viiking Samba Member
Joined: May 10, 2013 Posts: 2668 Location: Sydney Australia
Posted: Sun Jan 08, 2023 2:58 pm Post subject: Re: fuel gauge ball |
Emeraldlion wrote: |
Maybe you could get a small lead fishing pinch weight? Pinch to the end of the cable and cut it down small enough to fit in the spot. It isn't exactly a round ball but more a short squatty cylinder type shape. |
Hey! You know lead was banned in fuel years ago! _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
bnam Samba Member
Joined: July 02, 2006 Posts: 2936 Location: El Dorado Hills CA/ Bangalore, India
Posted: Sun Jan 08, 2023 9:19 am Post subject: Re: fuel gauge ball |
Were you able to fix it? What worked? _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
rafito Samba Member
Posted: Tue Dec 06, 2022 6:34 pm Post subject: Re: fuel gauge ball |
heimlich wrote: |
It's a mechanical type pump. The float pushes and pulls on the wire that goes to the gauge. You need to fix it so that it has something to grab onto in order to push and pull on that wire. |
Thanks! |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6620 Location: Houston, Texas
Posted: Tue Dec 06, 2022 3:02 pm Post subject: Re: fuel gauge ball |
It's a mechanical type pump. The float pushes and pulls on the wire that goes to the gauge. You need to fix it so that it has something to grab onto in order to push and pull on that wire. _________________ www.vwnos.com [email protected]
rafito Samba Member
Posted: Tue Dec 06, 2022 1:04 pm Post subject: Re: fuel gauge ball |
bnam wrote: |
Here’s an idea: I think the function of the ball is just to provide something to grip the cable and pull it. Get a blind pop rivet that has a stem that is close in dia to the cable. Pull the stem out of the rivet. Insert the rivet onto the cable - flange end first and then crimp the rivet to the cable. This should enable the sender unit to grip the end of the cable.
I.ve not done this on a fuel gauge but I’ve used this approach successfully to repair the cable on a Mercedes convertible whose top cable had lost it’s end. |
thanks for the idea |
rafito Samba Member
thanks a lot |
bnam Samba Member
Posted: Tue Dec 06, 2022 8:55 am Post subject: Re: fuel gauge ball |
I.ve not done this on a fuel gauge but I’ve used this approach successfully to repair the cable on a Mercedes convertible whose top cable had lost it’s end. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
Emeraldlion Samba Member
Joined: April 13, 2005 Posts: 743 Location: Texarkana, TX
Posted: Mon Dec 05, 2022 7:29 am Post subject: Re: fuel gauge ball |
Maybe you could get a small lead fishing pinch weight? Pinch to the end of the cable and cut it down small enough to fit in the spot. It isn't exactly a round ball but more a short squatty cylinder type shape. _________________ 1967 Sunroof Beetle: tourist pass car
1961 SWR Kombi |
rafito Samba Member
Posted: Sun Dec 04, 2022 7:19 pm Post subject: fuel gauge ball |
Hi, we have our grandfathers vw beetle 1962, the fuel gauge stop working (it is a magura ), we looked and this time the ball detached from the cable. there is not a single piece of cable on the ball, is there a chance we can restore it? someone knows how to do it?
thanks a lot |
