrote: |
Pruneman99 wrote: |
Is that a piece that goes in the bottom of the pipe that goes through the tin? None there on this old pipe.
I drained out some of the oil that was in the air cleaner and will see if that helps. |
Cusser Samba Member
Posted: Wed Apr 19, 2023 6:38 am Post subject: Re: 71 Beetle engine pull adventure |
mg50 wrote: |
Is that a piece that goes in the bottom of the pipe that goes through the tin? None there on this old pipe. . |
Yes. This won't affect your issue specifically, but can help dust getting sucked into the engine.
mg50 wrote: |
That's a good place to start.
If not the answer, maybe wait a few hundred miles of driving to see.... _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Wed Apr 19, 2023 12:00 pm Post subject: Re: 71 Beetle engine pull adventure |
Curious, When you installed the oil filler stand baffle. You made sure to install it with the louvers pointing toward the crankcase and pointing to the right. Right?[/img] _________________ I have learned over the years.
Buy Once, Cry Once!
mg50 Samba Member
Posted: Thu Apr 20, 2023 8:05 am Post subject: Re: 71 Beetle engine pull adventure |
67rustavenger wrote: |
Curious, When you installed the oil filler stand baffle. You made sure to install it with the louvers pointing toward the crankcase and pointing to the right. Right?[/img] |
Pretty sure I was careful about that and it is a question as part of the thread. Let me find pictures. |
mg50 Samba Member
Posted: Thu Apr 20, 2023 1:04 pm Post subject: Re: 71 Beetle engine pull adventure |
I was following this picture in Bentley book.
mg50 Samba Member
Posted: Thu Apr 20, 2023 3:09 pm Post subject: Re: 71 Beetle engine pull adventure |
No oil has splashed up the generator base to the new cap; still dry. Just wet around the bottom hinge of the weighted flap on air cleaner. just a few drops end up on the tin near the dipstick after a run. Not a big thing but I have to OCD about something.
