Renowestfalia Samba Member
Posted: Sun Dec 04, 2022 7:51 pm Post subject: AFM connector |
I found this Afm connector with this wire pulled out of the plug and the others are brittle. Would this make the van run like crap? Also where about a could I buy a good engine harness or individual plugs like the AFM plug? Thanks in advance
zimflux Samba Member
Posted: Sun Dec 04, 2022 8:19 pm Post subject: Re: AFM connector |
Yes. Lots of discussions on this here If you take the time to search. _________________ 84 1.9 Westy |
shadetreemech Samba Member
Joined: October 05, 2005 Posts: 777 Location: Claremont, CA
Posted: Sun Dec 04, 2022 11:18 pm Post subject: Re: AFM connector |
Search the Classifieds on The Samba for parts. Search the Forum for specific words. "Title Only' simplifies your search. _________________ '84 GL 1.9
'01 Volvo V70 T5
'88 Westy - "MZDRTHY" |
t3 kopf Samba Member
Joined: October 22, 2012 Posts: 1115 Location: over by 'der
Posted: Mon Dec 05, 2022 5:19 am Post subject: Re: AFM connector |
Someone has been in there before. Those little orange boots are not stock for that connector. You dont need a new plastic connector as long as it isnt cracked or damaged. You need to re-pin those wires. Here is a link for instructions on how to do that. The pins you need are part number: A107135CT-ND
https://www.thesamba.com/vw/forum/viewtopic.php?t=619007 _________________ '90 Carat w/ '95 phase 1 EJ22 OBD2 conversion |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Mon Dec 05, 2022 6:01 am Post subject: Re: AFM connector |
It might be a vanagon syndrome harness that someone made that plugs in between the air flow sensor and the stock harness. I can’t tell from your picture. _________________ ☮️ |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4353 Location: United States, Iowa
Posted: Mon Dec 05, 2022 7:41 am Post subject: Re: AFM connector |
MarkWard wrote: |
It might be a vanagon syndrome harness that someone made that plugs in between the air flow sensor and the stock harness. I can’t tell from your picture. |
I agree, there is a hint of another portion of the connection toward the top of the photo which almost suggests that the connector with the strange orange boots and loose wire is hooked to another plug. If that is the case, and you have a segment of the harness that can be removed, try removing that and plug the connector that is not the 'Jumper' directly to the AFM. Then, if indeed that is a 'home built VANAGON Syndrome' harness, you can either find a real one, or do the AFM hack with a tantalum capacitor.
https://www.thesamba.com/vw/forum/viewtopic.php?p=9083845 _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6361 Location: Honolulu,Hawaii and France
