goober Samba Member
Posted: Fri Dec 23, 2022 7:55 am Post subject: Run switch... |
With temps at -10 deg F and a windchill of -40 deg F it's not only cold but dangerous to be out and about. If you rely on your Bug to travel under these conditions then you know how fast your Bug's engine/cab cools down when you turn off the engine. When I get my Bug started it remains running until I get back home. (with the exception of getting gas)
A run-switch allows me to keep my Bug running with the key removed and the doors locked. (I use a separate switch but you could adapt your kill-switch using a single-pole double-throw switch). I could use an extra key for my ignition but my steering wheel wouldn't be locked.
Carry the necessary cold weather back-up stuff and be safe out there. Gotta go, Bug's warmed up and I'm heading to the store. |
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Fri Dec 23, 2022 8:20 am Post subject: Re: Run switch... |
As an emergency when the ignition switch locked up, I just jumped a wire from the fuse for the running lights to the ignition circuit. Lights on, ignition on. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Fri Dec 23, 2022 8:32 am Post subject: Re: Run switch... |
Don't worry about anyone stealing the Bug
It's has a Manual Trans,, that nobody can drive _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Bonesberg55 Samba Member
Posted: Fri Dec 23, 2022 10:15 am Post subject: Re: Run switch... |
madmike wrote: |
It's has a Manual Trans,, that nobody can drive |
And that's pretty sad considering the AC bug is about the easiest thing to shift. |
oprn Samba Member
Joined: November 13, 2016 Posts: 12730 Location: Western Canada
Posted: Fri Dec 23, 2022 2:55 pm Post subject: Re: Run switch... |
madmike wrote: |
Not many thieves out in this weather!
We used to just lock them up running and use a spare key to get back in. Your solution sounds better. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
hobthebob Samba Member
Joined: December 08, 2021 Posts: 375 Location: Austin, TX
Posted: Fri Dec 23, 2022 5:19 pm Post subject: Re: Run switch... |
You could completely solve this problem by moving someplace warmer...
Come out to AZ, we have the opposite problem in the summer. |
Jacks Samba Member
Joined: July 15, 2006 Posts: 2348 Location: San Clemente, Ca.
Posted: Sat Dec 24, 2022 3:34 am Post subject: Re: Run switch... |
A gearshift lock could give an added degree of security. Stay safe out there, and happy holidays _________________ Jack Staggs
Actual name |
oprn Samba Member
Posted: Sun Dec 25, 2022 5:15 am Post subject: Re: Run switch... |
Jacks wrote: |
A gearshift lock could give an added degree of security. |
Got one, it's that third peddle that the kids of today have no idea what it's purpose is. Makes shifting nearly impossible when not used! _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3853 Location: San Jose, CA
Posted: Thu Jan 12, 2023 5:51 pm Post subject: Re: Run switch... |
Hmmm, I don't know how I even landed in this thread, musta been a couple inadvertent taps of my digits on this phone.
Anyway, interesting topic. I am picturing another switch - perhaps actuated by a press of the clutch - that kills the motor if someone unauthorized attempts to drive away, and then cannot be restarted (yes, an authorized operator needs a means to disable it before attempting to roll off).
Of course, I myself am not quite adept enough at eletricalicity to make something like that work, but I'd like to integrate something like that just for poops and grins. _________________ My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom) 😏 |
