2Dokas Samba Member
Joined: October 09, 2004 Posts: 752 Location: Santa Cruz, CA
Posted: Mon Dec 19, 2022 6:26 pm Post subject: Leaking carb |
after the first drive I noticed this
gas leaking out of the throttle bit.
hmmm, any suggestions?
Know I have the wrong bolt but it works for now!
_________________ 87 Doka 2WD Ej22,
56 Convertible |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76889 Location: Sneaking up behind you
Posted: Mon Dec 19, 2022 6:30 pm Post subject: Re: Leaking carb |
Probably needs to have the shaft bushed.
aka... rebuilt _________________ Glenn
Member #1009
#BlueSquare |
2Dokas Samba Member
Posted: Wed Dec 21, 2022 6:43 pm Post subject: Re: Leaking carb |
Glenn wrote: |
aka... rebuilt |
I dont recall any shaft bushing when I rebuilt it years ago.
Not part of the usual rebuild kit?
Peter _________________ 87 Doka 2WD Ej22,
56 Convertible |
esde Samba Member
Joined: October 20, 2007 Posts: 5965 Location: central rust belt
Posted: Wed Dec 21, 2022 7:14 pm Post subject: Re: Leaking carb |
The steel shaft wears the bore in the alloy carburetor body. You can either machine the carb body for a brass bushing that corrects the wear, or ream the carburetor body for an oversize throttle shaft
https://www.thesamba.com/vw/classifieds/detail.php?id=1929455
What you see is the gas leaking out, what you don't see is the air leaking in. When this gets bad it can drive you nuts if you don't know you have an air leak. _________________ modok wrote:
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24732 Location: Olympia Wash Rinse & Repeat
Posted: Wed Dec 21, 2022 9:19 pm Post subject: Re: Leaking carb |
Throttle shaft is NEVER totally sealed even back when the carb was brand new. With engine running there is always a little air being sucked thru there. With engine running, fuel is kept inside due to the air being sucked in. On the other hand when the engine is shut off and the butterfly valve is closed, any fuel that drips down the throat of the carb will spread out on the flat of that valve and leak out of the throttle shaft.
Big question now is if the fuel seep or drip is there with engine idling or only shows up when engine is shut off. Can take several minutes for the latter to show. _________________ In Stereo, Where Available! |
2Dokas Samba Member
Posted: Fri Dec 23, 2022 8:56 am Post subject: Re: Leaking carb |
Eric&Barb wrote: |
Big question now is if the fuel seep or drip is there with engine idling or only shows up when engine is shut off. Can take several minutes for the latter to show. |
Thanks for this. I think I flooded the carb trying to start it. I will try again today if I have time.
speaking about time.... I am confused about the timing of the spark. My pulley has only one mark and both references I have say that is the timing mark at 7 degrees BTDC. I had used it prior as TDC and guestimated the 7* and the car started right up. After changing it to the manuals spot it would not start and flooded. _________________ 87 Doka 2WD Ej22,
56 Convertible |
EverettB Administrator
Joined: April 11, 2000 Posts: 69801 Location: Phoenix Metro
Posted: Fri Dec 23, 2022 9:27 am Post subject: Re: Leaking carb |
2Dokas wrote: |
Eric&Barb wrote: |
speaking about time.... I am confused about the timing of the spark. My pulley has only one mark and both references I have say that is the timing mark at 7 degrees BTDC. I had used it prior as TDC and guestimated the 7* and the car started right up. After changing it to the manuals spot it would not start and flooded. |
Yes, the single mark on the 36hp pulley is 7.5 BTDC when lined up with the engine case seam.
This is strange it wouldn't start unless the timing / distributor position was off.
Flooding would be a separate issue, although obviously cranking it a ton because it wouldn't start can cause that. _________________ How to Post Photos
2Dokas Samba Member
Posted: Tue Jan 03, 2023 2:15 pm Post subject: Re: Leaking carb |
Thanks!
Carb seems fine, just flooded from the change in timing, and the accelerator cable was too tight (thou not a factor in starting)
odd I admit, but it starts right up much closer to 10 degrees BTDC.
Not driving it much, too many other things to do and its raining a lot and no current reg or insurance _________________ 87 Doka 2WD Ej22,
56 Convertible |
