OCD Garage Samba Member
Joined: May 25, 2020 Posts: 150 Location: British Columbia, Canada
Posted: Sun Dec 04, 2022 8:38 am Post subject: Do all deep sumps fit rear buggy bumpers? |
I want to add a deep sump to my buggy to carry a bit more oil but don't know if they all fit between the lower tubes of a rear buggy cage bumper. Anyone know the width between the lower tubes? Thanks.
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Sun Dec 04, 2022 10:24 am Post subject: Re: Do all deep sumps fit rear buggy bumpers? |
https://www.cbperformance.com/product-p/1770.htm
This Thin Line Mini sump should fit your application.
It's no wider than the engine case.
IIRC, the Baja bumper lower bars pass under the PR Tubes. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
jsturtlebuggy Samba Member
Posted: Sun Dec 04, 2022 11:12 am Post subject: Re: Do all deep sumps fit rear buggy bumpers? |
Here is a SCAT 1-1/2qt sump on my buggy. The Scat sumps fit closer to case for more ground clearance. This buggy get used off road with a skid plate.
The wider sumps that hold 3-1/2qts like what Gene Berg sells can interfere with some rear bumper cages _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
oprn Samba Member
Joined: November 13, 2016 Posts: 12740 Location: Western Canada
Posted: Sun Dec 04, 2022 5:02 pm Post subject: Re: Do all deep sumps fit rear buggy bumpers? |
I have that exact cage on my street Buggy. A sump would definitely fit between but it would hang down below. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Posted: Sun Dec 04, 2022 5:30 pm Post subject: Re: Do all deep sumps fit rear buggy bumpers? |
I'd like to add a deep sump on my air ride buggy build which has a 3" motor lift, it doesn't matter if it hangs a bit bellow the cage/bumper but I don't want to use the smallest sump either if I don't have to. What is the inside width of those lower tubes? The kit I was considering holds 1.5 quarts and is 10"W x9"L x2.75"D. https://www.cip1.ca/acc-c10-5974/
Posted: Sun Dec 04, 2022 6:25 pm Post subject: Re: Do all deep sumps fit rear buggy bumpers? |
The best quality oil sump there is are the ones from Gene Berg. Made in America.
They are the strongest and will take a hit if you bottom out on the street.
Plus with the mounting hardware supplied you don’t have mess with changing studs.
I broke a cheap sump going up a hill in San Diego in 1973. No fun removing it in motel parking lot.
As with everything else from Empi, beware of cheap quality and casting flaw’s. _________________ Joseph
Elrod Motorsports
Posted: Sun Dec 04, 2022 7:31 pm Post subject: Re: Do all deep sumps fit rear buggy bumpers? |
This Scat version from Cip1 looks to be the same as yours, specs check to be 2.75" tall which is the same as the Empi one. I'm sure this would do nicely, but unfortunately no one has stock.
Posted: Sun Dec 04, 2022 8:38 pm Post subject: Re: Do all deep sumps fit rear buggy bumpers? |
I have bought my SCAT sumps directly from SCAT. Yes it did take several weeks to receive.
I always call Scat first before ordering to find out the lead time if something is not in stock.
The reason I an using a Scat sump is because buggies are used off road and fit tight against the case for ground clearance. If I used a Berg it would set further away from bottom of case and lose ground clearance.
Scat sumps are made in the USA and sealed against leakage. _________________ Joseph
Elrod Motorsports
slalombuggy Samba Member
Posted: Sun Dec 04, 2022 9:03 pm Post subject: Re: Do all deep sumps fit rear buggy bumpers? |
Both my Berg and CB 4qrt sumps fit on my buggy with that same bumper. They did hang below it though. |
Posted: Mon Dec 05, 2022 7:39 am Post subject: Re: Do all deep sumps fit rear buggy bumpers? |
Thanks for the info guys. I contacted Cip1 with these questions but as always, never heard back from them. |
