74 Thing Samba Member
Posted: Fri Dec 09, 2022 2:39 pm Post subject: Re: Cam Gear Install in Situ? |
If you are running straight cuts I would run these CB ones (not the Pro Series) or the Magnum which I know RLR had them at one point
https://www.cbperformance.com/product-p/1399.htm
Check the gear backlash at 4 different points on the can gear 90 degrees apart when doing mock up/assembly. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Fri Dec 09, 2022 4:27 pm Post subject: Re: Cam Gear Install in Situ? |
74 Thing wrote: |
Curious.
Why don't you recommend the Pro series cam gear set?
I have a set and they seem to work as advertised.
I have heard that the Magnum straight cut gears are the quietest of them all. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Fri Dec 09, 2022 4:30 pm Post subject: Re: Cam Gear Install in Situ? |
My pro set was loud…whine not rod like noise
1399’s are quiet |
Posted: Fri Dec 09, 2022 5:10 pm Post subject: Re: Cam Gear Install in Situ? |
Pro series is loud! |
Posted: Fri Dec 09, 2022 5:26 pm Post subject: Re: Cam Gear Install in Situ? |
74 Thing wrote: |
At full throttle. The roar of the 45 Dells are louder than the cam gears!
But I get the idea. I have a set of EMPI straight cuts that are kinda quiet.
But I prefer the "racer spacer" crank timing gear, compared to the VW spacer ring. _________________ I have learned over the years.
Buy Once, Cry Once!
txoval Samba Member
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Fri Dec 09, 2022 7:14 pm Post subject: Re: Cam Gear Install in Situ? |
74 Thing wrote: |
My observation is that the quality control on the pro series is all over the place. Not concentric with the center of the cam has been the issue several times I am aware of. That'll make it loud for sure _________________ modok wrote:
allamaabroad Samba Member
Joined: September 22, 2016 Posts: 560 Location: South Jordan, Utah
Posted: Fri Dec 09, 2022 10:02 pm Post subject: Re: Cam Gear Install in Situ? |
I actually really love the way that sounds...A loud set of cam gears just sounds like a hopped up VW to me.
Put in the order for pro series gears today, I will be sure to check lash in multiple places and do what I can to check concentricity out of the box.
Just want to get rid of the clattering of this gear set _________________ Dennis - 1973 Super Beetle ('16-'21)
Debbie- 1970 Baywindow Bus ('21 - Present)
Tin top camper/adventure bus
2180 TW: CNC Panchitos, Beehives Done Right, Web 163, Ultralight Lifters, 1.3 Rockers, CSP Python, Custom Speeduino EFI Conversion with 40mm Throttle Bodies
Distributors are lame
I have a really hard time leaving things alone...
Innovative and affordable engine management systems and EFI conversions for your Vintage VW
Visit https://debbiesaircooled.com/ |
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Posted: Sat Dec 10, 2022 7:17 am Post subject: Re: Cam Gear Install in Situ? |
I Like to use OG mag gears; I can get the size I need and with using double copper face thrust cam brgs the setup does not wear out with any street spring. I keep re-using the NLA copper thrust brgs as they don't wear out. I also like using the 36hp/356/912 gears if I can find the size I need without it costing an arm and leg.
All that racket on Ricks car I could never live with. I would love for someone to engineer a reasonably priced intake air box to reduce the intake noise of the VW dual carb setup. The worst intake noise I have ever had on all the engines I built was with IDA's.
I guess I just don't like noise and would be embarrassed if other hear my engines sounding like that. I guess I take a lot of pride in my engine building.
If I were to build a trailered Drag car, I would use straight cuts. |
txoval Samba Member
Posted: Sat Dec 10, 2022 7:48 am Post subject: Re: Cam Gear Install in Situ? |
Just admit that you’re getting old Dan😂, I’m joking so don’t get mad
Most straight cut gears aren’t that loud and actually the Pro Series are the only ones I’ve had that are.
Running an A-1 race muffler wouldn’t be quiet on any engine |
Posted: Sat Dec 10, 2022 8:21 am Post subject: Re: Cam Gear Install in Situ? |
txoval wrote: |
Yes I am getting old but I have always liked quiet but potent engines. I sure have to see doctors more than I care for. I do like a good sounding exhaust and the A1 would not be my choice. |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7551 Location: Santa Cruz
Posted: Sat Dec 10, 2022 6:36 pm Post subject: Re: Cam Gear Install in Situ? |
allamaabroad wrote: |
Just want to get rid of the clattering of this gear set |
You sure it's not clacking??
_________________ Bus Motor Build
What’s That Noise?!? |
