volvofan94 Samba Member
Posted: Sun Dec 04, 2022 2:16 pm Post subject: VW Buggy Transmission on Opposite Day |
Hey All,
My Buggy project has come along nicely, but ran into an issue with my transmission where reverse gear moves the car forward and the forward 1-4 gears move the car backwards. It’s Opposite Day!
How do I fix this? I’m hoping the transmission doesn’t need to be removed, but at this point it’s wishful thinking. No grinding when selecting gears and the shift linkage underwent a complete overhaul. When the car moves I don’t hear grinding noises in either direction.
The transmission is a swing axle and I removed material from the bell housing to fit an engine from a 1970 Beetle (6v to 12v flywheel conversion).
Thanks! |
jsturtlebuggy Samba Member
Posted: Sun Dec 04, 2022 2:31 pm Post subject: Re: VW Buggy Transmission on Opposite Day |
It sound like ring gear has been flopped to other side of pinion.
With a VW type 1 transaxle this was done to use a reverse rotation engine such as a Corvair.
VW also did this with Bus transaxles that used reduction boxes.
What this history of the transaxle?
Fixing it requires disassembly of transaxle. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9755 Location: Oregon
Posted: Sun Dec 04, 2022 3:53 pm Post subject: Re: VW Buggy Transmission on Opposite Day |
jsturtlebuggy wrote: |
Fixing it requires disassembly of transaxle. |
Totally agree.
I had a high school mate that had his Baja trans rebuilt.
The builder installed the R&P on the opposite side.
Result? 1 forward and 4 reverse gears.
The mechanic fixed it in a day. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76897 Location: Sneaking up behind you
Posted: Sun Dec 04, 2022 3:55 pm Post subject: Re: VW Buggy Transmission on Opposite Day |
Yup... it was setup for a mid engine. So by putting it in a rear engine car you need to flip the diff/ring gear.
Not as easy as it sounds. _________________ Glenn
Member #1009
#BlueSquare |
oprn Samba Member
Joined: November 13, 2016 Posts: 12704 Location: Western Canada
Posted: Sun Dec 04, 2022 4:58 pm Post subject: Re: VW Buggy Transmission on Opposite Day |
Or it was rebuilt for a split window Bus or VW Thing... _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Glenn Mr. 010
Posted: Sun Dec 04, 2022 5:07 pm Post subject: Re: VW Buggy Transmission on Opposite Day |
oprn wrote: |
Or it was rebuilt for a split window Bus or VW Thing... |
Did Things have RG? _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sun Dec 04, 2022 6:07 pm Post subject: Re: VW Buggy Transmission on Opposite Day |
VW Things Type 181 in USA only, in 1973-74 had IRS rear suspension.
The Type 181 Safari made in Mexico and sold outside the USA came with swingaxle and reduction boxes. _________________ Joseph
Elrod Motorsports
Posted: Sun Dec 04, 2022 10:17 pm Post subject: Re: VW Buggy Transmission on Opposite Day |
I agree with you too, thanks for the suggestion! Honestly, until I saw your post, I forgot the seller mentioned already converting the transmission to run a Corvair engine when I purchased the Buggy. My plan was to run my VW engine, so I didn’t give it a second thought. Lol.
Now to get the transmission repaired to work with my VW engine. Appreciate everyone’s help!
Thanks! |
