mg50 Samba Member
Joined: August 30, 2022 Posts: 643 Location: Southeast
Posted: Wed Feb 01, 2023 1:02 pm Post subject: Re: 71 Beetle engine pull adventure |
Tom K. wrote: |
Speaking of developing good libraries, are you deleting your old photos? Looking through your old posts from just a few months ago, all of your photos appear missing. Why not just leave them to allow future Sambanistas to learn from your questions? |
I haven't deleted any. Just was previously serving them from another space but started putting them on here about midstream, per suggestion of one of you guys.
M |
mg50 Samba Member
Posted: Thu Feb 02, 2023 4:20 pm Post subject: Re: 71 Beetle engine pull adventure |
Removed the c-clip, pulled the gears and now bearing #3 is free.
Feels like a special day. I've gone as deep as I can go and now to turn around and put it all back together.
Rickf1985 Samba Member
Posted: Thu Feb 02, 2023 4:50 pm Post subject: Re: 71 Beetle engine pull adventure |
THAT is an interesting wear pattern! That looks like it was standard bearing on an undersized journal. Was there a dowel in there? It almost looks like the bearing spun. Anyone else? |
Tom K. Samba Member
Joined: March 10, 2005 Posts: 1600 Location: Central Pennsylvania
mg50 Samba Member
Posted: Thu Feb 02, 2023 6:19 pm Post subject: Re: 71 Beetle engine pull adventure |
Rickf1985 wrote: |
Yes, dowel was in place. |
mg50 Samba Member
Posted: Thu Feb 02, 2023 6:20 pm Post subject: Re: 71 Beetle engine pull adventure |
Tom K. wrote: |
Yeah I realize you are skipping the case machining step, but you should at least measure your bores to be sure you are inserting the correct sized bearings. |
I will. |
mg50 Samba Member
Posted: Thu Feb 02, 2023 6:37 pm Post subject: Re: 71 Beetle engine pull adventure |
more shots of bearing 3. Does the VW emblem and number mean that it may be the original bearing?
pmriverrat Samba Member
Joined: October 09, 2021 Posts: 92 Location: West Michigan
Posted: Fri Feb 03, 2023 11:13 am Post subject: Re: 71 Beetle engine pull adventure |
I just pulled down a '71 AE engine that also had what appear o be OE main and rod bearings. The engine was run hard enough the bearing numbers were imprinted in the case. .040 over line bore to clean it up. |
Zundfolge1432 Samba Member
Posted: Fri Feb 03, 2023 12:14 pm Post subject: Re: 71 Beetle engine pull adventure |
If the numbers are pounded into the case you just about be sure it needs to have the line bore done. .040 second cut is OK but also pay attention to lifter bores and cam tunnel. |
Posted: Fri Feb 03, 2023 12:23 pm Post subject: Re: 71 Beetle engine pull adventure |
mg50 wrote: |
Removed the c-clip, pulled the gears and now bearing #2 is free.
Feels like a special day. I've gone as deep as I can go and now to turn around and put it all back together. |
To avoid any confusion the bearing in you picture is #3, number 2 is the split bearing and number 4 is little one next to crank pulley. |
mg50 Samba Member
Posted: Fri Feb 03, 2023 12:49 pm Post subject: Re: 71 Beetle engine pull adventure |
Zundfolge1432 wrote: |
mg50 wrote: |
To avoid any confusion the bearing in you picture is #3, number 2 is the split bearing and number 4 is little one next to crank pulley |
Thanks for that. Someone called it #2 and I didn't know which end you number from.
All the previous bearings were fit snug into their saddles when I first popped out the crank, and the new standard size set seems a proper snug fit when placed on their pins.
I took measure of everything with a caliper and didn't see anything that didn't match up.
mg50 Samba Member
Posted: Fri Feb 03, 2023 2:30 pm Post subject: Re: 71 Beetle engine pull adventure |
I put bearing #3 and the gears on camshaft:
- after checking it out, I slid on bearing #3, offset hole towards flywheel.
- heated gears in a pan with a little oil on a hotplate to about 250 degrees.
- slid on easily without any pounding at all. Timing dots face out.
- put on spacer ring
- distributor gear took a slight tap on a piece of pvc pipe.
- special pliers were required for the c-clip.
mg50 Samba Member
Posted: Fri Feb 03, 2023 2:39 pm Post subject: Re: 71 Beetle engine pull adventure |
Rickf1985 wrote: |
I always use to heat the gears in a coffee can of oil. Once the oil was smoking the gears were hot enough to drop right on. Plus they had oil on them for lubrication. |
worked like a charm |
Posted: Fri Feb 03, 2023 6:38 pm Post subject: Re: 71 Beetle engine pull adventure |
Please don't put that pot back in the house!!!! |
mg50 Samba Member
Posted: Fri Feb 03, 2023 7:09 pm Post subject: Re: 71 Beetle engine pull adventure |
Rickf1985 wrote: |
My cheap camping pot, or else wife would kill me. |
Posted: Sat Feb 04, 2023 7:07 am Post subject: Re: 71 Beetle engine pull adventure |
No longer your camping pot, no more food use. Yea, after I said I used coffee cans I realized how many years ago that was and when was the last time I saw a real coffee "Can". |
mg50 Samba Member
Posted: Sat Feb 04, 2023 4:33 pm Post subject: Re: 71 Beetle engine pull adventure |
Testing the drop rate on the rods with new bearings installed and torqued to 24 lbs. I put a light coat of assembly lube on the bearings but wondering if they should all match in amount of resistance.
video:
Cusser Samba Member
Joined: October 02, 2006 Posts: 31270 Location: Hot Arizona
Posted: Sat Feb 04, 2023 4:44 pm Post subject: Re: 71 Beetle engine pull adventure |
mg50 wrote: |
Looks OK to me.
Note that I never did such "match test" on any of the engines I've built; note that I've only built about six engines, from 1500cc to 1835cc, but none died early.
Others will comment. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9665 Location: Oregon
Posted: Sat Feb 04, 2023 5:04 pm Post subject: Re: 71 Beetle engine pull adventure |
#2 and 4 are a little slow. But that could be due to cold temps.
You did measure the bearings, carefully, right?
Who is the bearing manufacturer? _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9880 Location: Huntington Beach, CA
Posted: Sat Feb 04, 2023 5:10 pm Post subject: Re: 71 Beetle engine pull adventure |
Looks okay. A little slow on the #2 rod. Try swapping it out with one of the other ones.
Try the drop test with a light layer of 30W oil. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
