Mnmunky Samba Member
Joined: December 18, 2012 Posts: 80 Location: Minnesota
Posted: Wed Dec 28, 2022 8:05 pm Post subject: White wall tire (tyre) options |
Hi everyone.
I wanted to see what experiences people have had with different systems of creating the white wall tire look.
I’ve read in many places that the white wall tire inserts can be a nightmare. Yet people like Portawall seem to have been in business for many a year:
https://portawallshop.com/
The advantage is that you can add these to any tire and are certainly the least expensive option (short of buying a tin of emulsion!).
Have you successfully fitted and used these? Are there any tricks to bring successful?
Next up are the companies that make the tires from existing. I guess they buy tires, rough up the face and then pour white rubber directly into the face of the tire.
I assume this is the process, though I’m sure this is a gross simplification.
One such company is Calli wheel and tire.
https://callitw.com/22575R15-Calli-Whitewall_p_341...0kQAvD_BwE
They seem cheaper than the main ‘fully built’ options, with more performance rated tires (radials that will work in the wet - not specifically ‘sticky’ race tires) and more options of width, wall size and white wall size.
Are they as good as the fully built for longevity? Has anyone used this or a similar service?
Lastly (as far as I’m aware - let me know if there are other options) there are the pre made classics by the likes of Coker.
https://www.cokertire.com/
These can be eye wateringly expensive and typically not the best in wet weather. The bias ply versions look the part, if you are going for originality and other than the old challenge of keeping them clean, aren’t going to give you as much trouble as people claim the inserts give.
I’ve searched on here through threads over the past couple or three years and couldn’t find any up to date opinions.
Thoughts?
Thanks |
obus Samba Member
Joined: March 08, 2001 Posts: 11070 Location: just off Garden State Parkway Exit 81
Ian Godfrey Samba Member
Joined: September 25, 2006 Posts: 1137 Location: Melbourne Australia
Posted: Thu Dec 29, 2022 1:45 am Post subject: Re: White wall tire (tyre) options |
BF Goodrich have 2 Whitewall Radials in165R15.
one has a 3/4" stripe, nice on a later car?
one has a 2 1/2" stripe, more a classic early car look
Blockley also does a 155HR15 narrow whitewall. |
bhartwell59 Samba Member
Joined: December 28, 2014 Posts: 792 Location: dallas, tx
Posted: Thu Dec 29, 2022 8:20 am Post subject: Re: White wall tire (tyre) options |
Ian Godfrey wrote: |
one has a 3/4" stripe |
These are what I have: BFG Silvertown
They look pretty close to the way my '74 came stock _________________ '74 Zambezi green Ghia vert, autostick, 101k
'87 Jeep Wrangler, 4.2, 330k |
kingkarmann Samba Member
Posted: Thu Dec 29, 2022 8:50 am Post subject: Re: White wall tire (tyre) options |
bhartwell59 wrote: |
They look pretty close to the way my '74 came stock |
I remember some of my buddies with their raised white lettered tires that were so popular back in "the day".
Being low on cash back then I went the white pencil route to color in my black letters. It was cheap and the result looked cheap.
Short of springing for real white walls I think your going to find the other solutions will also look cheap. _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
SBusch Samba Member
Posted: Thu Dec 29, 2022 11:30 am Post subject: Re: White wall tire (tyre) options |
I got these, reasonably cheap and look good. The only issue I've had is that two of the four whitewalls (front r and back l) turned sort of brownish, which apparently is a common thing, something to do with the oils in the tire.
https://www.performanceplustire.com/tires-for-sale...165-80-15/ |
Posted: Thu Dec 29, 2022 1:52 pm Post subject: Re: White wall tire (tyre) options |
yep, the oils in the black section can leach into the white rubber.
Interestingly, Blockleys claim to have fixed that. |
'40's guy Samba Member
Joined: February 13, 2021 Posts: 36 Location: Spo-Kane Wa
Posted: Thu Dec 29, 2022 8:48 pm Post subject: Re: White wall tire (tyre) options |
I have a lot of experience with Portawall inserts. I had them on my bus and '69 Ghia for years as I was too cheap to spring for genuine wide whitewalls. I would not recommend them. They interfere with the bead of the tire so you have to install inner tubes, which adds to the expense. Also, the Portawalls make a fair amount of squeaky noise because they're not as flexible as the tire and they rub against the sidewall where the tire bulges out at the bottom. Which brings us to the main issue; that rubbing eventually cuts a big old groove in the sidewall of the tire, which is a safety concern, to say the least. That said, they did look nice and I never had an issue with them wrinkling or flying off like I've heard they are notorious for. Here is a picture of my 1969 coupe on Portawalls:
I had always heard that they were really made for stiffer bias-ply tires and not really suitable for radials. |
blue72beetle Samba Member
Joined: April 23, 2008 Posts: 846 Location: Fort Wayne, IN
Posted: Fri Dec 30, 2022 7:54 pm Post subject: Re: White wall tire (tyre) options |
Oooh, those Vitor tires look good - though the mention of the discoloration is concerning. I guess it’s the old adage of you get what you pay for?
Continuing the research, has turned up side wall stickers.
All of the reviews and YouTube videos I’ve watched about them, seems to suggest that they are, cheap and look kind of cheap…
https://www.tirestickers.com/shop/white-wall-tires/
I’ve also seen a few ‘good ol’ guys’ (which I’m one, but not skilled like they are), cutting into the side wall of their tires on ‘42 Fords, and buffing down to the white lower level of their tires…
Not sure I’m man enough to risk that… that said, the Callitires seem to be my preferred option so far. There, they seem to rough out the sidewall and bond strips of white (zinc Oxide) rubber and then heat to vulcanize. The downside compared to Coker, is you have a seam. But at roughly half the price, with a greater selection of sizes, might be the answer.
Thanks for the experiences so far. When I finish and pull the trigger, I’ll update on how the Callitires perform (or whatever route I end up taking). |
ghiamanjc Samba Member
Joined: August 16, 2020 Posts: 146 Location: Vancouver BC
Posted: Sun Jan 15, 2023 2:43 pm Post subject: Re: White wall tire (tyre) options |
Ghiamanjc, those look great! How do you fix the crinkled one?
One step closer for me to pull the trigger on white walls.
Just need to find some tires I can justify buying!
Posted: Tue Jan 17, 2023 7:18 pm Post subject: Re: White wall tire (tyre) options |
So I happened across a discount code for the place selling Kontio white walls at the cheapest price I could find on line.
Kontio are made in Nokia in Finland and they promise to be pretty good quality radials for the money.
I was strongly considering Calli tyres, where the white walls are added after the tires had been molded, but the price and reviews of these (by guys running some seriously heavy tin on them - 57 Chevys and the like) seemed pretty solid.
As this is my summer fun cruiser, I’m not going to be going after new track records or high speed runs. Just hoping that they don’t turn brown after a year.
For the price though (for new tires) I’m hoping they work out ok. That’s 4 tires for the price of 2 1/2 Cokers.. |
Starbucket Samba Member
Posted: Wed Jan 18, 2023 4:28 pm Post subject: Re: White wall tire (tyre) options |
ghiamanjc wrote: |
I haven't tried to fix the pucker yet. My plan is to use Gorilla glue and perhaps some heat. Open to suggestions from Sambanistas....
I would use contact cement like Weldwood contact cement, you let each side get tacki then stick them together instant flexable bond. |
Posted: Sun Jan 22, 2023 6:09 pm Post subject: Re: White wall tire (tyre) options |
It would be really interesting to hear how you fix them Ghiamanjc. Useful for others looking for whitewalls in future.
My cost conscious White walls turned up today. Way more bling that I expected!
These are from Jegs. Packing is a good idea.
Will unwrap them at the garage that is going to fit them to the new rims. Hopefully have some time to do that this week. |
simon varley Samba Member
Joined: March 12, 2020 Posts: 175 Location: Geelong Australia
Posted: Sat Jan 28, 2023 2:27 am Post subject: Re: White wall tire (tyre) options |
Mnmunky wrote: |
Will unwrap them at the garage that is going to fit them to the new rims. |
hopefully you know this, but do those rims have a bead? if not you will need tubes too.
if the whitewalls are like mine, they come with a blue coating on the white that needs to be removed. You might want to powerwash this off before you go to your tyre fitting place
should look great when you are done! |
Posted: Sat Jan 28, 2023 7:52 am Post subject: Re: White wall tire (tyre) options |
Thanks Simon.
I wish you had posted this before Thursday… that’s when I took the wheels and tires off to the tire place for the two to be ‘introduced’.
Looks like I was lucky and had a bead - so didn’t need inner tubes, but I was wondering about how to get the blue off. It’s currently in place until I finish messing with the car before summer.
Other than power washing, how have others managed to remove the blue on their tires? Is there an easy way?
Posted: Sat Jan 28, 2023 8:53 am Post subject: Re: White wall tire (tyre) options |
Mnmunky wrote: |
Thanks Simon.
SOS Pad and Wesleys Bleach White to make them glow afterward and DO NOT rub the curb. |
Posted: Sat Jan 28, 2023 10:46 am Post subject: Re: White wall tire (tyre) options |
Thank you. I’ll give that a go. Great tip!
I’m looking forward to getting them on the car next and getting it a little more drivable, ready for summer. |
