phoenixragtop Samba Member
Semper_Dad Samba Member
Posted: Sun Dec 18, 2022 8:00 pm Post subject: Re: Thing shop accelerator cable |
Don't seen to recall any sleeve on the cables I've purchased from them before.
May be useful on the other end as an anti-chafing device as it enters the tunnel. I'll have to check my spares tomorrow. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
SilverThing Samba Member
Posted: Sun Dec 18, 2022 10:50 pm Post subject: Re: Thing shop accelerator cable |
That is a bit of a head-scratcher. I doubt that little sleeve would make it all the way to the carb if pushed in and I wonder what it would actually be accomplishing on the pedal end besides potentially getting hung up on the entrance to the tunnel tube.
As a somewhat related side-note, my 1975 Beetle uses a cable that has a plastic sleeve almost the entire length (the cable can slide back and forth in the sleeve a couple inches). I don't care for that design because the sleeve tends to get hung up in installation where plain cables do not. That sleeved cable broke last weekend on me (after 10 years of use) and I fought trying to get a new sleeved cable to go back in and gave up after multiple attempts and some choice words. Did I mention that it was cold and raining? Thankfully, the cable broke while backing down the driveway, but unfortunately left me having to work on it without cover. I ended up installing Scat's super duty throttle cable, which I had intended to install in my Thing. It went in very smoothly (with lots of grease) and I am quite pleased with it. It is much smoother than the sleeved cable I had previously. My only minor complaint with the Scat cable is the pedal connection requires a small bolt and nut (from aircooled.net), which i dropped in the pedal cluster multiple times trying to install. _________________ "I like how everyone likes talking about Zeke's Thing yet he's the only one that's ever seen it." - Katie
"I've seen pictures..." - Jeremy |
Joe 20 Samba Member
Posted: Mon Dec 19, 2022 8:46 pm Post subject: Re: Thing shop accelerator cable |
Maybe you could call them and ask them. _________________ "Someday the world is gonna be populated by nothing but Volkswagens'" Corporal Klairvoy |
germansupplyscott Samba Member
Posted: Tue Dec 20, 2022 12:13 am Post subject: Re: Thing shop accelerator cable |
The sleeves like this are normally found on GEMO brand cables and are stamped with manufacturer part numbers. Something like "430 257" (I just made those numbers up but GEMO seems to use a 6-digit part number in this format)
Here's a GEMO cable with the sleeve (Bus cable but GEMO cables always have this). GEMO make the best quality cables so this sleeve means the cable is good!
_________________ SL |
