chrmcc Samba Member
Joined: April 29, 2022 Posts: 24 Location: Houston, TX
Posted: Sun Dec 04, 2022 10:02 am Post subject: Front door seals 78 Bay Window |
I replaced the seals on my 78 bay window about a month ago. I used the cheaper Brazilian seals from JBugs. Both are tight but passenger door is hard to open/close, sticks when opening. I kind of expect that with new seals and expect it might get motive over time. However, they both have caused my bus to whistle at speeds above 45mph. I verified it’s the doors, I put masking tape over the exterior leading and top edge and voila, quite. Couple questions. Does the group believe this will improve as they break in? Should I have opted for the more expensive German seals, are they that much better a fit? 😒
Thanks!
SGKent Samba Member
Posted: Sun Dec 04, 2022 10:06 am Post subject: Re: Front door seals 78 Bay Window |
there are hundreds if threads here about the problems with some seal brands. Here is the most recent solution.
https://www.thesamba.com/vw/forum/viewtopic.php?t=771787 _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Bleyseng Samba Member
You should have bought the German seals as they fit and work great _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
chrmcc Samba Member
Posted: Sun Dec 04, 2022 10:16 am Post subject: Re: Front door seals 78 Bay Window |
Thanks, I did search a bit prior to posting but found mixed reviews even on the German seals. I did not find the thread you shared, it mentions Airhead’s seals, they sound promising. I suspect the German seals would be an improvement. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Sun Dec 04, 2022 2:21 pm Post subject: Re: Front door seals 78 Bay Window |
I removed my German door seals and installed the airhead seals. The door closes better now. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
