Nacho_74 Samba Member
Joined: March 22, 2018 Posts: 53 Location: Norwalk,California
Posted: Mon Dec 19, 2022 10:16 am Post subject: Grafting sunroof on 66 beetle |
Hi
Working on getting the courage to welding in an original sunroof on my 66 bug. I've been welding for well over 20 years but I don't consider myself an expert but I'm pretty decent!
I recently acquired a complete donor sunroof for my installation. My plan is to use the front windshield flange as means for correct installation location. What I'm not 100% sure of is if I should use the rear window flange as well and just make full butt welds seams front to back on each side? Or should I just go a few inches past the rear of the sunroof and butt weld across? My preference is to butt weld front to rear and then plug weld the flanges at the front & rear.
Thoughts?
Thanks
viiking Samba Member
Joined: May 10, 2013 Posts: 2668 Location: Sydney Australia
Posted: Mon Dec 19, 2022 4:52 pm Post subject: Re: Welding in Sunroof |
If understand you correctly, my only concern is to maintain the correct windscreen hole dimensions. Nothing worse than doing a great job only to find the glass won't fit.
Cutting steel is easier than modifying glass. However if you can make a wooden template exactly the same as the glass opening then you could do it the proposed way.
If I were doing it, I would measure very accurately many times and install the whole sunroof section a few inches bigger than the "sunroof aperture in the roof and weld around the perimeter on that section. Just have to deal with distortion but you have full access to the backside for hammer and dolly work as you weld.
Just my opinion. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
Posted: Mon Dec 19, 2022 6:34 pm Post subject: Re: Welding in Sunroof |
Thanks for the reply viiking
I don't plan on cutting the structure behind the sheet metal on the windshield, only plan on drilling out the spot welds and then slice the upper layer free.
Once I get going with this sunroof swap I'll start posting progress pictures with comments. |
Posted: Mon Dec 19, 2022 8:01 pm Post subject: Re: Welding in Sunroof |
Then I misunderstood. But the sentiment still applies. Make sure the window opening does not shrink when reattaching the roof skin. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9967 Location: Huntington Beach, CA
Posted: Tue Dec 20, 2022 9:05 am Post subject: Re: Welding in Sunroof |
“Sunroof”, as in a hard steel hatch that slides back under the roof? Or are we talking about a rag top? 2 different methods, similar but a little different. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
infiniteLoop Samba Member
Joined: October 09, 2020 Posts: 265 Location: Empire State
Posted: Tue Dec 20, 2022 11:13 pm Post subject: Re: Welding in Sunroof |
If a flange is made on a crowned panel it is going to straighten out the crown. |
tzepesh Samba Member
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Wed Dec 21, 2022 5:53 am Post subject: Re: Welding in Sunroof |
If your'e putting a ragtop roof on a later car, you cannot use the windshield as a guide; The windshield size changed in 65 _________________ modok wrote:
Posted: Wed Dec 21, 2022 8:04 am Post subject: Re: Welding in Sunroof |
VW_Jimbo wrote: |
“Sunroof”, as in a hard steel hatch that slides back under the roof? Or are we talking about a rag top? 2 different methods, similar but a little different. |
Hi VW Jimbo,
Hard steel sunroof that slides back under the roof. I think the rigidity of the sunroof structure will significantly help keep the original curvature of the roof under control while welding. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Wed Dec 21, 2022 2:24 pm Post subject: Re: Welding in Sunroof |
Don't try to weld all the pillars!
Cut the assembly out of the roof crown and weld it in. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Thu Dec 22, 2022 7:52 am Post subject: Re: Welding in Sunroof |
Mike Fisher wrote: |
Cut the assembly out of the roof crown and weld it in. |
Interesting way of going about it Mike! if I'm understanding you correctly, this could possibly cut the welding by half. I would also save 80% of my original roof which is in perfect condition. Hmm... |
Posted: Thu Dec 22, 2022 9:47 am Post subject: Re: Welding in Sunroof |
Here's what I think you were mentioning I do. I don't think the pocket is actually welded to the underside of the roof skin. I believe its only held in place by the support brackets and then there's a rubber seal that is pinched between the roof skin and pocket lip. If it pans out this way, I really like this way of grafting in the sunroof.
Now I'm motivated to start but I'm stuck at work!
capedave Samba Member
Posted: Thu Dec 22, 2022 12:40 pm Post subject: Re: Welding in Sunroof |
Look under you have to take the tray and drains, plus fish the drains out the bottom of car, |
Posted: Thu Dec 22, 2022 5:13 pm Post subject: Re: Welding in Sunroof |
So I got home and verified that it will work. I plan on separating the sunroof by cutting along the inner edge of the blue tape. Then drill out the spot welds on the front windshield and then drill out the spot welds on the support brackets from the underside.
Posted: Tue Dec 27, 2022 7:00 pm Post subject: Re: Welding in Sunroof |
Cut the sunroof out today.
Created a template from the cut sunroof for reference on the body
Enough measuring....time to cut with my CNC hand grinder
Inserted the sunroof into the precision CNC hole. Sunroof has 1 inch of extra metal around the entire edge. Later I'll add some spot welds around the sunroof and then make a nice clean cut through both pieces of metal for a nice clean edge for butt welding.
Posted: Wed Dec 28, 2022 9:29 pm Post subject: Re: Welding in Sunroof |
Very nice job cutting & fitting! _________________ https://imgur.com/user/FisherSquareback/posts
Kafer_Mike Samba Member
Joined: June 23, 2004 Posts: 348 Location: Noblesville, IN
Posted: Thu Dec 29, 2022 6:58 am Post subject: Re: Welding in Sunroof |
Lookin' good. I like your approach. _________________ Kafer_Mike
Build 'em fast...or let 'em sit. |
Posted: Thu Dec 29, 2022 4:56 pm Post subject: Re: Welding in Sunroof |
Thanks So far everything is going to plan...if it wasn't raining so much here in SoCal I would finish cutting & fitment. I don't like to cut and grind inside my garage, it makes to much of a mess and I have two other cars in the garage. More to come... |
Posted: Mon Jan 23, 2023 8:07 am Post subject: Re: Welding in Sunroof |
Update to the sunroof install now that it finally stopped raining. I was able to do my final cut around the perimeter. Next is to strip and epoxy coat the structural area of the sunroof itself. VW doesn't apply and coatings to the inside prior to installation so there's surface rust. Also, discovered my original roof wasn't in perfect condition, found body filler and some waves in the rear half. oh well!
Deburred edge
Rear edge
Driver side
Posted: Mon Feb 20, 2023 8:44 am Post subject: Re: Grafting sunroof on 66 beetle |
Progress update
Used OSPHO and a lot of elbow grease to get the rust removed from the bucket.
Epoxy primed the bucket. I thought about painting it but nah...
Getting everything lined up for tacking in place
Tacking done
Next will be a lot of tack welding and jumping around to keep the metal from getting to hot. |
