DesertG Samba Member
Posted: Mon Dec 05, 2022 7:17 am Post subject: Positive Battery Cable Options |
Hi Guys, my 12v 65 with a 1970 1600 needs a new battery cable. The voltage regulator is in the engine compartment.
I see a new positive battery cable with a second red wire for the voltage regulator. Is this for when the regulator is mounted under the seat. Could that extra red wire go out the grommet to the voltage regulator in the engine compartment.
Or, how would you wire this up.
Thank you! _________________ 1965 Beetle, 1970 1600cc DP 60HP, 12v |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Mon Dec 05, 2022 10:26 am Post subject: Re: Positive Battery Cable Options |
Get the battery cables for your year of VW from Wolfsburg West. Yes, get both of them, WW makes them just like the original factory ones and they are superior to any you would buy elsewhere. Plus as long as you do not over tighten the clamps, the WW brass battery clamps will long outlast the cheap lead clamps everyone else sells.
Would use the stock positive cable in the engine compartment wiring harness to connect the regulator to the rest of the wiring system. _________________ In Stereo, Where Available! |
Posted: Mon Dec 05, 2022 4:32 pm Post subject: Re: Positive Battery Cable Options |
Thank you Eric. _________________ 1965 Beetle, 1970 1600cc DP 60HP, 12v |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Mon Dec 05, 2022 6:45 pm Post subject: Re: Positive Battery Cable Options |
Eric&Barb wrote: |
Get the battery cables for your year of VW from Wolfsburg West. Yes, get both of them, WW makes them just like the original factory ones and they are superior to any you would buy elsewhere. Plus as long as you do not over tighten the clamps, the WW brass battery clamps will long outlast the cheap lead clamps everyone else sells. |
Agree; don't get cheap, not worth it ! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
