Dual Single Barrel Carburetors with Electric Choke options?
volvofan94
volvofan94 is offline
PostPosted: Tue Dec 06, 2022 2:32 pm    Post subject: Dual Single Barrel Carburetors with Electric Choke options? Reply with quote
Hey All,
On my Buggy I'm using dual single barrel EMPI EPC-34's through a center pull low style throttle linkage. The carburetors don't have an electric choke which makes cold starting in cooler temps a bit of a challenge. The engine does start and runs well once warmed up.
Eventually I want to replace them with carburetors with an electric choke but can't seem to find a model that works with the linkage / intake setup.
What options would you recommend?
About the engine:
- VW 1600cc with EMPI twin port heads
Thanks!
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Tue Dec 06, 2022 3:23 pm    Post subject: Re: Dual Single Barrel Carburetors with Electric Choke options? Reply with quote
CB Performance has 34mm Solex dual carb kits with chokes.
Both Empi and Scat use to have them in their catalogs, nothing now, appears CB is the only ones.
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
volvofan94
PostPosted: Tue Dec 06, 2022 4:04 pm    Post subject: Re: Dual Single Barrel Carburetors with Electric Choke options? Reply with quote
Thanks for the reply, this would be exactly what I'm looking for!
Sadly CB Performance didn't have stock, hopefully they're back in stock soon.
What are the part numbers on the carburetors? Maybe there's a set for sale without the kit. Have everything else, minus the carburetors.
Dale M.
Dale M. is offline
PostPosted: Tue Dec 06, 2022 8:22 pm    Post subject: Re: Dual Single Barrel Carburetors with Electric Choke options? Reply with quote
Check Classified...
https://www.thesamba.com/vw/classifieds/
“Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
63beryl
63beryl is offline
PostPosted: Mon Dec 12, 2022 5:06 pm    Post subject: Re: Dual Single Barrel Carburetors with Electric Choke options? Reply with quote
I have a set of barely used kadrons with chokes, I'd consider letting go of. If you're interested, I'll post a few pictures.
63beryl
63beryl is offline
PostPosted: Tue Dec 13, 2022 2:32 pm    Post subject: Re: Dual Single Barrel Carburetors with Electric Choke options? Reply with quote
$375 shipped. These were new 4 years ago. Only run long enough to break in the cam. The buggy then sat in a garage for 3 years until I purchased it last year.
