1965 Rear Carpet to Headliner Glued?
DesertG
DesertG is offline
PostPosted: Sun Dec 04, 2022 10:43 am    Post subject: 1965 Rear Carpet to Headliner Glued? Reply with quote
Hello Guys, the prior owner replaced the carpet and headliner. The back carpet is glued to the headliner (and falling apart). Is this correct. Is there a better way to do this. Thank you.
1965 Beetle, 1970 1600cc DP 60HP, 12v
61SNRF
61SNRF is offline
PostPosted: Sun Dec 04, 2022 4:14 pm    Post subject: Re: 1965 Rear Carpet to Headliner Glued? Reply with quote
From stock the carpet is longer and the end is unfinished.
It rolls over the edge of the firewall and tucks into the crevice as does the end of the perforated headliner, then a piece of ~8 mm cording gets pushed in to hold them tight.
-Bruce
An ounce of prevention is worth a pound of cure.
DesertG
DesertG is offline
PostPosted: Sun Dec 04, 2022 4:48 pm    Post subject: Re: 1965 Rear Carpet to Headliner Glued? Reply with quote
Thank you. My carpet looks to have a finished edge. How do you think I can easily fix this. Do people use screws.
carcrazed
carcrazed is offline
PostPosted: Sun Dec 04, 2022 6:38 pm    Post subject: Re: 1965 Rear Carpet to Headliner Glued? Reply with quote
On both of my bugs I glued that portion on. Haven't had an issue with it peeling back off. My 65 was installed in 1998.
1965 Herbie Replica. 1776cc dual Kads.
1961 Beetle 33,000 Original Miles
"Just When you think you are getting ahead, you're always wrong."
DesertG
DesertG is offline
PostPosted: Mon Dec 05, 2022 7:20 am    Post subject: Re: 1965 Rear Carpet to Headliner Glued? Reply with quote
Thank you. What did you glue it with.
Rome
Rome is offline
PostPosted: Mon Dec 05, 2022 7:29 am    Post subject: Re: 1965 Rear Carpet to Headliner Glued? Reply with quote
In 2013 I was lucky to view the red '65 Sedan seen here at Classic VW Bugs' shop in person. All original, ca. 8000 miles! Here are some close-ups of the rear carpet and headliner sections.
More photos: http://www.classicvwbugs.com/65rubyoriginal/#
DesertG
DesertG is offline
PostPosted: Mon Dec 05, 2022 7:34 am    Post subject: Re: 1965 Rear Carpet to Headliner Glued? Reply with quote
Thank you. That looks nice. I don't think I can undo what I have at this point.
61SNRF
61SNRF is offline
PostPosted: Mon Dec 05, 2022 1:49 pm    Post subject: Re: 1965 Rear Carpet to Headliner Glued? Reply with quote
Is your carpet not long enough to roll over and tuck in?
Is it glued down firmly? If it is loose perhaps you can undo it from the floor/firewall so you can pull it up and bias more material towards the top.
-Bruce
DesertG
DesertG is offline
PostPosted: Mon Dec 05, 2022 1:52 pm    Post subject: Re: 1965 Rear Carpet to Headliner Glued? Reply with quote
Thanks Bruce. I will look to see if I have slack. If I can roll if over, how to I secure it. Not necessarily looking for "correct" but easy and quick.
61SNRF
61SNRF is offline
PostPosted: Tue Dec 06, 2022 7:04 am    Post subject: Re: 1965 Rear Carpet to Headliner Glued? Reply with quote
As said stock it is long enough to roll over the edge and get wedged into the slot with a piece of cord. I suggest try that first if you can get an extra inch or two.
If you don't have cording try rope or a rolled up cloth of a discrete color.
If you can't get an extra inch or two then?
-Bruce
61SNRF
61SNRF is offline
PostPosted: Tue Dec 06, 2022 8:36 pm    Post subject: Re: 1965 Rear Carpet to Headliner Glued? Reply with quote
Idea Here's an idea.
Pull the top of the carpet down five or six inches.
Tip: If it's glued, and it's closed loop carpet, be VERY carefull not to unravel as you go.
Cut a 6" by what ever the total width of the carpet/firewall is strip of heavy fabric (old denim might do well).
Lenghwise stitch 4" of it to the carpet, with like colored thread, on the top edge of the carpet so as to extend the carpet's end by 2" or so.
Like this now you have a heavy fabric tail you can wedge into the crevasse so to hold the carpetup firmly, and like that should also finish off the bottom edge of the window headliner piece too.
-Bruce
DesertG
DesertG is offline
PostPosted: Tue Dec 06, 2022 8:37 pm    Post subject: Re: 1965 Rear Carpet to Headliner Glued? Reply with quote
Thanks Bruce. I will hit it this weekend.
hitest
hitest is offline
PostPosted: Wed Dec 07, 2022 1:22 pm    Post subject: Re: 1965 Rear Carpet to Headliner Glued? Reply with quote
If you have time to investigate using screws(!) you have time to pull that one simple piece of carpet and just do it right. The hard part of this thread to read is that you asked for the right way to do it but then say, "Not necessarily looking for "correct" but easy and quick."
If the carpet is pulling away from the headliner so easily- it must not be thoroughly glued down. Therefore it should pull out easily with the back seat removed.
The seal around your rear window needs the lower edge pulled properly- easily done with a warm garage and a hook tool.
FU#5
DesertG
DesertG is offline
PostPosted: Wed Dec 07, 2022 2:29 pm    Post subject: Re: 1965 Rear Carpet to Headliner Glued? Reply with quote
Thank you. The nature of my comment was I don't want to open up a can of worms with the headliner. I don't have the money to hire someone to replace it.
