Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2211 Location: UK (South)
Posted: Thu Dec 29, 2022 3:00 pm Post subject: Re: Think you've seen it all... |
Yeah, I subscribed to that channel a while back.
There's a lot to be said for annual, mandatory safety/roadworthiness tests like we have in Europe. _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
jinx758 Samba Member
Posted: Thu Dec 29, 2022 3:03 pm Post subject: Re: Think you've seen it all... |
Thanks for sharing ...
These videos are entertaining.
Some people are SO CLUELESS and most aren't aware they're in the shallow end of the gene pool.
Take care ... stay safe
jinx _________________ " It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference
You can't push a rope
VALVES (cold)
POINTS
TIMING
CARB (fully warmed engine)
SCRAPE ALL GROUNDS
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor |
supercub Samba Member
Posted: Thu Dec 29, 2022 3:42 pm Post subject: Re: Think you've seen it all... |
Here's one that came in at work a couple years ago for a flat tire. If I remember correctly, a caliper bolt fell out and the caliper shifted and ground through the rim. They probably had to drive it for a while grinding though to get it all the way through. Just turn up the radio more I guess. Some people.
Bonesberg55 Samba Member
Posted: Thu Dec 29, 2022 4:31 pm Post subject: Re: Think you've seen it all... |
Who.Me? wrote: |
There's a lot to be said for annual, mandatory safety/roadworthiness tests like we have in Europe. |
You are right on! In most states here, emission testing is required in urban areas with no regard for whether or not a vehicle can stop or hit a bump without the front end coming apart.
In Illinois, safety inspection for light trucks used to be required but that was done away with a long time ago. Don't pollute the air but everything else is just fine. Idiots! |
Jon Schmid Samba Member
Joined: May 29, 2012 Posts: 2038 Location: Southern California
Posted: Thu Dec 29, 2022 5:00 pm Post subject: Re: Think you've seen it all... |
Bonesberg55 wrote: |
Who.Me? wrote: |
I'm rather surprised that we don't have annual vehicle "inspections" here in CA. Another reason to fleece us drivers/vehicle owners with more "fees." |
KTPhil Samba Member
Posted: Thu Dec 29, 2022 7:34 pm Post subject: Re: Think you've seen it all... |
Jon Schmid wrote: |
We used to have random (yeah, right) roadside inspections for smog and safety in California. Stopped in the mid-'70s, I think. They weren't comprehensive, but covered lights, tires, brakes.
Joe 20 Samba Member
Posted: Thu Dec 29, 2022 8:15 pm Post subject: Re: Think you've seen it all... |
Ya, Ohio had them too. Stopped around the same time. They'd set up by the side of the road and pull over drivers at will. Usually young with a "hot rod." They were dreaded. If you did happen to pass they wanted to put an ugly sticker in your drivers side lower windshield...uhhh no thanks...can I just put it in the glove box? If you didn't pass it was a warning, ticket, or tow...up to them. _________________ "Someday the world is gonna be populated by nothing but Volkswagens'" Corporal Klairvoy |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Thu Dec 29, 2022 8:25 pm Post subject: Re: Think you've seen it all... |
Customer states…
It used to mak a grinding noise but then it stopped about three months ago…
But it started making that same noise on the other side last week. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Thu Dec 29, 2022 11:07 pm Post subject: Re: Think you've seen it all... |
Who.Me? wrote: |
That means you have to rely on the inspectors. At 1:57 in this episode, we see what they missed.
_________________ nothing |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Fri Dec 30, 2022 5:55 am Post subject: Re: Think you've seen it all... |
My Dad's Transmission shop, a young gal in a Pinto said she had a noise , I drove it in on the hoist and it locked up,lifted it up ,pulled inspection cove off the Differential, and "Metal Dust" hit me in the face, pin that holds the spiders fell out and locked it up we had a good laugh, then replace the whole dam thing, from the wreckers _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
oprn Samba Member
Joined: November 13, 2016 Posts: 12740 Location: Western Canada
Posted: Fri Dec 30, 2022 7:02 am Post subject: Re: Think you've seen it all... |
madmike wrote: |
then replace the whole dam thing, from the wreckers |
The whole car... I hope... with something else that didn't explode on impact! Just about anything else you would find at a wreckers would be better than driving a Pinto! _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
oprn Samba Member
Posted: Fri Dec 30, 2022 7:16 am Post subject: Re: Think you've seen it all... |
We used to have mandatory yearly inspections here too. The inspectors were a bunch of diehard anal jerks that would fail nearly every car that went through. That started in 1969 and Dad knew that the old '57 Plymouth Suburban Wagon would never pass so he bought a new '69 Bay Window Bus.
Well the new Bus failed! Headlights were adjusted too high! Dad told them it was because no one was sitting in the front seats, let me in there. Nope! Against the rules! No one is allowed in the cars when in the inspection bay.
Back at the dealership they confirmed that all VWs were failing due to headlight adjustment. They screwed the headlight adjusters down and put them back up after the car passed.
In 1971 government abandoned the mandatory inspections. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Posted: Fri Dec 30, 2022 8:26 am Post subject: Re: Think you've seen it all... |
When I was a kid in NJ back in the 60s, I usually went with my dad for his safety inspection. The only time he failed was in headlight aiming and it was with a new Rambler station wagon. They gave him a temporary sticker(30 days). He took it home, aimed the headlights himself, went back, and passed. You may not think that headlight aiming is a big deal until you're older and glare bothers you during night driving. There's also that super bright lighting that they allow now that discourages me from driving at all when its dark. |
Posted: Fri Dec 30, 2022 10:47 am Post subject: Re: Think you've seen it all... |
KTPhil wrote: |
Jon Schmid wrote: |
I know we had the recent roadside smog monitors to allegedly measure traffic as it drove by. I was always waiting for some clown to pop me when I went by in my 356. |
oprn Samba Member
Posted: Fri Dec 30, 2022 11:05 am Post subject: Re: Think you've seen it all... |
Yes I get it that headlight aiming is a safety thing but what the inspection morons failed to understand was that in a rear engine vehicle the load on the front axle and therefore the ride height AND headlight height was totally dependent on people sitting in the car! _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Posted: Fri Dec 30, 2022 5:38 pm Post subject: Re: Think you've seen it all... |
BITD,When Ford recalled the pintos for the gas tank thing,,all they did was pull one of the gas tank straps and slip a molded piece of Plastic under it, so the Diff don't rupture the tanks so easy,yea tank is right behind the Diff housing _________________ 'Black Ice'Drag Buggy 'Turbo'
Zundfolge1432 Samba Member
Posted: Fri Dec 30, 2022 5:58 pm Post subject: Re: Think you've seen it all... |
Glenn wrote: |
No you haven't.
When you have time to kill, check them out. |
I like stuff like that. Used to be most people knew a trusted mechanic that would look over the car while doing routine maintenance, self service stations took care of that. But rather than see it as a negative I see it as guaranteed work for a mechanic. I remember a fellow at work telling us his wife ruined the engine in their car because she put bubble gum over the oil pressure light because??? Because the light bothered her… |
cbeck Samba Member
Posted: Fri Dec 30, 2022 7:12 pm Post subject: Re: Think you've seen it all... |
oprn wrote: |
madmike wrote: |
The whole car... I hope... with something else that didn't explode on impact! Just about anything else you would find at a wreckers would be better than driving a Pinto! |
Remember the exploding square body chevy truck? Where the slo mo cam showed the Estes rocket engine smoking under the fuel door moments before impact. _________________ My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779 |
Posted: Fri Dec 30, 2022 7:16 pm Post subject: Re: Think you've seen it all... |
Zundfolge1432 wrote: |
Glenn wrote: |
No you haven't.
A friend of mine had an early 90's Honda Civic with massive miles on it, back in the late 90's. His wife had some sort of contract job with the US Forest Service over at Mt Rainier National Park one summer, and drove the Civic to and from here every two weeks (300 miles one way?).
One day she got home and he went to check out the car, and there was NO OIL! He asked her about it, and she said she saw the oil light come on, but" had a good feeling about it" so she kept driving. She drove about 100 miles with the oil light glaring. He added oil and kept driving the car for several more years, but the oil pressure had dropped significantly. _________________ nothing |
